Posts posted by kiwiron
Fantastic job Mark she looks great,it'll be a big day when you take her off the jig,Happy retirement and b/day,wish i could as well but not yet for me.Ron.
- mtaylor and avsjerome2003
- 2
Here's my first ratlines using a copy of the plan sheet as a template,worked out to be an easy way to do it.I used .25 black thread they say to use natural thread and indian ink a bit messy you would think.They sell the black thread so don't know why they did'nt put it in the kit.One section done seven to go and this has only two masts.
She looks great,big changes after a good sand ok.
Hi Denis you have done an amazing job of your S.O.S,she is a beautiful ship alright.
Hi Mick nice job.This will be my next build when i finnish the supply.I am very interested to see how you go.Ron.
- popeye the sailor, mtaylor and Dfell
- 3
The Bowsprit looks real good Popeye,nice to see some rigging on.
Thanks,just hanging the rope for the upper shrouds deadeyes.Just finnished doing some odd rigging off the mast while i can get to them easily.It was good to get the futtocks done putting some more tension on the shrouds to make the rats easier.
- popeye the sailor, Dfell and cpt. Tom
- 3
Very nice Popeye,a great looking model,you want a bigger one calm down the Goth is next.
Hi Doug for the bowsprit it was only by doing a trial fit of the spirit yard that i could see one block won't work because thats where you fit it to the bowsprit.I was putting a hole in the center for a 1mm brass rod for later attachment.On the bowsprit as well you have 2 blocks one each side for the center 2 blocks of the sprit yard.
Hi Doug,ok now i've got the sheets beside me.You're right,on the spiritsail yard they have the blocks on the outside as J's they should be H's,(single 3 mm blocks) as in sheet #5 and in the centre there should be 2 x J's not one.For the direction the blocks face on the yards look at later sheets to see which direction the rigging comes into the block from and where it goes after the block. The 4 blocks on the spiritsail its self face forward. On the bowsprit it's not clear how many O 5mm deadeyes you should use.It should be 3 one thread goes to port,one to starboard and one to the stem.Hope this helps,surely they should have checked these instructions before releasing the kit.The spiritsail yard is the 3rd one down in the photo.Ron.Good luck.
No worries Doug i'll put the details here after work.It's only by looking at a later rigging sheet plan i saw a discrepancy.It's the bowsprit yard.
Hi Doug when you get to the yards one of the yards has the wrong set up on it.
Thanks Doug great to see you back here.
Hi Doug,it's great to see your Supply again.How about your latest photos so i can copy you again.ron.
You're right Tom i would'nt have a clue if it is accurate or not as long as it looks ok and it does'nt get knocked of the shelf and break.
HMAT Supply by Kiwiron - FINISHED - Caldercraft 1/64
Thanks Augie and Mark,thats good to hear it looks right.I got the advice from Frank to get the shrouds tight then it's easy.
