Everything posted by drtrap
I'd like to say about the deck that I used carpenter's glue to fix the fittings.
- 1,144 replies
- snake
- caldercraft
Hi Vasileios I think that you deserve (as my first teacher) all the credits of my progress. Cheers
- 1,144 replies
- snake
- caldercraft
My personal "taste" of coloring (using dark-mate varnish) of the capstan and companionway. The walnut parts of the kit were too pale in my opinion...
- 1,144 replies
- snake
- caldercraft
I've decided to glue and fix the fittings of the deck before I start the bowsprit assembly. These are some pics of my latest progress.
- 1,144 replies
- snake
- caldercraft
Hi Jim I'm trying to "study" the photos related to your No 142 post but can't see anything. Have u changed their format or that's a technical error? Thanks Stergios By the way, about the anchor rope a question, what kind and size of line did you use?
- 412 replies
- snake
- caldercraft
This is a basic question for my snake mates. Following the plan No 2 I'm measuring a bowsprit outer length (from the front of the hull to the other edge, a>b (see my previous drawing)) of about 13 cm long. The length of the relative Jiboom is about 15 cm long. Do you kindly confirm the above dimensions to enable me to avoid any important mistake? Thank you. PS: For the anchor, have you used the standard natural 2,5 mm rope of the kit?
- 1,144 replies
- snake
- caldercraft
- 1,144 replies
- snake
- caldercraft
Small, quick update... I'm pretty happy with the arrangment of the bowsprit and the relative bracket...
- 1,144 replies
- snake
- caldercraft
I'm so closely following your log Jason and Jim's log too. I'll keep you informed. Cheers
- 1,144 replies
- snake
- caldercraft
- 1,144 replies
- snake
- caldercraft
Ooopppss. The inclination seems nice (or not ?) but the central edge of the dowel can not reach the "docking point" of the bowsprit bracket. Thinking to use a round file to enlarge the bowsprit hole or to file the central 1/4 edge of the dowel to pass it through that I've created in advance.
- 1,144 replies
- snake
- caldercraft
Thank you Jason. By looking sheet No 1 the distance a>b is 13 cm. When I'll shape and fix the central edge beneath the bowsprit bracket, I'll cut the dowel to a point as to keep that distance from the anterior front of the hull.
- 1,144 replies
- snake
- caldercraft
Thank you Jason. I'm trying to study currently the procedures needed for the bowsprit installation. I dont't feel very happy and that I'm on the safe side with it... It is supposed that to start I have to cut the 8 mm dowel at a length of 212 mm but I don't know whether this dimension is the right one in practise, especially when the angle of inclination of the bowsprit and its central edge placement (pinned or glued on the deck) can easily alter (?) the levers and the attachments of the other edge... So, starting to share a lot of question for this I'd like to ask you, did you encounter any initial problems with the length of 212 mm? Do you suggest as my 1st step to dry fix the bowsprit bracket and test/file the central edge of the dowel accordingly before I cut to length of the sheet No2 212 mm? Every help would be appreciated..!
- 1,144 replies
- snake
- caldercraft
I plan to leave for the moment unglued the gratings and the basic deck fittings and start to deal with the bowsprit placement and the bowsprit bracket fit. Is there any contra-indication on this by your experience? Thank you.
- 1,144 replies
- snake
- caldercraft
Now trying to figure out the "course anatomy" of the anchor rope. Looking at the drawings of the kit and the photos of senior mates I think that first step is to fix the 1st rope edge on the deck beneath the anterior grating (propably using those holes mentioned by Jason some posts above) and leave the other edge loose for tying the anchor many steps later.
- 1,144 replies
- snake
- caldercraft
That;s right Jim! I'll try to postpone fixing those fittings the later I can....
- 1,144 replies
- snake
- caldercraft
- 1,144 replies
- snake
- caldercraft
- 1,144 replies
- snake
- caldercraft
Just a couple of photos showing the deck gratings (unglued still) in place. For the mo I'm trying to find a "varnished way" to revitalize the mood/pale appearance of the walnut parts...
- 1,144 replies
- snake
- caldercraft
Hi Jason may I ask you about those two types of holes drilled on the desk and their importance? Have you created those holes as an in advance procedure for the next steps of the deck fittings fixing, for example to tie and "thread" the large rope of the most anterior gratting? As always, thank you. Stergios
- 800 replies
- snake
- caldercraft
It's time to go back to the deck fittings. Two basic questions before I proceed: have you glued only or pin-fixed the fittings and especialy the grattings on the deck? Have you applied any varnish on those fittings? Slightly coloured or uncoloured? Thank u in advance. Stergios
- 1,144 replies
- snake
- caldercraft
