mtaylor
Moderators
Everything posted by mtaylor
  1. I'm glad you got the bonnet to fit properly when closed. Looks like a perfect fix..
  2. Interesting looking model. I'm following. BTW, could the rear well covers be removed?
  3. Hal hasn't been on since 2017.
  4. Welcome to MSW, Fiurar. I would hope you'll do a log here at MSW. It's the best way to meet other modelers and also get help and ideas when you need them.
  5. I love the way you did that. Looks fantastic.
  6. Food for thought on the hood closing. You're right about destroying things to remove the engine. How thick is hood? Maybe sanding the inside over the intakes? Worse case... file/sand down the injector intakes and paint with chrome paint. Just some thoughts.
  7. I think the answer is: "depends". Paints at that time were mixed by various folks and not pre-mixed like today so color would vary. Aging of the paint after painting would also mean that it's varied dependent upon when was the last time it was painted. I think the answer is basically... use what looks good to your eye.
  8. I've tried nail clippers, razor blades, all the usual stuff. I finally bought a small "sewing scissor" from a fabric store. Works a charm. And I do NOT use it for anything else.
  9. Since I doubt you can remove the motor and lower it, I think your solution is a good one.
  10. Looking good, Gary. As for "cluttering up the workbench"... doesn't everyone do that?
  11. That's a small signaling cannon probably then. Or something to make noise on certain holidays.
  12. Serpe, I think that's a choice you'll have make. From what I've read, the hull color could be white, black, or brown if wasn't coppered. It all depended on when and where the coating was re-applied.
  13. Welcome to MSW. On the cannon... hmm.... How big is it? There are so-called "signal cannons" and there's also some pretty small ones designed to be fired off as basically noisemakers.
