Hello Les here. I made a boo boo on my current build. I followed kit instructions for the build, got ahead of my self and didn't put any bracing below deck for the masts. ?%X#*. Now I may have a big problem. Any ideas on how to secure the masts below deck? Thnx Les.
If I had no other choice because the hull is completely finished and also the deck, I would use heavy duty clay, placing the mast and wait for it to dry..
Completed.... Charles W. Morgan,Sea Horse,USS Constitution,Virginia 1819,San Fransisco II, AL HMS Bounty 1:48
L'Herminione 1:96
Spanish Frigate,22 cannons 18th C. 1:35 scale.Scratch-built (Hull only)
Cutter Cheefull 1806 1:48 (with modifications)
Current Project: Orca (This is a 35" replica of the Orca boat from the movie Jaws)
Another way would be find a small pin (sewing type).  Drill a hole in the bottom of the mast and put in the non-sharp edge of the pin (cut it down to length but not the point).  You woudn't need much of the pin sticking out of the pin to poke it gently into the keel/false keel.  CA it in place.  This would work if there's only one deck.  If there's two decks, then a bit of clue on mast to secure it to the decks would work.
Your rigging will secure it in place.
PROWE
If someone says something can't be done, it only means they can't do it.
Building:Shipyard - HMS Mercury card madel
Completed Builds:
Wood Models; AL Bluenose II 1989, Corel Toulonnaise 1995, Corel Flying Fish 2000, AL Scottish Maid 2005,
Sergal President 2010, Mamoli Beagle 2011, Corel Eagle 2013, Mamoli Constitution Cross-section 2014, Victory Cross-section 1/98 by Corel 2015, Occre San Francisco Cable Car 2018, Model Shipways Armed Long Boat 2021
Card Models
Christmas Train by PaperReplika 2012, Yamaha DSC11 Motorcycle 2013, Canon EOS 5D Mark II 2014, WWII Tiger I Tank by Paper-Replika 2014, Wrebbit Mercedes-Benz 500K Roadster 2014, Central Pacific no. 60 Jupiter card model 2015, Mirage III 1/30 converted to 1/33 card model 2017, TKpapercraft 1912 Mercer 2021
