rvchima
Everything posted by rvchima
  1. Bob, Thanks for the information about the spell checker. I use Firefox and had somehow had no dictionary installed. It's fixed now so I have no excuses. Rod
  2. Masts Stepped I stepped the masts last night. Plans on the wall to align the side view, plumb bob hanging from the ceiling just behind the main mast to make sure it's vertical from the front. I used 5 minute epoxy for the job. I've done everything else with 15 second medium CA, so the epoxy gave me 20 times the working time I'm used to. Stayed up until 1 am making tiny wire links for the chain plate assemblies. Not the most fun part of the model. ;^(
  3. Augie, I just downloaded and printed the photo of your yards. I'll be building a set before long, and your photo will be a better reference than all the plans in the box. Rod
  4. Hi Bob, I just skimmed through your Bluenose build log and am totally amazed at all the minute details that you have built. I've never seen turnbuckles that small. Just magnificent! I'll be following along from now on. Rod
  5. Question about this editor This is a nice editor for a blog, but does it have a spel checkr? I can't find one anywehre!
  6. New stand built 16 weeks, 320 man-hours I wanted to build and attach the permanent stand for the Syren before I attached the masts. As I dug through my lumber rack looking at cocobolo, padauk, and quilted maple, I had to step over a pile of quarter sawn white oak waiting on the floor for my next build - a Stickley-style coffee table. And suddenly I realized that the real Syren was probably made mostly from oak That settled it - the stand had to be oak. I built it yesterday and attached it today. I have also finished adding all the miscellaneous blocks and rigging to the masts, so it's time to head back downstairs and step the masts.
  7. Gentlemen, Thank you all for the kind words. I am enjoying posting this build log, and it is gratifying to know that some folks are following it. Rod
  8. Masts, Tops, and Top Masts Complete 15 weeks, 301 man-hours The Syren has gotten much taller too! The masts aren't actually attached yet but they will be soon. I better build and attach the final base to the model before I attach the masts. It took 19 hours to build the masts, tops, and top masts. The 1/16" tape that came with the model did not stick very well, so I bought a roll of 1/16" flat black graphic tape made by Chartpak at a local art supply store. It sticks very well, but I coated the mast bands with some diluted white glue just to be sure. I like this overhead view. In real life the cross trees would be about 75 feet above the deck. I have climbed about 40 feet up some big spruce trees in my back yard to trim branches, and it was terrifying! Imagine hauling sails this far above the deck in rough weather.
  9. Bowsprit, Jibboom, and Flying Jibboom Complete 14 weeks, 277 man-hours It took 23 hours to build and rig the Bowsprit, Jibboom, and Flying Jibboom. The Syren has almost doubled in length since my last post. I've had to revise my situational awareness - I kept bumping parts that weren't there before and broke the dolphin striker twice. I shaped all the booms, etc. in a drill press. I left an extra inch to go in the chuck, spun the part at 1600 rpm, and tapered them with sand paper. Pretty easy. I rigged most of the blocks to the booms with thin wire instead of thread. That's not realistic, but it is a lot easier and looks OK to me.
  10. Question about thread supplied with the kit The thread supplied with the kit is wound tightly around plastic "bobbins," and ends up kinked when you unwind it. Should I use it as-is, or soak it in water to straighten it out?
  11. Question about seizing a line A couple of places in the instructions have said to seize a line with thread. I think I could do it full scale but it sure is hard in miniature. Does anyone have any tips on how to hold two threads while wrapping them with a third?
  12. Longboat completed 13 weeks, 255 man-hours The longboat took about 1.5 times longer than it should have because of two major mistakes. I mentioned my first mistake in my last post - I sanded through the hull. It patched up OK with wood filler but the stain was blotchy. My second mistake was to try to line up the ribs by eye. I measured carefully but the result looked terrible, as shown below. I ended up starting a new longboat from scratch. This time I held it up to the light periodically as I sanded. When I could see light through the wood I knew it was time to stop. Left: What happens when you sand through the hull, then try to line up the ribs by eye. Right: New hull with ribs aligned with a jig. How I aligned the ribs First I eliminated the center keel strip. You can't see it under the floorboards anyway. Then I used a 1/8" nylon cable tie to align each rib parallel to the last. I used spring clamps to hold the cable tie. CA glue barely sticks to the nylon. The second hull looked SO much better than the first that I'm glad I started over. The longboat took 27 man-hours to build but it's one of the best tiny models that I've ever built. Maybe I'm finally getting the hang of this precision work. I did start on the bowsprit. Only a few hours of work so far, but it makes a big difference in the look of the ship.
  13. Augie, Tonight I was trying to match your speed on the longboat and sanded through the side. Now I have to wait all night for the wood filler to dry. Maybe I can use spray paint to catch up. Rod
  14. Hull complete except for longboat I spent the last couple of weeks working on deck fittings, so my hull is complete except for the longboat. Augie's build log shows the hull, longboat, and bowsprit, jibboom, and flying jibbom complete at about 800 hours. I figure that I am building 2.5 times faster than him at about 1/5 the quality! 10.5 weeks, 226 man-hours Here are some detailed views> The stern cannons were fun but the companionway was a pain. It is thin, flimsy, and didn't want to stay square. It could be better. The hammock cranes seemed very flimsy, but when I got the 1/16" x 1/32" rail pressed into place it firmed up. Tying the netting in place was literately a pain in the back. I had to stick my face right into it to see what I was doing. And the photos show every thread that I didn't cut clean off! Guess I need to go back for the nail cutters. The main fife rail was hard to make by laminating 1/32 " stock. It would be better to cut it from 1/16" ply. The stanchions were easy to turn in a Dremel tool, but I wish they had been supplied as castings with pins on the ends. The gratings were fun. The pieces fit together perfectly. If I ever have granddaughters I can start making doll houses. Lots of trip hazards on this ship. It would never pass OSHA standards. I can't believe that I built a ladder to hide inside this thing! If you're building the Syren, just build the companionway with the door closed. I never expected a periscope on the Syren. Now I get to put the Syren aside and build the 25' longboat, a kit within a kit.
  15. Completed Cannonades Well, the cannonades are built, installed, and rigged. You can see that I ignored most of your cries for historical and scale accuracy by using the larger eyebolts, by placing the sleds on the deck without wheels, and by notching the waterways so that the gun barrels would protrude outboard a little more. Thank you for all the excellent suggestions, but I doubt that anyone who ever sees the model will know the difference. 9 weeks, 182 man-hours I bundled the ropes on deck instead of making the coils shown in the plans. The bundles looked better to me. It took 18 hours to rig the cannonades after they were built and installed
  16. My first major SNAFU I ran into a very unplesant surprise when I completed my first cannon and set it on the deck - it didn't fit! Somehow I cut the gun ports too close to the deck. I even cut out the little paper gun and checked it on the rear ports, but never on the side. I should look back in the instructions to see how it happened, but it's too late now. The only solution is to omit the swivel brackets from the front of the cannon sleds, and the wheels from the rear. The guns end up centered in the ports. The front of the sleds hit the waterway, and the end of the guns end up about flush with the outside edge of the ports. Can anyone tell me how far the guns should extend beyond the edge of the ports? Should I notch the waterways and push the guns up to the rails? 8 weeks, 162 man-hours
  17. Pin rails >>> If anything in this kit is laser cut, it should be the pin rails! <<< Pin rails complete, 7 weeks, 153 man-hours
  18. More on eyebolts In an earlier post I asked if anyone thought that the brass eyebolts supplied with the MSW kit were too small, and asked for suggestions about painting them. Augie recommended Blacken-it. I tried using similar chemicals that are used to patina stained glass but had problems with the patina flaking off the eyebolts. I ended up ordering the only black eyebolts I could find from http://www.modelshipyard.com.au/ You can see them compared to the MSW eyebolts in the photo, They are beautifully made, but just a little bigger than I would like. I decided to use them anyway. Left: eyebolts supplied with the kit Right: eyebolts ordered from Modellers' Shipyard Cannons (Cannonades) I don't know if the discussion on cannons has been reposted but I'm glad that I saw it earlier. Alert builders realized that the cannons suppled with the MSW kit do not look quite like those on the plans. I went ahead and ordered 16 appropriate cannons from Bluejacket Shipcrafters. http://www.bluejacketinc.com/ They were expensive but I like them a lot better than the originals. Left: cannon supplied with the MSW kit Right: cannon bought from Bluejacket Shipcrafters
  19. It's been a while since my last post. I finished the headrails and the exterior of the ship. The headrails were hard to build. I tried carving double mouldings on the upper rails like Chuck showed, but gave up and used single mouldings on the lower rails. I decided to paint my figurehead. She looks like she has a black eye in the photo, so I suppose she needs some makeup! 6.5 weeks, 136 man-hours
  20. Question about eyebolts The eyebolts supplied with the MSW kit seem to be a much finer gauge than those shown in other build logs. They are also a pain to paint. Is everyone else rolling their own from wire, or is there somewhere that I can order 350 nice black eyebolts?
  21. And that's where I left off before the site went down. Since then I have built a rudder, sweep port lids, gun port doors, and a temporary base. I am now working on the head rails, which are impossibly small to carve. 6 weeks, 125 man-hours
  22. Here are some views of the plated hull. In extreme close up the nail patterns aren't as precise as some of the others I've seen in the MSW forums, but in general I am very pleased with the way the model looks. I have several kinds of chemicals used to add patina to stained glass leading. I could easily change the look of the hull, but I kind of like the shiny copper. Please let me know if this this is unrealistic practically or historically, and I will reconsider. Now - off to build a rudder.
  23. I can't believe I have finished copper plating the hull already. It only took 15 hours, start to finish. I made the stamps by pounding tiny brass pins directly into the end grain of a block of 3/4 inch cherry. The plans call for 11/16 inch, but 3/4 is so much easier. I clamped a metric ruler to the block, and spaced the pins every 2 mm. I rough clipped the pins with the wire clippers mentioned above, flooded the end grain with thin CA, sanded the pins to the same length with my disk sander, and sliced the block to size on a band saw. 2 hours per stamp. I made a stamping jig pretty much like Chuck described in the kit instructions. One tap with a tack hammer, pull, tap again. 45 min. to tap 375 plates and another 45 min. to cut them apart with scissors. 1.5 hours per side of the hull. Grab a plate, pop an X-acto knife into the long edge, stick the copper to the end, peel off the backing, and place lightly on the hull. 5-10 sec. per plate. This was the most fun I've had on this model so far - just like playing with Legos. After laying down an area of plates I burnished them with the rounded piece of balsa shown in the second photo. 29 days, 110 man-hours
  24. Here I added a note on the tools that I have found most useful so far. I have since discovered other forums to share information about tools, so hope it's OK to digress here. Wood carver's chisel At first I tried cutting my planks with an X-acto razor saw, but that was slow and left a rough edge. Then I realized that I could chop them to length in one motion with a wood carver's chisel. It works perfectly on 1/8 inch strips. Dremel tool with sanding drum How do you thin out the inside of the bulwarks? With a Dremel tool and sanding drum. It also worked well for trimming extra material off the transom. Fine wire clippers Need a quick and dirty way to cut a 1/8 inch plank? Use these clippers from Sears, then clean up later with sandpaper. Proxxon disk sander You can get his neat little disk sander from Woodcraft or Amazon. It is pricey, but great for cleaning up cuts on thicker stock. Be careful with parts smaller than the gap between the table and the disk.
  25. Paint I have used Testor's Model Master enamels for everything so far. Their Insignia Red seems to be a good match for the inside of the hull. Noted added later - the enamels chip off easily. I have completely switched to Testor's acrylics, except where I need to match the original red. In the photo below the deck is planked and stained. I marked the tree nails on the outer hull with a mechanical pencil, and I think they look pretty good. I still have to mark the deck and add the waterways. Today I was Googling for "ponce wheel" to find a shortcut for the copper plates. Then I spotted Thomas' build log with his beautiful stamped plates. Now I think I'll have to give that a try. I have used a lot of that copper foil for stained glass projects, one of my other hobbies. With stained glass the copper foil all gets soldered together. On the bottom of a ship model it is totally exposed. Is anyone concerned about it falling off in 40 years? - Not that I'll be around that long :? Note added later - I have since found many posts attesting to the durability of the copper foil, although I did manage to tear a couple of plates when I added a brass pedestal base. 27 days, 95 man-hours
