Everything posted by drtrap
At this point I'd like to ask, especially you Mort and Norman whether you have painted in yellow ochre the middle and upper 1/3 parts of fore- and main- masts or you have left the unpainted (except the sections in black). If you have left them unpainted, did you use the original dowels from the kit or have you ordered walnut aftermarket dowels? Thank you in advance! Stergios
- 1,144 replies
- snake
- caldercraft
- 1,144 replies
- snake
- caldercraft
- 1,144 replies
- snake
- caldercraft
Next stop: trying to chequ the alignment of the midle (top mast dowel) and the lower part of the foremast. The most difficult point of this procedure is to find the right height to open the hole and pass the hinge to stop the middle part on the gunwale (i prefer to use a 2mm toothpick vs the 1,5 mm walnut strip). All the parts are dry fitted, so isn;nt so easy to keep them in the right way.
- 1,144 replies
- snake
- caldercraft
Hi everybody, I'm back again. The most difficult point at this stage is to shape and align both the rectangular edges of the same mast part at the same plane/axis...
- 1,144 replies
- snake
- caldercraft
Thanks again Mort. The lower parts of the fore-, main- and mizzen mast are ready. I'll shape the other 2/3 parts and following the literature and your advices, I'll see. For the mo I'm leaving for the greek islands for some days.... Cheers!!
- 1,144 replies
- snake
- caldercraft
Right, I've "Rigging period ships models" on my desk but I did/nt know the writter.... Thanks a lot. Cheers
- 1,144 replies
- snake
- caldercraft
Hi again Mort could you please inform me what;s exactly "Lees, Pattersson and Lever" ?? A reffering rigging textbook or something related? I'm in complete darkness about this.... Thank you in advance.
- 1,144 replies
- snake
- caldercraft
Hi Mort and thank you so much. I think I need to take my time to deal with all those ...sticks and spaghetti!! For the mo I feel more safe to attach first the lower parts on the deck, but we'll see, I'm taking seriously on my mind your reffering recommendation. Thank you again!! Stergios
- 1,144 replies
- snake
- caldercraft
In the middle of the summer a point for debating...: to glue or to not glue to the deck the lower parts (lower-mast) of the fore- main- and mizzen-masts? I've prepared and painted the lower parts of the masts as appropriate but I do'nt feel so sure about how to proceed.... What's the best next step? Gluing the lower masts to the deck, adding & gluing the upper parts to the lower parts of the masts or starting the shrouds bilaterally without gluing the masts on the deck? If you're there, away from the beach, I'm waiting your experienced opinion/recommendations. Thanks a lot! Stergios
- 1,144 replies
- snake
- caldercraft
...well, following Jason's and Jim's log, I see it is the front view...
- 1,144 replies
- snake
- caldercraft
Hi snake-mates, hope to find you home... Could you please help me: this is the front or the rear side of the mizzen-mast crosstrees/tressletree complex? Thank you in advance! Stergios
- 1,144 replies
- snake
- caldercraft
- 1,144 replies
- snake
- caldercraft
These side views showing the almost vertical and slightly posterior tilting of the lower-masts... I consider as acceptable this tilting all I need is to have the gunwale-mast top parallell to the water...
- 1,144 replies
- snake
- caldercraft
I've uploaded some pics showing my little progress of these days... The mainmast has a tilting tendency to the right, so I must find a mild way to restore this fault.
- 1,144 replies
- snake
- caldercraft
Summer days especially in Greece are so long.. You can't spend your time at the shipyard... Enjoy your summer-time!
- 800 replies
- snake
- caldercraft
This is a critical step. I'm trying to establish the right (parallel to the water) orientation of the lower top mast. I need your comment, what's the best choice: sanding with a file the cheeks and bibbs or placing a wedge up there between the walnut parts?
- 1,144 replies
- snake
- caldercraft
- 1,144 replies
- snake
- caldercraft
Following the manual instructions the week before I cut and glued Nr 31 walnut parts for the foremast cheeks... The right was to cut and glue Nr 32 Another wrong from the manual writter propably due to a beer's complication... The only solution for the main mast was to elongate parts Nr 32 (foremast) and simulate Nr 31 (main mast) cheeks.
- 1,144 replies
- snake
- caldercraft
Fore lower mast top, almost ready... I've used my dremmel to sand down and fit the vertical 1,5X1,5 rail to the small top mast holes...
- 1,144 replies
- snake
- caldercraft
- 1,144 replies
- snake
- caldercraft
Now, I'm about to start the assembly & shaping of the main mast and I know what to do to do it better. First thing in my opinion is to mark and paint the yellow to black border below the bibbs and second to drill and open at hte same level the cleats holes.
- 1,144 replies
- snake
- caldercraft
I'm referring to the fact that the main mast is'nt vertical/perpendicular to the deck. Anyway, the only thing that matters is to align the lower mast top parallel to the waterline, from this point of view I am ok... Thanks Jason
- 1,144 replies
- snake
- caldercraft
Thank you Jason, I've almost completed the top mast out of the model (pics to follow...). The foremast's lower edge is already dry-fitted/fixed in the respective hole/slot below the deck, with no chance of reamarkable changing of that slight posterior tilting... Do you consider that tilting/inclination as undesirable/abnormal? In my opinion is'nt so important. Thanks. Stergios
- 1,144 replies
- snake
- caldercraft
