Hi All,
John (AKA Jim Ladd) suggested in another forum (Metal Work) that if I was crazy enough, I might want to try to use a jeweler's tap and die. Well I went ahead and picked this up on E-bay for not a lot of $:
I've played around with it with some small success. Now....can any one help me use it correctly? Cutting threads is pretty straight forward and easy. I was even, after quite a bit of trial and error, able to tap a hole which fit the threads. My question is basically if there a way to determine the size hole to drill for the tap? I would assume it would be the inside diameter of the thread, but how do I figure that out. I'm hoping there is something simple which has to do with the corresponding holes in the die, but right now that eludes me.
Best,
John
PS. I tried it out tonight and came up with this:
The bolt head needs to be filed down a bit but the other end actually screws into the loop.
Regardless, if any one has any pointers on how to best use this tool, I would appreciate it. Thanks.
John
Edited by Landlocked123
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
http://en.m.wikipedia.org/wiki/List_of_drill_and_tap_sizes
When cutting the threads, go slow. 1/4 turn in, 1/8 turn out. Go slow. Use cutting fluid. Not sure if I mentioned it, but GO SLOW! You will break taps.
Edited by justsayrow
Currently building: Model Expo AMERICA, A/L KING OF THE MISSISSIPPI
Completed: Mamoli Victory cross-section, Revell LSM (Plastic, in memory of Dad), A/L SANSON tug, MS Longboat (awesome model Chuck!), Dumas 1949 Chris-Craft 19' Racing runabout, A/L SWIFT, MS ELSIE, Constructo ELIDIR (now LOUISE), Midwest Muscongus Bay Lobster Smack, Amati 1:80 Yacht ENDEAVOUR, Mamoli CONSTITUTION cross section, Revell VIIc U-boat (1:72 plastic), lotsa other plastic ships
Next up: who knows - there are too many to choose from!
Hi
I was taught that the hole for the tap should be the minor diameter of the thread plus the difference between the major and minor thread diameter.  Hope that helps.
My advice and comments are always worth what you paid for them.
These charts are correct for good mechanical strength.  On a model you do not need that strength.  You will have an easier time of it and break fewer taps if you use 95% of outside diameter.  In other words you just need to cut enough of a thread so the screw does not fall out on its own.    And as justsayrow says' "GO SLOW".
Bob
Edited by Cap'n'Bob
Current build:  SS_ Mariefred
