Diver
Everything posted by Diver
  1. To improve my skills in dealing with small painted parts I purchased this kit from Echelon hobbies in Brighton Ontario. This will be used as a learning curve before Continuing with my 1/12 scale Alfa. The colours used may not be accurate but they are what I have. At this stage I am not ready to attempt spark plug wires but that will come later. The kit is a 1/25 from Moebius models.
  2. Worlds finest navy, Must have been the RCN.. LOL
  3. I believe that Douglas Bader was flying a Bulldog when he crashed and lost his legs.
  4. Thats great news. It is so easy for a country to lose its history due to lack of funding. We can not always rely on private funding and donations.
  5. I have the luxury of using the second bedroom in our Condo.
  6. Steps 5, 6, and 7 complete. I now will wait for my airbrush set up before going any further. I will start on the engine but will only do main pieces and hand paint smaller items like hoses, distributor etc. This kit is all produced and have not run into any problems , yet. I do require my back kit magnifier for the tiny nuts and bolts.
  7. Thanks for pointing this out. I have disassembled the front suspension and scraped the mould lines. I have started on the rear springs and scraping was much easier before assembly. Once the rear suspension is installed the build comes to a halt as I wait for my airbrush set up. Will be picking that up in Ottawa in early September.
  8. I was initially going to paint different colours on the suspension but I have not yet received my airbrush system. I am going to paint the model as per photos in the build manual. Front friction dampeners added.
  9. I have started on this build, my first car in over 50 years. It will be a slow build as I am still waiting for my airbrush set up. There will be a learning curve and lots of practice before putting paint to the model. Step 1 and 2 complete
  10. I am going to call this build Finished. The small boats ended up in the garbage, new ones will be ordered from AL. I started this build with great enthusiasm but that was lost when I ran into problems with some of the materials, and lack of drawings. The videos are a great help but drawings would be better in my opinion. No mast lights are provided with the kit so I used plastic thumb tacks. This build gave me great frustration at times and complete joy at others
  11. Just about finished. Only the mast and fenders to complete. The small boats ended up in the garbage so I will order a new set from AL. All the parts for the boats are on one small sheet so it should not be a problem. I have lots of material for planking.
  12. I am just finishing the up dated Sanson from AL. Has not been the most enjoyable build. I will follow along on your version.
  13. Making some slow progress. I will finish everything but the small boats. More on that later
  14. I just purchased the DSPIAE photo etch bending tool so the ladders and other parts could be shaped . The tool is well made and worked very well. Unfortunately the operator not so good. After bending the ends of the ladder I twisted the steps in the wrong direction. When trying to correct this the steps broke off. The sides were drilled and some copper wire cut and soldered in. It’s not perfect but with some paint it will be acceptable. The towing deck of the tug is pretty much complete, now it’s onto the boat deck.
  15. Looking at these photos it appears the capstan shifted when I glued it down. I used CA and Titebond so I don’t think it can be moved
  16. I have started on some of the fun stuff. The capstain and anchors are secure, the ventilators require a bit more work before they are glued in
  17. Welcome aboard. I am a novice builder having completed the Medway Long boat by Syren and am in the process of doing the Sanson Tug by AL. What I have found with the video instructions is that they leave out some important steps. An experienced builder would think of these. In my case it was bevelling the planks on the hull. If I had not built the Longboat that came with very detailed instructions I would not have known to do this. In hind sight I would have viewed the videos numerous times to to see if the steps were in a logical order, case and point, the gunwales and deck/pilot house would not have been installed til after the hull was planked. Good luck with the build.
  18. Two coats of blue on the uppers. Had a bit of bleed through on the rub rail. Should be an easy touch up with a small brush and more masking tape. I am pleased with the Taniya tape for doing curves. Starting to look like the photo on the box.
  19. I am using the AL acrylic water based paints on my SansonTug. The paint is quite thick and does not seem to flow very well. If you brush on paint in one direction and then come back with the brush it pulls the paint away. The hull is well sanded with a primer sealer applied. Is there away to thin the paint to slow drying time and help it flow better? Thanks
  20. Two coats of Red Hull paint applied. Levelled the hull in display cradle, fore and aft, and port to starboard and applied the water line marking with my cobbled up contraption. It worked out well. Next I will mask of the water line and apply the blue hull paint
  21. Put the Hull Red on this evening. There are a few areas that will need some more attention. I am pleased with the progression so far.
  22. I have a question about painting. I am using the AL paints and put the first coat of Hull Red on. It seems to dry too quickly, when a second brush stroke is done over the area just covered it seems to pull the paint away. Is there a way to thin these paints to extend the drying time? The AL paints are water based acrylics.
  23. I have done another coat of filler and primer and another sanding session. There are still a couple of areas that need attention but I have to remind myself that this is a Tug , not a racing yacht. Still not an excuse to make it as good as possible. Next step will be adding colour coats.
  24. I have done another coat of filler and while it drys I started on one of the small boats that come with this kit. The instructions show this as a Clinker build, but starting at the gunwales and going to the keel would have the overlap in the wrong direction. I have decided to build it as a Carvel. Hope this is the right term. A couple of pics to show my clamping solution for this small build. The instructions show the small boats covered and lashed to the deck. I might try and leave the covers off and have them swung out on the Davits ready to be lowered. Any thoughts on this appreciated
