HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
FRIENDS,
Well as my adventures in getting my shop together. One big issue with me as is with others. Is an area for your model to be built. But you also need an area for your plans. I have seen others will have their plans under glass and their model on top. Others build a drawer and they slide the drawer open, then close it to get close to their project to work on. Some have them pinned on the walls. So this was one big issue I really had to think things out. So I had so many ideas running through my head. Until finally I found one that would work for me.
   I JUST NEED A DEDICATED AREA FOR MY PLANS FOR RESEARCH, INTERPRETING, ECT.
  1.  I needed something I did not have to worry about fitting my model and plans in the same area. But still had them close enough so all I had to do was turn and there they are.
  2.  At the end of the day roll them back up and put them away. When I’d rather leave them out.
  3.  When I take measurements from my plans I much more preferred to be standing and have the plans basically on the wall. I just think I take better measurements rather then stooping over plans that are flat on a table.
  4. But I also needed to have them laid flat to see if my new part fleshly made matches the plans.
   5. And one really big issue. Leaving my plans out. But not in the way when doing other things around the house.
   6. I also hate to waste space. I like to use every bit.
   There are other reasons but too many to mention. But I hope you get my drift….
So I came up with my “TWO-SIDED PLAN TABLE” or “TWO-WAY”
post-1053-0-04447900-1434945674_thumb.jpg       post-1053-0-63108100-1434945685_thumb.jpg    post-1053-0-68493200-1434945699_thumb.jpg
post-1053-0-55968300-1434945711_thumb.jpg      post-1053-0-42384600-1434945723_thumb.jpg      post-1053-0-92574700-1434945733_thumb.jpg
post-1053-0-28883200-1434945743_thumb.jpg     post-1053-0-44496200-1434945753_thumb.jpg
When the table is down I can also pin a 3rd plan to the wall. No more switching from plan to plan most will be dsplayed for my use.... So my shop is getting there.
MARIO
Thank You all...
Mario
:piratetongueor4:  :piratetongueor4:
"Each of us is a mixture of some good and some not so good qualities. In considering one's fellow man it's important to remember the good things ... We should refrain from making judgments just because a fella happens to be a dirty, rotten SOB(biscuit) ;) "
My Builds....
BETTEAU WAR OF 1812     BOUNTY LAUNCH(bashed)    CHESAPEAKE BAY FLATTIE
THE SEA of GALILEE BOAT   VICTORIAN STEAM LAUNCH(bashed)    HOWARD CHAPELLE's CRABBING SKIFF
LADY KATHRINE 1812 SCHOONER
That's a great idea, Mario.
Great idea, Mario
Jack
Current buildUS Constellation
Thanks for likes and the comments my friends.
Mario :D
Thank You all...
Mario
My Builds....
