Everything posted by AON
At first I just looked at the first photo and focused on the difference from the flag today Then I saw there were more photos but until I picked the next one I hadn't realised those were people unrolling it. Absolutely massive!
New use of an old construction material - posted 1802 DEAL: DEALS – Fir wood, of similar thickness to plank; PLANK – A general name for all timber, except fir, which is from 1-1/2” to 4” thick. Of less dimension it is called board.
Just had my 19th eye injection on Tuesday so I've not been in my shop since mid last week in a effort to keep fine dust out of my eye so it might not aggravate the recovery... and it seems to have worked. So I spent the time at my computer researching where all the little things go on the bowsprit and jib boom I made earlier. I have been frustrated to no end by all the contradictory information out there. My go to books (in order of precedent) are Ree's, Steels, The Masting and Rigging of English Ships of War 1625-1860, The Anatomy of Nelson's Ships, and Rigging Period Ship Models. I have saved a number of reference RMG model images ... having spent the morning going through about 170 of those on site as was recommended to me. I also searched some paintings and sketches but they didn't seem to tell me much. Possibly it is the recent needle trauma, or the cataracts... did I mention I have those too! Geeze retirement is fun. As I will be building her as I imagined she looked when launched there will be no dolphin striker, and I will have both the spritsail yard and the spritsail topsail yard as all is clear for the latter sail. I've checked my drawing gammoning alignment with my gammoning holes and they align very well but my holes are too short to receive the nine to eleven turns of 2-1/2" diameter rope, so these need to be elongated in the correct direction at some point in the future. Tomorrow I will start to mark all the lines on my drawing with references to the particular source and images so I do not have to re-learn it all again down the road... and all is in a binder to keep it together. Monday I will start sanding frames again... and in the next month or so make some cleats, saddles, hoops, yards, and a fairlead for the bowsprit and jib boom that are stored away. Here is the drawing I've made.
I have 1985 copy of The Anatomy of Nelson's Ships by C. Nepean Longridge. Page 188, second paragraph from the bottom refers to figure 119. There is no figure 119 .... there is a 118 then a 120. If anyone has an copy of this book that has figure 119 could you please scan it and send it to me. I will print it and insert it in my copy of the book. Thank you. Alan
I should have mentioned it is also in The Anatomy of Nelson's Ships. I've had my breakfast so the brain is starting to work.
Thank you all for the responses. My source : The elements ans Practice of Rigging and Seamanship - vol 1 - is dated 1794. This table suggests it is in ships of 100 guns down to sloops (found on pg 45) it is not mentioned again nor is it shown in any of the Plates diagrams of masts and yards for any size ship. (not that I can find this early in the morning)
I just discovered yesterday that there is a flying jib boom. It is not on many builds. Steels lists it for the 74 gun ship, but I've not seen it on any builds except the 50 gun HMS Leopard (1790). I've read an old post that states the flying jib boom and the jib boom are the same thing, and having seen it I know they are two different things. The flying jib boom protrudes beyond the jib boom, secured to the head of the jib boom with an iron clamp The heel of it rests against the bowsprit cap. I've no idea how that end is secured. I also have no idea if it is an optional boom extension, when it is added, or what determines it should be included. Seemingly only if a flying jib sail is wanted to be rigged... seems to be logical. Does anyone know more about this item: why, when, where used? Thank you in advance.
HMS Fly according to papers, she was in Antigua in January, notice of PRIZE published 5 March... still looking update: did a quick search through to July and no other mention of her
from the reliable Wikipedia: HMS FLY On 17 September 1801 Fly left Portsmouth as escort to a convoy for Newfoundland. She foundered and was lost with all hands off Cape Flattery, Newfoundland in January 1802.
Mounted the model on the travelling base. Used a heavier clamp at one end as a counter balance as I made adjustments to align the drill bit with the mark then clamped it to the drill press base. Drilled the holes. #29 thru, #15 1/4" deep. Set it on the build table and drilled thru the table. Made up lengths of threaded rod, chased the threads after cutting the lengths (borrowed my son's tap and die set for this). Installed the helicoil inserts as described earlier. Now it sets up and cures. I left one of the original wooden clamping bars on the table as I can set the keel to it/align to it, and it holds the plan in place on the table.
Life is like that, eventually you either are no longer needed or worse, outlast your usefulness (1802)
As a picture is worth a thousand words I thought I'd try to explain it another way. In the photo below I show the Helicoil thread insert (in a stepped hole) versus a hex nut (set in a customized pocket). I have also drawn in the rising wood (top), keel, and false keel (below) at the end of the block of wood. The hex nut and helicoil are buried in the rising wood. The hex nut is as thick as the rising wood so it necessitates the removal of a great deal more wood than the helicoil. In my mind it is cleaner and simpler. More rising wood is left in place. The frames glue to the rising wood... so it would be nice if some wood were there. The hex nut is entrapped and so cannot spin. With the tang removed from the helicoil it does not move. So both are equal in that sense. The hex nut has 3.6 threads and the helicoil has 7.
This one was mis-labelled as 7 July 1801 but when opened it was realized to be 24 Sept 1795 It has a special meaning for me, as I had spent 5 summers on Vancouver Island, and earned my sailing and pulling cox'n papers in my third summer out their.
Thank you Mike. I had looked at these and thought they were quite large a barrel diameter and then also to the OD of the cutting thread, and in some cases the length. I was hoping to minimize the material (wood) removal. My test worked, but I will need to remove the "tang" as if you continue to turn the rod after it contacts the tang the insert threads out of the hole. Of course there will eventually be a frame covering the hole so the rod will only thread in so far and have to stop. In my application, I used a somewhat backwards installation as I cannot cut the proper size thread in the wood (as I am a cheap ol' coote). Normally they feed in the same side as the screw or rod, but mine in in the opposite side to create the retaining shelf for clamping.
a substitution for HEMP cordage is discovered..... and the list of officers gets even more inflated. (1801)
Above is a threaded insert (aka helicoil threaded insert) Below is a blind nut. I think you are referring to the blind nut with the flange and spikes that have a much larger diameter cylinder (with the threads inside) than the OD of the threaded insert, requiring a larger hole and length removing more wood than I prefer. The flange on the #6-32 blind nut is too large for the width of my keel and would require filing. The thickness of the flange requires a spotface in the keel to get the top flush or buried. The spikes are just a pain in the behind. I was looking for something cleaner than the flanged/spiked blind nut, and cleaner than a standard hex nut that would need to be filed across flats to fit in a pocket that would need to be chiselled out of the top of the keel. I am attempting something different. If this does not work I will resort to the hex nut, that is quite functional, but ugly (and, yes, I know it will be hidden). And you, sir, are anything but thick.
TESTING the stainless steel #6-32 helicoil thread insert for mounting my build to the table and eventually the display mounting board. FYI: #6 refers to the screw thread diameter; 32 means 32 threads per inch. I learnt long ago that the full strength of a thread is developed in the first fully engaged 5 threads, everything after that is safety factor. When I ordered mine I made sure it was long enough to have at least 5 full threads... mine has 7. I decided to drill and thread a hole in an attempt to assist the insert into feeding into the wood. First I drilled a 9/64 inch (0.1406 inch) hole for a #8-32 tap. Now a #8-32 thread is a slightly smaller diameter than the outside diameter (OD) of the insert but I thought as it was going into wood I might be able to ease it in so it followed the 8-32 and cut it's own threads a wee bit deeper. That did not happen as the "wire" is very slim and so it deformed. I then tried feeding it in with it on the threaded rod and that did not work. If I had spent an extra $40 for the correct tap and proper holder for the insert I likely would have been successful, but I didn't think the extra expense was worth it for 4 holes. Luckily I purchased 10 inserts and only need 4 for the job. So next I decided to try by drilling a stepped hole. First I used a #29 drill bit which is slightly larger than the rod OD at 0.136 versus 0.132 inches and drilled through the wood. So the rod slips thru easily. Second I used a #15 drill bit and drilled down 1/4". The #15 bit is 0.180 inch diameter and the insert is 0.1785 inch OD. The next smaller bit would be too small (#16 at 0.177 inch). This created a step or shelf that the insert rests on when placed in the hole. Although advertised as 0.276 inches tall the insert is actually 0.232 inches tall so a 1/4" (0.25 inch) deep hole puts it just below the surface. My keel assembly is almost 1/2" tall. I then inserted the threaded rod and rub some good old petroleum jelly (Vaseline) on the OD of the rod threads. Then I screwed the insert onto the end of the rod. Then I cleaned up a bit of the petroleum jelly that got pushed out of the threads by the insert. I applied a thick two part epoxy onto the OD of the insert. The petroleum jelly is supposed to keep the epoxy from migrating through the coil of the wire and gluing the threaded rod to the insert. I then pulled the rod back into the wood block to draw the insert in and up to the shelf or step. I let that set for a while and eventually removed the threaded rod. Now it is curing. Later today or more likely tomorrow morning I will test that it is holding, does not spin. I will apply reasonable torque (a wee bit over snug) for the small thread. The end of the stainless steel threaded insert has a tang blocking the hole. This is used with the proper insertion tool to help thread the coil into a threaded hole. It is meant to be broken off after the item is installed. If what I just did works, I think I will leave it on as a stopper for the threaded rod. Below are some photos.
