mtaylor
Moderators
Posts posted by mtaylor
  1. Richard,
    The Arbor Tilt isn't too much saw if you'll be using it for other things.  If cost were not a consideration, the Byrnes saw would be the ideal table saw.   You are correct that a scroll saw wouldn't do what you want.  However, a band saw could be used for ripping and also do much of what a scroll saw does.
    For an inexpensive chop saw, take a look at Harbor Frieght: http://www.harborfreight.com/bench-top-cut-off-saw-42307.html
  2. Meredith,
    Here's my list for mill must haves:
    A vice.
    A clamp kit (or homemade one) to clamp down the workpiece, vices, etc.
    End mills.
    Collets (they work so much better than than a chuck).
    I'm also finding a rotary table useful for various things also.
    I'm sure there's more, but that's what I'm using.  I have few other bits that I've never used so I don't know how useful they are.
  3. But here's another question:  I have read that with the Micro Mark/Grizzley micro mill it can be hard to find accesories. I would hope that Proxxon has plenty to choose from (and I'm still leaning toward something within my budget & skill range). So, what would you experienced folks consider to be the essential accessories?  What, for example (and here's where I show my ignorance and inexperience) does a 4 jaw chuch enable you to do that a 3 jaw chuck would not?
    Cheers,
    Martin
    Martin,
    There micros and minis.. and the terms get cross-used a lot.   Here's the MM Micro:
    This one has some tools issues as it uses M4 hardware to secure items to the table.  The biggest problems are modifiying and fitting accessories as they are made for the "mini" type.
    Here's the MM "mini" or the so-called "R8" type.  R8 is the type of taper used in the spindle.
    It's basically the same as the Grizzly and some others and also the Sherline tools fit it.  It uses the M6 size hardware to secure items to the table and is a lot more standard as the table is bigger with the slots further apart than the micro.
    4-Jaw and 3-Jaw chucks are used for holding different workpieces.  4-jaw is for square or rectangular stock and 3-jaw for round.  If you get the 4-jaw, get the self-centering.  Usually the chucks are used with lathes or on a mill in conjuction with a rotary table.  I'm not a machinist and am still learning power tools like the mill.
    Just a note... if I had known what I was getting into, I would have bought the "mini" or R8 mill.
  4. Here's some food for thought if any casual observer mentions things like "uneven plank widths" or "not all the same color". Just mention this: "The real thing was planked with what the yard had on hand.  They didn't sort it because one piece was too light or too dark.   I'm attempting to duplicate their magnificent efforts."
    By the way John, will there be any work left on her for you take on the road?  You are moving right along.
