giampieroricci
Everything posted by giampieroricci
  1. After several attempts came bad, I managed to make a window more acceptable; I do not know if I can, but I want to try to fix the two hinges to be able to open; will be very difficult to fix the hinges to the threshold ......... In the photos the window is stuck
  2. I have finished the nailing of the transom and I banded the inner part of the time of transom
  3. Little progress; I completed the bandage transom: I have yet rifinirne contours which are abundant:
  4. I started working on the transom, probably the less successful because of some asymmetry that I hope, completing the work, it is not too obvious. Meanwhile, I trimmed the excesses of strakes: I built the two stretchers of the transom: And the crowning that supports these stretchers: From this picture I get the impression that the courses tend to rise slightly to the left, although it seems not live; mah!
  5. Exscuse me, Mark.... From the first picture I see that the plank of ebony has not a curvature harmonious but has edges a bit 'too accentuated. This could affect the lines and the beauty of the model! You still have time to correct this error!
  6. Druxey you're right! Soon I'll have to paint the entire hull with matte varnish
  7. I cut the excess The final result; I'll probably still reduce thickness because it seems a bit 'too much, but I'll do it later, when I finish the walled inside starboard and adjusted the length of the lead lining.
  8. Before fixing the dolphins I believe I must cover the hawse pipes with lead foil. For this, I thought of using the commonest fishing sinkers, long enough and suitably machined on a lathe to obtain a kind of tube: Reached the diameter must have stuck in power, tapping it with a hammer. the tube in hawses
  9. I built a tool to make the molding to the dolphins: and after a long, patient and very delicate manual work, here is the result:
  10. I started the construction of the dolphins bow; For these details, very mangy and difficult to achieve, I chose boxwood. They are made in two pieces joined to scull. After the first attempts, miserably failed trying to figure out how and where to make that scull, I think I've reached a good compromise: I preferred to keep me abundant at the beginning and gradually refine until the right size; Bonding: after a first roughing tests positioning:
  11. I finally finished the long process of nailing the last strakes, and having finely sanded the entire surface of the hull with sandpaper gradually more and more fine (220, 400, 600), here is how it looks:
  12. Thank you very much, Mark! I'm desolate! I read just now your question........ To simulate the caulking I used a thin piece of black cardboard 0.3mm
  13. Assembly of the spur of the bow: The gunwale, boxwood, is composed of two superimposed layers and working was performed with a micro-cutter to the microscope;
  14. While I carry on the long job of nailing the last strakes, I proceeded to make holes of hawses: their axis is parallel to the keel and have a slight downward inclination, to favor maneuvers hawsers: I also started the construction of the spur; To give more strength to the union between ebony and peer I thought to use a plug interlocking between the two species:
  15. After removing all the nails with the card I started to make a first rough finish with 120 sandpaper to remove excess glue and smoothing the side. There is still a lot of work, especially in the critical points of the curves more, also I have yet to finish the nailing in the last strakes, remained suspended:
