It seems that Blacken It will no longer be available.  I was wondering what other members used and which they favor.
Richard
Richard
Member: The Nautical Research Guild
For Brass, try Birchwood Casey Brass Black - usually available through gunsmith type shops and very good for brass. Or you might try Jax Pewter Black - usually available through jewellery supplies shops. The latter seems to be suitable for a wider range of metals, including white metal castings. I've just started using it and have been pretty happy with it.
For Copper, try Liver of Sulfur (LoS) - get the gel version. The advantage of LoS is that it can be used in situ, without straining the surrounding timber.
Birchwood Casey is also available on EBay.
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
JAX Chemical sells a product called Pewter Black that blackens brass, copper, and solder, and has even blackened the ferrel on the paintbrush I use to apply it.
http://www.jaxchemical.com/jaxshop/shopexd.asp?id=129&bc=no
JAX GREEN PATINA also does a great job when applied to copper plates - gives an authentic look for those who do not want a bright 'copper' finish on a hull.
Hornet
they (Bluejacket) also sell a Brass Browning Solution which I used on their copper plates - looks fantastic!
Ulrich
