One of my favourite tools is the small proxxon drill press. The manual suggests every 10 hours of operation to lubricate the bearings but does not specify what oil to use. I emailed Proxxon and this was the reply:
The TBM 220 drill press may be lubricated with a wide range oils, so we do not recommend any specific lubricant. Sewing machine oil is absolutely suitable.
Maybe this will be of help to others. I am not sure what I will use, I think probably what ever car motor oil I can get my hands on.
Vaddoc
Motor oil may be to thick for your machine.  A lighter machine oil would be better.  A lot of different places should carry what you need.  The same type of oil is used to lubricate fishing reels, sewing machines, small motors and other light equipment.  Not sure if it is still available or sold in the UK if it is but the old standby household oil called 3 in 1 oil would be a good choice.  If nothing all else fails ask at a hardware store for light machine oil.
My advice and comments are always worth what you paid for them.
Well, I did a bit more research on the net. It appears that indeed 3 in 1 has been traditionally used but there seems to be some disadvantages. Sewing machine oil on the other hand seems to be a very fluid oil, some times fully synthetic, specially formulated for such purposes. I just ordered a bottle
I'd second the decision for sewing machine oil....key properties that make it suitable for this application are:
   1) Light in "weight" means it will penetrate bearings as needed.
   2) Non drying formulas typically are used for sewing machine oils....this keeps them from "gumming up" mechanisms
        of sewing machines and also any other similar machine that does not see strong side loads (like a drill press).
   3) Easy to obtain in small quantities.
If you were asking about lubricating oil for the spindle of a milling machine then you'd need a different oil that provides ability to lubricate under presence of side load....so if you use your Proxxon drill press for milling operations then we'll need to discuss a different option...although in reality I'd suggest against using any drill press for milling as it will cause premature failure of the spindle bearings.
This could be a really long discussion, but that's the crux of it....
Cliff Ward
Cary, North Carolina
USA
Just out of curiosity: I have the predecessor to this machine, purchased in the early 1980s. At that time it had ball-bearings, which of course would not be oiled, but greased. Did they change the bearings to plain bearings, which would need to be oiled ? This would be rather surprising, as one hardly ever uses plain bearings these days.
And, yes, I use 'sewing machine' oil for my small lathes and mills, which is what the manufacturers recommended at the time.
Edited by wefalck
it has ball bearings but they are not accessible. At the top of the spindle there is an opening that you pour oil through. I am not sure though if this is supposed to lubricate the bearings or the rest of the moving parts. I suspect the latter.
The sewing machine oil arrived and I put a few drops (may overdid it a bit) in the spindle. Very thin oil that gets sucked through the very small opening. The sound of the drill changed, it def needed the oil.
I don't know what the design of the spindle today looks like, but one should take care that no oil enters the ball-bearings, as this may dilute the grease there and could lead to early wear.
  • 7 years later...
thanks or this ,I just bought one of these and was wondering what oil? as usual all questions answered on this forum. Regards Frank😁
Ordinary 'sewing-machine oil' will do (as per the recommendation by PROXXON at the beginning of the thread). You only want to have the outside of spindle lightly lubricated, but don't want to get it into the ball-bearings.
Edited by wefalck
If you could get it, spermaceti oil would be ideal due to its stability and resistance to high pressure and temperatures - and it was traditionally used to lubricate precision machines ... but it has been illegal internationally for some time under whaling regulations.  Either sewing machine oil or clock oil are substitutes.  In the late 20th century, jojoba oil was discovered to be a better substitute for high-friction applications because it is even more stable at high temperatures.
Actually, lubricating the quill of the TBM is really a light application, neither high speeds, nor high pressures or temperatures are involved ...
