Everything posted by AON
While I move ahead with my forward cant frames and the tree nailing of my aft cant frames to the deadwood, I want to complete my bowsprit. As I had made a number of rookie errors I thought I'd best get both my sketching and math down clearly on paper. I've made two bowsprits to date. The first was a quickly turned cigar shape on the lathe at proper dimensions to simply see the fit in the bollard clearance hole and determine my satisfaction with the diameter (posted earlier). The second was properly shaped on an Ed Tosti style board as he'd shown on his Young American build. This last one is not quite right so I will do it again. Practise makes perfect... or nearly so! To start with I must say I snagged a copy of an excel document entitled Masts and Rigging from somewhere. I believe it was this forum. I checked the properties and the author was Danny Vadas. I've found it to be a very helpful tool to cross check with. As I cannot see the formulae controlling the results in the cells I need to verify the numbers as best I can. The following explains the process. I am new to this so it also serves as my reference for later on as I will do more of this. I also snagged a copy of another excel document entitled Steels Dimensions by Y. Miroshnikov which is equally as useful. I must say that I found The Fully Framed Model Vol. IV by David Antscherl to have been very helpful because of the photos, plans and descriptions. The same can be said for Rigging Period Ship Models by Lennarth Petersson. They helped me understand what I was looking at or searching for. The following detailed explanation is quite long. I hope you do not mind, but I find the process fascinating. BOWSPRIT with CAPS, BEES and BEE BLOCKS As mentioned earlier I used REES's Naval Architecture (1819-1820), page 106, plate VIII for the dimensions, however he does not give much information regarding the Bee's and the Cap. I had looked at The Anatomy of Nelson's Ships (figure 116, page 185) but something wasn't quite right between this and some Vanguard kit builds I've been following. I needed to look deeper. Key dates: HMS Bellerophon was ordered in 1782, launched in 1786 and completed in 1787. This immediately suggests Rees might be a poor choice due to its date of 1819-20. I went to The Masting and Rigging of English Ships of War 1625-1860 by James Lee. All the information required is in Section 1. Mr. Lee agrees with Mr. Rees with regards to the ratio of the tapers of the bowsprit, but length and diameter differ in Appendix I ( Length = 0.6 x the length of the main mast = 104.25 x 0.6 = = 62.55 feet versus 64 feet; diameter = 62.55/3 x 1.555 = 32.3 inches versus 36 inches). Appendix II of Lee's reads HMS Valiant 74 gun 3rd rate Bowsprit was 36" diameter x 69'-5" long. Due to the scale of my build (1:64) a difference of 3.7 inches (at scale = 0.06") diameter is not at all noticeable, and 1.45 feet (at scale = 0.27") difference in length is arguable. As REES shows details I will follow his plate VIII as best I can. Mr. Lee suggests that looking down at the Bees they were somewhat scalloped fore and aft for the time period of my build. The Bees were 2-1/4 times the diameter of the bowsprit at this location (2.25 x 20 = 45 inches long); their breadth would be 2/3rds the diameter (2/3 x 20 = 13.3 inches wide); their thickness inside was 1/4 the diameter (1/4 x 20 = 5 inches thick at the bowsprit) and tapered to 4/5ths the thickness to the outside (4/5 x 5 = 4" thick outboard). The outboard edge tilted upwards by the thickness of the inner edge plus 1 inch. This would be 6 inches. This is all different than what was shown in The Anatomy of Nelson's Ships. I will be following Mr. Lee for the Bee's and Bee Blocks. Below the Bees are the Bee Blocks. They were 7/9 times the length of the Bees (45 x 7/9 = 35 inches long). They were half the width (13.3 / 2 = 6.65" wide) and 2 inches per foot of length in depth ( [35 / 12] x 2 = 5.83 inches deep). There were two holes in each Bee at one for each of the the foretop stay and the foretop preventer stay and one spare per side. These holes were elongated slightly fore and aft to better receive the stays as they passed through the Bees and Blocks. There were no sheaves at this time. What size hole do I need in the Bee for the Stay to pass through? If I know the size of the rope I can determine the hole size needed to clear. I went back to The Masting and Rigging of English Ships of War 1625-1860. In Appendix I it explains that the sizes of fore topmast stay and the fore topmast preventer stay are calculated to be a proportion of other considerations.... The topmast stay is 1/2 the size of the lower stay. The lower stay is 1/2 the diameter of the lower mast. The fore topmast preventer stay was 3/4 the size of the topmast stay. The foremast was the same proportions as the main mast. The main mast diameter from 1773 to 1794 was 9/10 inch per 3 feet of length. How long was it? In my time period the main mast length was 2.23 times the ships beam. The ships beam per the contract was to be 46 feet 9 inches (561 inches). 561 x 2.23 = 1251.03 inches (104.25 feet). The main mast diameter would be 104.25/3 = 34.75 x 9/10 = 31.3 inches diameter. The foremast would have been the same diameter. Now things start to not make sense to this novice. If the lower stay (rope) is half the diameter of the lower mast it would be 15.65 inches diameter! I think he meant size of rope which was the circumference not the diameter! The diameter is the circumference divided by Pi (3.1416). 15.65/3.1416 = 5.3" diameter rope. The top mast stay is half this 5.3 x 1/2 = 2.65 inch diameter (or 8.33 inch rope by circumference = 2.65 inch diameter) The topmast preventer stay is three quarters this or 2.65 x 3/4 = 1.98 or simply 2 inch diameter. I will make the holes 3" diameter (at 1:64 scale is 0.05" diameter = #55 drill bit). Since I'm all warmed up I may as well carry on with the Jib Boom details and get it over with. JIB BOOM I took the dimensions for my Jib Boom directly from REES's Plate VIII. The major diameter is 11" and the overall length is 51'-0". Only the heel end is octagonal in shape for a distance of 4'-4". The length differs from what is described in The Masting and Rigging of English Ships of War 1625-1860. Mr. Lee directs the length of the hex shape at the heel to be 3.5 times the diameter (3.5 x 11 = 38.5 inches). Mr. Lee also directs the length of the Jib Boom to be 0.41 x the length of the main mast (0.41 x 104.25 = 42.7 feet). This is a difference of 8.3 feet (1.5" at 1:64 scale). The diameter is to be 7/8 inch per 3 feet of length or 12.5 inches. Mr. Lee also gives some drawing details for the Heel Lashing Hole and Heel Rope Sheave. The slot in the Jib Boom for the Heel Lashing Rope Sleeve (sheave) is horizontal and the length of the slot is 1-1/16 x the diameter of the Jib Boom (1.0625 x 11 = 11.7 inches). The slot is located a distance of 1.5 times the diameter from the heel of the Jib Boom (1.5 x 11 = 16.5 inches whereas Mr. Rees locates this at 2 feet). The Heel Lashing Hole runs horizontally and is halfway between the Jib Boom heel and the slot for the sheave (8.25 inches). There is another sheave located at the head of the Jib Boom for the Jib Outhauler. This sheave runs up and down (vertically). Mr. Lee directs it to be located "a few inches abaft the rigging stop". For my time period the rigging stop was tapered back to a shoulder. Mr. Rees shows the horizontal heel sheave slot to be 18" long x 4 or 5" wide. The outhaul couldn't possibly be the same size as the head of the jib boom is so much smaller in diameter than the heel (7.3" versus 11"). In my novice opinion there seems not enough "meat" left either side in the boom to support it. To double check this I need to know the size of the Heel Lashing and Jib Outhauler ropes which will determine the sheave sizes. Mr. Lee directs that the Heel Lashing is the same size as the Bowsprit Shroud Lanyard which were the same size as the Gammoning which were 0.44 of the Forestay. The Lower Stays are 1/2 the diameter of the lower mast. The lower mast was the same proportions as the main mast... 9/10ths inch per 3 feet of length of the fore mast, which was 0.93 x the length of the main mast which I'd already determined to be 104.25 feet. 104.25 x 0.93 / 3 x 9/10 x 0.5 x 0.44 = 6.4 inches circumference / 3.1416 = 2 inches diameter rope. From Steels I find the sheave diameter is 5x the thickness of the sheave but in Lee's it is 4x; the sheave thickness is 1/10th more than the rope diameter; the breadth of the sheave hole is 1/16 inch greater than the sheave thickness; the length of the sheave hole is the sheave diameter plus one rope diameter in Steels whereas in Lee's it is 1-1/3 x the sheave diameter. A sheave for a 2 inch diameter rope would be 2.1 inches thick x 10.5 (Steels) or 8.4" (Lee's) inches diameter. The sheave slot would be 2.163 inches x 12.5 or 11 inches. For the Jib Heel Lashing on my drawing I find a 10.5 inch diameter sheave does not suit my 9.5" across flats hex shaped heel of the jib boom. I made my Heel Lashing Sheave 8.4" diameter and the hole 2.2" x 11". Search as I might I cannot seem to identify the rope size ratio for the Jib Outhauler. The Mast and Rigging spread sheet (which has proven to be reasonably accurate up to now) suggests the Spritsail Yard Halliard and Running Lifts and the Fore Trisail Outhauler are all 1" diameter. As these are all in the same general area it seems reasonable for the Jib Sail to be similar. The sheave for a 1" diameter rope would be 1.1 inches thick x 5.5 or 4.4 inches diameter. The hole would be 1.163 inches wide x 6.5 or 5.7 inches long. Again the differences are those between Messrs. Lee and Rees. I will use the 5.5 inch diameter sheave and the 1.1 inch wide x 6.5 inch long slot for the Jib Outhauler. This fits nicely in my drawing. PDF attached! Also a couple pictures from my second Bowsprit. **** This exercise took a number hours over just as many days. I needed to walk away and shake my head clear a few times, review a number of books and re-read passages many times. This is the kind of stuff that cranks me up and gets me jumping for more! Yes I really enjoyed it that much. Bowsprit + Jib Boom.pdf
Also, I made a quick bowsprit at about 37+ inches diameter (Ree's says it is 36" diameter) to see how it would look. I am not happy with the gap and so will make it a little larger. No one will be taking a caliper to it! Then I researched the finished shape of the cap end of the bowsprit to accept the BEES and made notes. I'll be making a good bowsprit soon enough to have a change of pace... after all they say a change is as good as a raise!
Hope everyone is having a great St. Patrick's Day! I completed the installation of the hawse pieces moments ago. Also completed the installation of the chocks at the head of the aft cant frames. Time to start on the forward cant frames... not today though.. because my name is Uá Niáll and it's St.Patrick's Day!
Okay... I admit I have never cast anything for models. Industrially we used sand. Yes it was a special casting resin but it had no "give". It was solid. What if you built two boxes. One as a skin for the mould. The other twice as large. Put a couple inches of sand (clean dry beach sand) on the floor of the second. Put your mould in the first box then put the first box centered in the second and on top of the bed of sand. Then pack sand all around the first but inside the second. These could be reused over and over again plus any spillage is on the sand. Just a thought.
Pat I appreciate your suggestions. There is always the plan B that I spoke to my wife about at lunch... make the bowsprit a hair larger in diameter. I will make a test bowsprit to see what it looks like with and without the leather layer. I have coloured paper to simulate the leather for the test. Thank you... I learnt something from you today.
More of those moments then I care to admit to! My back is back to normal, thank you for asking. I hope you are back on your feet again. Only people with this infliction understand how debilitating, aggravating and painful it really is. Back to this leather capping on the head of the stem post and apron. Would this have been tarred? In my searching the only thing I can find was two references where they say the gammoning was covered in leather and tarred to protect it from the water and chaffing.
Steven I thought long and hard on how to respond to your especially kind post. Thank you! 😊 But as Wayne and Garth said to Alice Cooper... I (feel) am not worthy. Druxey and Pat Regarding the leather puddening strip on the head of the stem post. If either of you have a reference such as a picture I'd feel better about how I install it. I confess I haven't looked yet but will be searching myself today... but first I have an appointment at city hall. Alan
I failed to report an error I had made... but caught before damage was done. While measuring the bowsprit from the plate in Ree's I failed to notice the section views directly above with dimensions! See post #817 above. These identified the bowsprit to be 36" diameter not the 3'-5" as I had measured with my dividers against the provided scale. The diameter of my clearance hole is ever so slightly oversized (0.60" versus 0.563").
wow! very impressive.
My back is much better today, just in time for our club meeting tomorrow at Lee Valley Tools in Niagara Falls. I wonder if I'll find any new toys there this time? After pondering on it a while (and watching Kenny's video again) I decided on a method to sand the 3'-5" diameter bowsprit clearance hole in the stem post head and bollard frames. I over thought it, trying to be more accurate I realised I over thought it and my method didn't work so well so it was abandoned mid stream... as will be explained. First I had to determine the angle of the bowsprit and so brought out my trusty parallel ruler and a protractor. I found the angle was 30°. I was going to sand a taper on a dowel from a diameter under the width of the stem post to the finished diameter so I could rotate and feed the sanding plug through the assembly of bollard frames and stem post but in the end I decided to use an undersized dowel and wrap/wood glue a layer of sand paper to it. Next I layed out a scrap block of wood, drill a hole for the dowel at 30° and clamped this to the table. I thought I'd slip the dowel into the block which would help me maintain the angle, rotate the dowel/sand paper and sand the profile into the head of the stem post. The bollard frames were pinned through to each other near their foot so they could rotate. A clamp located near the top acted as a stopper so they would rest against it in the exact proper location when rotated forward. I could then open these up and holding/pinching with my fingers while rotating the dowel I'd cut the shape into everything. Well that didn't work. My finger pinching idea was not adequate... I needed gorilla fingers to hold it. The rotating of the sanding stick did not work as it gripped the stem post and caused it to twist the whole frame. I did manage to start a profile in the head of the stem post but it would wander. I abandoned the angle guide block and sanded with an in/out or forward/aft motion and this work well but I could not see if I was centred on the stem post head. I took an HB pencil and coloured the top of the post with graphite to darken it. As I sanded away the wood and graphite I could see the pencil mark width remaining and determine I was indeed on centre. I then swung one bollard post up and pinching the one I was able to start a groove in it at the proper angle. I marked the head of the stem post location onto the bollard frame and sanded it off the model and on the work bench. I repeated this for the sister frame. I then glued a second layer of sand paper to the stick over top of the first to increase the diameter., then repeated the sanding operation. Finally I glued a third layer and after the third sanding routine I was done. Following are some photos. The bollard frames are presently glued, pinned and clamped in place.
If only it would be so easy to "get rid" of it. I use to be able to set a clock to it then there was a period I almost forgot about it. Now that I have entered the "best years of my life" it has returned to remind me that I am it's bitch and shall submit to it's will... but I am too darned stubborn to give in. So we dance the dance. .
I've decided to follow REE'S Plate VIII as it provides more detail. (I am told REE's and STEEL's plates are identical) I'll need to turn down some 3/4" dowelling to make a 0.641 inch diameter sanding stick (including the thickness of the sand paper). This will also necessitate the sanding of a slight radius pocket in the inside of both bollard frames. Meanwhile I shaped and fitted the mating starboard hawse piece. I feel I may not post again until I have them all nearer to done as posting each step would be repetitive and might be boring. And spacer chocks continue to be installed back aft at the rate of one or two sets a day...
Spent an hour and a bit this morning working on the rough shaping of the next hawse piece on the port side. Dry fitted it and it looks darn good to me. I want to glue and pin the bollard frames in place but need to sand a radius seat on the head of the stem post (stem and apron pieces) that the bowsprit will rest on while I have clear access. I need to determine the diameter of the bowsprit at this location. Looked in Ree's Naval Architecture Plate VIII which is a diagram of masts, yards, and the bowsprit, and it measures 3'-5". Measured (for comparison) on Ree's Plates I and IV and I get 3 ft and 2'-9". Checked NMM plan J7795 (ZAZ6781) which is a diagram of the main mast and bowsprit for a 74 gun ship and it measures 2'-9". Measured the space between bollard timbers (which is the thickness of the stem post) at the head and it measures 2'-6". Now I need to make a decision.... I need to check what size dowels I have to make a sanding stick.
