I like using CA.  It is quick tacking and with arthritis it is difficult to hand clamp parts even for short periods.  My question is whether there is a Matte finish CA type glue.
Thanks,
Richard
Richard
Member: The Nautical Research Guild
I agree with Mike,  a flat top coat will kill off any shiny areas from the CA glue,  or you could gently scrape the area with a sharp blade  or light sanding, this often does the job on my projects.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Thanks for the help.  I will test a few finishes to see which works best for me. On another note, I thought I once read about a pva that works like thin CA.  You can set up the pieces then at the seam the pva will "seep" into the crack.  Anyone herd of this?
Richard
Richard
