AON
Everything posted by AON
  1. looking at photos I would have sworn they were bare wood. see below
  2. I attempted to draw a segment of a tube above the trunnion at both ends of the insignia at locations of known diameters. I then attempted to loft and cut using the two sketches and a 3D line connecting the two as a rail. My program (Inventor) does not seem to want to cut away with the loft command. With my second attempt... If I cut away a Rotated (tube) segment drawn on the XZ plane above the trunnion that is successful. As the trunnion is below the horizontal plane it is below the cutaway and is not touched.
  3. the other option might be to apply the insignia flat, protruding from the surface and then manually file or sand it round after printing. I was told that 3D printing is an open honeycomb cell structure below the thin solid surface so you might have to use some type of filler afterwards.
  4. Mark Every 3D CAD program is different. If your program will do it there should be an option to WRAP to a surface and you will be prompted to pick the surface. This is what it looks like in Autodesk Inventor...
  5. "too much time on my hands" ? If it hadn't be for me wasting an afternoon surfing You Tube I would have thought much about the sled. I started surfing because I just couldn't live with the sunken and too wide a gap shoe plate and needed to make a new useful one.
  6. exhaust??? it doesn't go any faster. I did however give some thought to hooking my vacuum hose to it
  7. I have a Mastercraft table saw bought from Canadian Tire a few years ago. It needed a zero clearance insert plate as the one supplied accommodated angle cuts and it also sat below the deck surface which caused me some grief. I made my new plate out of oak... good and hard and flush with the table top, and it has made a world of difference. I then made a Cross Cut Sled and added an adjustable stop block. To improve on this I mounted my old (never used again) vernier caliper instead of a measuring tape. The pin that locks the fixed end of the vernier is an old worn out drill bit. So a drilled the hole with a new one and I knew it would be a perfect fit. The moving side is locked to the stop block by a profile plate on one side and a rotating locking cam on the other. As an after thought I drilled another hole to keep the cam Allen Key in as I am sure I would spend 20 minutes or more looking for it otherwise. This vernier reads to only two decimal places and has an accuracy of only +/- 0.01 inches. This is fine enough for quite a few of my cuts. The saw can only be raised 1-1/2 inches for this sled so it will be used on small stuff. I did not invent this sled... I found a version on YouTube and made some small improvement.
  8. Thanks. It was the 3d program... all I did was draw lines and pick to wrap to the surface.
  9. Been there. Done that. 😉 Actually, I've done considerably worse.
  10. Why might the 9 pdr 7.5ft be longer than the 9 pdr 6.5ft image???
  11. the Admiral may have something to say about that
  12. I think it is a distributor. Possibly they meant "brass-ish".
  13. Found some stainless steel screws that were 3/8" (9.5mm) too long which worked out well after I cut the extra length off the pointy tip. This meant the amount that engaged (3/8") was all full form threads. Drilled the pieces and countersunk for the screw head. Assembled it all and the drawer would not pull out. I had to sand the thickness of the varnish off the frame under the sliding tray. Now everything works well. The new aluminium plates were installed, along with the felt foot pads... and a couple photos were taken. Next week (Tuesday) I take the 3D printing seminar and then I'll get my cannon printed up. You will hear from me after that. PS: Yesterday was our 43rd wedding anniversary.... today I turned a year older.
  14. here is the packaging and description. I purchased these quite some time ago.. but that doesn't explain it. Staining done. Two coats of varnish done to seal the base frame. Assembly today. 3D printing course next week... and a barrel shortly afterwards.
  15. I tried acetone, scrubbed, washed, swished... nothing. Let it soak... nothing. Me thinks Home Hardware "got some s'plain'n to do".
  16. Thank you Druxey but they are already blackened with a marker and installed. I had tried sanding any coating off the head and it didn't seem to help. I'll try acetone tomorrow just for the heck of it. Presently trying to figure out how to drill and pin two of the four trucks so it is fixed to the mounting board and doesn't roll around when she heels over when handled.
  17. After all the hullaballoo (of my own making) over figuring out how to blacken properly... it turned out to be very easy. I set up a work station, in the kitchen, on the counter, window to one side cracked open, stove overhead exhaust fan to the other side and turned on high. One small container with cleaning solution (drop of soap and ammonia). One small container with hot water and baking soda solution to stop the process. One large container with clean hot water to rinse parts off in after treating. One small container with hot water and a small amount of crushed rock liver of sulfur mixed with a wooden stir stick. Set this on my abandoned coffee mug warmer. Pair of latex gloves and tweezers. Cleaned, rinsed and dried the parts. Picked each part up with tweezers and swished (stired about in the solution while holding the part with the tweezers) them in the LOS solution for 5 seconds. Took it out and it was turning black. Did it again quickly... then once more and then into the baking soda solution... swished it about. Then into the clean rinse and done. Repeated this for every part. The copper blackened very quickly. The brass was a problem. I swished and waited and swished and waited and nothing. I let it sit for quite some time (20 minutes) and nothing. After 33 minutes they seemed to be dulling abit.... but it was wishful thinking. After 50 minutes I told myself to stop. I am thinking they are calling these brass but possibly they are not... the packing reads: "solid brass". As you only see the head of these I have decided to blacken them with a black permanent marker.
  18. Went back to the engraver's and admitted to my mistakes. Asked if he had an idiot's discount. Got a call today to advise they were ready and I could have the two for the price of one. Sweet
  19. The poplar sub-base was just stained with a Minwax Penetrating Stain #260 - Pickled Oak to bring out the grain but keep the clear unfinished look. It is presently drying. A clear sealing coat of Varnish will be applied afterwards. The MDF will be varnished only. The sub-base will then be screwed to the underside of the mounting plate from below and felt pads will be added to protect table tops from any scratches. Meanwhile I've done some more research into using lump or rock form Liver of Sulphur (LOS) that I had purchased and used once before about a year ago blackening the staples on the keel of my ship build. That attempt had flaked off but fortunately I liked the end result. I'm guessing I possibly did three things wrong back then: too strong a mix of LOS to water, too cool a mix when the blackening process took place, and too long a soak in the mix. The following PDF is a summary of the instructions I'll be following. I have also included a MSDS for LOS. I will be doing some practise runs on copper wire and brass nails before I commit to blackening the pieces to be used. This will happen tomorrow. How to Patina Copper and Brass.pdf MSDS_LiverofSulfur.pdf
