One time I opened my box with this model and...closed...
realised I need to read too much books , before start build it... "intimidating"- new english word for me !!! :))) ,
Yes - fully agree, it is very complicated kit...and as I know,very interesting in assembling....
have You seen this build ?
https://www.segelschiffsmodellbau.com/t125f165-to-Victory-and-beyond.html
 guys,
just tried to make reverse translation from english to russian my posts...it looks like abracadabra of 10-15% of my written text
I'm very sorry for inconvinience when you are reading my "english" posts 🤪
Edited by kirill4
Yes I have read through this build in great detail. I am also watching/following several onging builds of this model and many older builds. My plan is to do the older original model with no mods, then do the second one custom. I'm not a big fan of the etched parts, I don't think they bring anything to the build, and they are extemly expensive, which adds to an already very costly model. That said the Dafi build log is massively fun to read and very informative. Dafi is clearly very talented. (I just want to add that, I think the etched parts are amazing and when I say they don't bring anything, they clearly add a level of refinement. I just meant, I think the kit is great as it is)
Edited by bosco72
On 1/10/2021 at 3:04 AM, bosco72 said:
I'm thinking of adding the Revell kit English Man O'war 1/96 to my collection. Does anyone know why the back mast was purposely leaning? Thanks.
It is the mast rake.  The following article may help explain it:
https://www.woodenboat.com/whiskey_plank/why-mast-rake
I hope this helps
Jeff
I hope this helps
Jeff
This is super interesting, as I have read through a couple of Revell English Man O'war builds, and there was debate on the raking being too much. I think it will be my next build, and Im OK with tilting the masts as the kit dictates, I hope maybe I can counter the crows nests, as tilting them also makes no sense.
Edited by bosco72
Good day,
Dear Bosco,
I don't  know why , but your stays , fore and main are fitted in wrong way... very wrong :)))
for example,there is no room for fore sail being left...???
Or You did it in purpose?
In such case just discard my comment as unimportant :)
Edited by kirill4
19 minutes ago, kirill4 said:
Good day,
Dear Bosco,
You are correct, great spot, I would have missed that. I'm not fitting the sails but I will make sure there is sufficient room as if the sails was to be fitted. Thank you so much.
Working on some cargo, to add a little depth and life to the decks. First covered in black acrylic to ensue all the tiny details stand out when painted. Will drop more browns on individual planks and greys on hinges and latches.
Edited by bosco72
22 hours ago, kirill4 said:
Good day,
Dear Bosco,
Hello, from images could you point out which is wrong, as I'm working roughly to the below image and the kit instructions, thanks. Also I'm not going for a 100% accurate recreation here, just trying to get in the ball park, as I learn about rigging, lots of reading needed. That said more than happy to know my mistakes.
Edited by bosco72
Good day,
Assembled model generally looks right , but masts are not strait anymore probably due to excessive tensions of the rigging...
There are more good pictures with clear details which You could use as guidance for making rigging
53 minutes ago, kirill4 said:
Good day,
Hello thank you so much for your feedback. It is always greatly appreciated and very important.
I have ensured there is only the slightest bit of tension to any of the rigging as was advised in an earlier post; anything excessive could snap the plastic masts. So I have used just enough to make the string taught and not sagging. What you could be seeing is the slight rake in the front and back masts that the kit dictates. Also I have purposly got the ship on a tilt on the stand dipping forward and leaning slightly to one side, so that the all decks are visable when viewing from the side.
Again, thank you for the feedback and thank you for the great images.
Thinking of adding the figures. Does anyone have opinions on this? Is it too much, overkill? Or does it add life and character? The build below is amazing, tells a story.
Edited by bosco72
Progress. 2nd image shows using scissor clamps to add weight to rope loops soaked with pva. A different methed found when reading from using a jig to mould the ropes. Doing the rigging has been my favourite part of this build so far. Painting and detailing a close second. Hopefully as time passes with further builds I will improve on accuracey and technique.
Good day,
Dear Bosco72,
Please advise, what is the purpose of this rigging?
Can't understand their functionality...seems to me there could be something wrong with arrangements...
All the best!
Kirill
49 minutes ago, kirill4 said:
Good day,
Dear Bosco72,
All the best!
Kirill
I'm not sure which part of the rigging you are talking about, if you are saying it is all incorrect then as I said; I'm OK with that. At this point, with this build it is serving as a test, a fun learning curve.
If you are actually asking about the string, it serves no purpose what so ever? It's string on a plastic model, it has no functionality at all. It's decorative?
If you want me to pretend it was a full sized sailing vessel; I would have to say, I don't know wat the exact function of each rope. At this point in time, I currently do not know enough about rigging a full sized working vessel. But I'm reading and I'm learning.
Do I want to undo and change my every mistake as I learn more, not really, I don't have the time, I work 50 to 60 hours a week, have 3 kids and do my share of running a very busy household.
This is my first model and I'm still figuring this all out, whilst trying to enjoy this process.
Hope this goes in some way to answer your question.
Edited by bosco72
Practicing whipping (common) and seizing, no glue.
What I'm struggling with, is the first couple of turns once you have both loops in place.
I'm using bees wax, but I don't see how this helps here. (I know it stops the string from being fluffy, I also find it works really well when making knots)
I'm sorry,
I didn't attach picture to my post, I thought I did it but actually  not ,sorry
I questioned about this rigging
