Hello everyone!
For my current model, I need parrel beads the size around 1/32" or 0.8 to 1.0 mm. I have searched this web site, the internet and went to the lokal hobby store (Michaels) without satisfying results. Does anyone know where to purchase or how to make beads this small? Any help is greatly appreciated.
Kind Regards
Ulrich
Try a sewing shop, i.e. Joanne's, Hobby Bench.   Folks who do bead work and some jewelry may use beads that small.....last ditch effort might be Bass Pro Shop or Cabela's fly making gear.
good luck
Tom
While at Michael's you should have asked for "seed beads" they are the little glass beads that are made into bracelets and such using a loom.
Bob
Current build:  SS_ Mariefred
On a recent build, drilled through the centre of a small diameter dowel using my drill press and then turned the dowel down to the desired diameter using sandpaper on my lathe. I then cut the parrel beads to length and carefully sanded the ends. It was fiddly but worked well. The beads were around 1.5 mm in length but could be made even smaller. See below
Alternatively, you can buy beads in a range of sizes and colours from sewing shops. See below.
Edited by hornet
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
I needed 1.5 mm, and did not succeed in finding a shop selling beads that small.
I used a clay used for beadmaking (soft clay that hardens after baking it in an oven). i drillen holes of the desired measure in a wooden strip, smeared the clay in the holes, used a piece of thin copper wire to make a hole in the bead, baked it. (While still in the wooden strip) after baking, i used the blunt end of the drill to pish them out of the strip, did some founding of the corners using a bit of sandpaper.
It worked reasonably well, although Idon'tthink you can get much smaller than 1.5 mmusing this methodl. I have also seen peaple using magic sculpt or something likethat to make small parrels.
Jan
Edited by amateur
Thanks for all the advise and tips. I don't have a lathe to turn those beads from wood (which would be my first choice).  I will try to use the method, Jan describes, using clay. To round them off, I will run them in my block tumbler and see if that works. I'll keep you posted.
Thanks again,
Ulrich
Ulrich, did you make your own block tumbler or did you buy one? If bought, what type is it and what is your experience? The reason I ask is that there was a long discussion some time back about block tumblers and the difficulties of tumbling small blocks.
Thanks,
Tony
Ulrich, because are only using sandpaper to reduce the diameter of the dowel, you may be able to fix the dowel into a collet after drilling it out and sand it back using your hobby drill clamped in a vice. I am assuming that you have a hobby drill that uses some form of collet.
Hornet
Tony,
I made my own some years back using a can with a top (english candy). It is somewhat primitive but it does the job well on blocks, not so well on the wooden parrel beads, when I tried to reduce their size.
Regards,
Ulrich
Thanks, Ulrich. I've often thought of making my own. Perhaps I'll get round to it this time!
Tony
Hi, you'all
a short update on the issue of parrel beads: I did purchase a bunch of toho beads but it turned out their holes are too large and that does not look right. My friend and mentor from the HRSMS (Hampton Roads Ship Model Society) pointed me in the right direction: take a hardwood dowel (I used holly), pull it through a draw plate to obtain the desired thickness, drill a small hole in the center (don't drill too deep, you might get off center), than cut it to the desired length with a sharp blade (#11), rolling the dowel against it to avoid pressure which could deform the dowel. I also made a small jig to get the same length for all beads. After that, I run these beads for a few seconds in my block tumbler to round their edges. This results in a bead not exactly round but slightly cylindrical. Dipping them into some wood oil will give them a "yellowish" color, same as boxwood (I think). The beads I made are slightly less than one mm in diameter and length which I think is appropriate for a 1/8" scale.
Happy modeling
Ulrich
Edited by ulrich
Thanks for the update, Ulrich. Sounds good. How about some photos?
Tony
