Nice work Chap!!
I Esp. like the Brass Hinges on the Companionway Door.
Nice touch.
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
After you tied them did you add a little glue to keep them secure?
Derek
If you want to build a ship, don't drum up the men to gather wood, divide the work and give orders. Instead, teach them to yearn for the vast and endless sea
Antoine de Saint Exupery
Current Builds
Bluenose - Model Shipways - 1:64 Scale
Fair American - Model Shipways - 1:48 Scale
HMS Winchelsea 1764 - Group Build
On Deck
Guns of History Naval Smoothbore Deck Gun - 1:24 Scale
Finished Builds
Mare Nostrum - Artesania Latina - 1:35 Scale
Guns of History Carronade - Model Shipways - 1:24 Scale
Thanks Chap,
Just giving credit where credit is due!! :)
You'll be finished very soon by the looks, I reckon this deserves a good Cabinet.
Cheers....HOF.
Edited by hof00
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Your tool boxes are amazing. Did you make them?
Derek
Current Builds
On Deck
Finished Builds
Very impressive.  I stand in awe.  However, I think I'm ahead in the build and might just beat you  :dancetl6:
Derek
Current Builds
On Deck
Finished Builds
Yeah you right.  Sitting back right now and enjoying a cold pint.
Derek
Current Builds
On Deck
Finished Builds
Looks really good Chap,
Brings back a few "Fondish" memories. :)
(Did you "Pin" the Fish Boxes on? (God knows why I did, probably fixated with the What if I need to do Maintenance...." ))
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
fish boxes just temp at the moment still have to visit the sand and paint department think I will ca them in place
so many logs depict the two top ones slightly out of place think im a wee bit to ocd for that mine will be nicely stacked
Stack Away Sir.
The top ones on mine were "Canted" to add something.
(Careless Fishermen perhaps?)
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
finish applied to fishboxes I have build the trawl doors however they are having finish applied at present so I have completed and rigged winch gallery
as the build begins to come to a close there will be no more parts to make I have included a pic of left over parts
I'm going to miss watching when you are all done with the Mare!  Such a great job and a useful build log to document your work.  Back to the Bounty?
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
Very nice - I'll look forward to your finale!
Doug
Hello all bit more final touches completed
ive done some of the winch lines and various ropes
as for the trawl doors im not satisfied with the look of the 2mm brass surround i have decided to remake these using one of them i removed the brass and added 3mm to the bottom and 3mm to the side then i was able to use this as a template to create two new doors 1mm shy of the door with fitted brass wire i will next attach 0.5mm brass all around doors  and see how that looks
Steve,I think I get the rope coiling jig except what is the purpose of the paper?   I presume as well that getting the finished coils off the base board wasn't a problem - not glued down?
I can't figure out where your trawl doors are installed on the boat.  Where do they go?  They look pretty awesome by the way.
Doug
Hi Doug the photos seemed to come out the reverse of how i posted them try looking at them from bottom to top the paper is infact doublesided tape used to stick the line to the board when wrapping
the trawl doors are the strange looking device the winch operates
I figured out the reverse order of picture but missed the two-sidedness of the tape!  Thanks for the explanation.
 Now I see the trawl doors on the box photo on page 1.
Doug
Steve, I noticed on my kit that the little pulley frame that the sliding doors sits on is mounted one way in the instructions and another way on the box cover. Did you have the same problem, and if so, which way did you mount them.
Looking great by the way.
Derek
Current Builds
On Deck
Finished Builds
I must have overlooked that particular post because I referred to your build log constantly.  I made it like the picture on the box.  I wish I hadn't now because it looks a bit off but it will be our little secret.  Just like the beds that will never be seen  ;)
Derek
Current Builds
On Deck
Finished Builds
progress so far on the Mare Nostrum the last part of the build I have found frustrating with the trawl doors
the instuctions call for 4 brass pins to be shaped and fitted tied together with a silver wire the first door I did I was pleased with however trying to recreate this with the second has so far took ten attempts and to date im not happy so will carry on trying to replicate the first.
and for the border of the doors they call for a 2mm brass wire to be fitted I have tried this but not happy with the result I ordered some 0.5 mm brass plate in the hope I could rip 2mm strips to use as the surround however all this has resulted in is I now need to order a new blade for my proxxon saw
I remade the doors to the size of original includeing 2mm brass wire so if I cant figure out how to make 2mm x0.5 surround I may just use the doors without brass surround
Wood hath its advantages doesn't it.
you'll get it Steve - just a small bump in the last stretch of road!
Doug
thanks doug the brass work has definitely been a challenge I have no experience with brass or soldering and perhaps this should be an avenue I should explore I welcome the new challenges and will not let the model say complete until I feel it is COMPLETE
