Stern framing....egad! Most of the pieces on this kit have been excellent. My stern frames were a bit warped, though. When I first had everything fitted, it looked about as straight as an eight year -old's mouth. I should have taken a photo then. After sanding and re-gluing some pieces, I have the following result. Better, but there is a slight curve aft on the port side. I am using "hope" as a method, and hoping it will come into line once I start paying planks. It is pretty flexible.
  • 5 weeks later...
All Hail to the wales! Sorry couldn't resist. Love Chuck's practicum.  So far it has not led me astray. However, I was a bit concerned when he starts Chapter 5 with a statement assuming. The builder has previous POB  experience......NOT this guy.  I did look at a couple of POB guides, but Chuck's instructions and photos are too notch, so forward!
Coming along nice...brings back memories!
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
As this is my first POB build, I think I have discovered a certain "zen" in planking. I am really enjoying the process. Don't get me wrong here, I suck at it am making copious mistakes, but it is totally taking away the stress. Also, I am using the hull itself as my "jig" , and bending planks to the hull prior to cutting them. You can see this with the top plank still damp from soaking. So far this has worked fairly well. I will probably be painting vs. Staining to hide some of the gaps and nicks. I was going to lightly sand the planks once in place to also mitigate some of the fitting issues.
Edited by Eric W
