Everything posted by KenW
Good to see that your progress is going so well. Your hull looks really great. I'm in the process of framing my gunports, as well, and it is taking a while. Keep up the good work.
- 42 replies
- fair american
- model shipways
Your model is coming along great. I really like your quoin. I'm going to have to rework mine. Great job.
- 42 replies
- fair american
- model shipways
I am definitely going to cut the forward corners of the aft hatch. The holes are for the anchor cables. My kit came with small dye cast quoin handles. I am planning to use them. Also, I am using Bob Rafine's log as the guide for my build. He did an outstanding job!
- 455 replies
- fair american
- model shipways
My FA build progresses. I like your deck. I don't think the 1/8 inch planks look bad at all. I notice that your grating is done with the 'crisscross' method. How come you didn't run out of wood grating pieces? I don't think I wasted any; but I didn't have enough to do both hatches that way. (see my build log.) I used the gun carriage parts from the kit and didn't worry about the fore cheeks being narrower that the aft cheeks. I am worried about the gun port placement. My gun carriages seem to be higher/larger than the plans. I guess everything will work itself out in time. Best of luck. Cheers.
- 42 replies
- fair american
- model shipways
I made the hatch covers because I want to have them installed before I do the deck planking. The problem is that I thought that the grating was made by using the included grating pieces “crisscross”. But after doing the larger hatch (left in the photo), I didn’t have enough wood pieces for the smaller grating. Then I noticed that other modelers laid the pieces side-by-side. So now I have one hatch grating done one way and the other done another way. But I don’t, at this time, think that it looks so bad. I don't want to take the larger one apart; or try to get more grating pieces from Model Expo. I'm leaving the coaming in walnut. I like the look of walnut deck ‘furniture’. So I will probably stain the rest of the furniture wood walnut color. Also, I glued the waterway.
- 455 replies
- fair american
- model shipways
Thank you all for your support. Ed: I used the gun carriages and barrels supplied with the kit. The bottom of the carriage, including the axles, were pre-cut and square (i.e. the cheeks are parallel). And, I also had problems extracting the laser carriage parts from the basswood board. Basswood splits too easily. My previous model had the carriage parts in a walnut board and I cut the axles from planks. In this case, I prefer the walnut. My solution was to simply glue the trucks right onto the cheeks when the axles split off. The carriage is small enough so that is hard to see. Alistair: I am glad that there are more rather than less bulkheads. I think smaller spans between bulkheads would make things easier.
- 455 replies
- fair american
- model shipways
Structure creation is progressing. I attached the Stern, Keel and Stem to the Center Keel first and then fitted and glued the bulkheads. I added some scrap wood to strengthen the bulwarks during fairing. The fairing is complete; but I had to add shims to a few bulkheads – including the starboard side of bulkhead #1. I also added the filler blocks fore and aft. I added scrap wood around the hatch openings so I can install the combings before laying down the deck. Everything, so far, is pretty basic but enjoyable and relaxing.
- 455 replies
- fair american
- model shipways
Since you have been great answering my questions, I have another one. (Punishment?) I know I am getting way ahead of myself, (I am still carving the bow and stern filler blocks), I was looking at your stern molding and the bow knees and rails. It looks like you are able to score the wood perfectly down the middle making it look like you glued two pieces together - similar to the way you glued together three pieces of wood to make the head rail. Is there a trick to the scoring, or your hand real steady with the x-acto blade, or did you glue two pieces together. (Also, any tips about the round "ball" on the upper cheek knee would be appreciated.) Thanks.
The replacement center keel finally arrived yesterday. The new part matches the Fair American’s plans exactly. I attach photos of the old center keel sitting on top of the new replacement center keel. The two parts line up perfectly at the stern, but the difference in size is well over a ¼ inch at the stem. So now I am able to start removing the laser burn, redrawing and cutting the rabbet line, and gluing the stern/stem posts, the keel, as well as the 16 bulkheads to the new center keel. It is great to be back modeling again.
- 455 replies
- fair american
- model shipways
You model looks great! You hull planking is excellent. Are you planning on painting or going with the natural finish look? Cheers
- 42 replies
- fair american
- model shipways
Ed: It took me quite awhile to figure out how to use the new MSW. Once I got started, it seems sort of logical. The place I started was in "The Captain's Lounge". There is a tutorial on how to start a log, add photos, etc. I would recommend starting there. Cheers.
- 455 replies
- fair american
- model shipways
Thanks Alistair and Bob for the encouraging comments. I uploaded a couple of photos of my Armed Virginia Sloop on the completed models gallery. Cheers.
- 455 replies
- fair american
- model shipways
The replacement center keel from Model Expo still has not arrived; although they say it was shipped on July 9th. The binnacle in the Fair American is also made from dye cast metal. It doesn’t look very good to me so I decided to make my own from left over walnut planks from the Armed Virginia Sloop. I based my design on rafine’s and added an extra drawer that can hold charts and stuff. There probably should be some kind of vents on the back or roof since I assume that there were lanterns behind those “triangle” shaped doors. I may be changing the overall “look” of the Fair American with these changes, but I guess I can always use the metal binnacle, as well as the metal bilge pumps if necessary. Anyway, I wish my center keel replacement part would finally get here so I can start building this kit in earnest.
- 455 replies
- fair american
- model shipways
Thanks. My thoughts were the same as yours. I remembered that this is a model created from a model. I will have to give it more consideration. I am not at that point in my build yet, so I do have time. I also agree with you and Figuerres that two stairs and two doors makes things pretty crowded. Thanks again.
I don't know what it means to be "photo-etched". I will have to do some research here. Thanks.
- 455 replies
- fair american
- model shipways
Does anyone have a way to get that fancy scroll work onto the stern? My hand is not steady enough and the Fair American does not come with metal scroll work that I can just glue on. I would need the letters for "Fair . American ." as well (although I can probably get decals for that). Thanks.
- 455 replies
- fair american
- model shipways
Ed - I'm glad Augie answered your question since I haven't gotten that far yet on my model. Also, I forgot to credit Aliluke with the design of the bilge pumps. His Armed Virginia Sloop model is outstanding! Still waiting on the replacement center keel from Model Expo. Cheers.
- 455 replies
- fair american
- model shipways
I have a question regarding the placement of the guns. I see that you have only one stairway and one door into the cabin. Using the plans I see that the aft guns block the doors; and firing the guns would completely destroy the stairs. Also, your aft gun is not as close to the cabin 'panel' as the plans show. How did you determine where to place the guns? And was your center keel the correct length as per the plans? Thanks.
The replacement center keel from Model Expo still has not arrived. The Fair American kit provides bilge pumps made from dye cast metal. I didn’t like the look of them and think that wooden pumps would be much better. So I constructed two pumps based on the ones from the Armed Virginia Sloop. I started with a ¼ inch dowel cut to a length of 3/8 inches. I used 3/16” .020 walnut planking split in two around the dowel to give the look of a barrel. The handle bracket was made from 1/8” square walnut stock with a notch cut in the top. The handles were 1/16” walnut rounded from about halfway to one end and leaving a nob or ball at that end. I made the straps and U-bracket from 1/16” strips cut from a manila folder. I find it is better to paint the manila strips before gluing. Finally, a spout was cut from 1/16” square walnut stock with a gouge cut into the top. A photo of the pumps is attached below. Next I plan on replacing the dye cast metal binnacle. Again, a wooden binnacle will look much better.
- 455 replies
- fair american
- model shipways
