Greetings All,
Where to begin...?
I had intended to start posting my progress, but life got in the way.  However I first must acknowledge all other building blogs for the Lynx - they did help steer me in the right direction.
Shortly after I started, I had the bulkheads aligned with the keel;
and had begun planking:
Edited by Pchem530
Update
11 minutes ago, Pchem530 said:
Where to begin...?
Where do you want to begin? Unboxing? Starting the build? Already part-way through the build? It's up to you.
Current builds: Brigantine Phoenix, Vought SB2U Vindicator
First, my apologies - I am new to the log and am still fighting years of conformance to federal computer systems.
Second, my thanks to Chris for correcting my title, again see the first comment (I set it up as per my old job's requirements).
Finally, I had to unexpectedly close out the log and initially had trouble figuring out how to edit/amend the log (your system is much too user friendly and would never be accepted for federal government use - too straightforward).
That being said, after fits and starts, I continued with the first planking.  After playing with the plank bender (very useful for the transom), I decided to go with the "soak, pin, then glue" approach.  Initially I was using standard pins (look like thumbtacks) but switched to 0.020" nails (look closely and you might be able to see them in the later photos).  The advantage is that with the proper pliers, it was easier to push through the soaked planks, and reduced splitting them.  The disadvantage is that the brass is relatively soft and after several uses, they tended to bend or break.
By mid summer I had half the hull planked, but projects around the house diverted me.  When I returned in the winter I hesitated not knowing how to continue, being afraid to make a mistake.  However, after perusing this site, I decided to resume, starting from the keel up and started to make progress.
At the beginning of the month, I was about to complete the first planking (not as bad as I thought):
I have since finished the first planking and am ready to sand/fill/sand the hull.
At this point I would like to make the observation that to rely on one's "good eye" can be a mistake - the eye isn't as good as one's ego would admit.  Also, your first attempt will not be perfect (perfect is the enemy of good), but forge ahead - filler and sandpaper can correct for a multitude of imperfections.
Now, to my questions.
I have noticed a discussion on using traditional wood filler versus drywall patch (the pink wet, white dry material).  My experience with drywall patch (wall installation/repair - don't ask) is that it is easily gouged/scratched and may not make a good base.  Therefore I plan to use standard fill/sanding for the initial shaping, followed by using the drywall patch for minor blemishes.  Comments?
Also, should I wipe the finished first layer with urethane to harden prior to the second planking?
I intend to post periodically as I progress, with observations and questions as appropriate.
Again, thanks Chris (the site is too easy to use for an old federal employee).
By the way, after the first pictures, my wife (aka the "Boss") recommenced the black background to prevent distraction from the model.  This requires a certain level of photoshop to correct for contrast, but what the heck - she was right (again!!).
  • 2 years later...
It has been three years since I started this log, but building got sidetracked until about a year ago. Since then, I have finished the model, but would like to post steps where I made progress/encountered problems, and would like to acknowledge any of the multiple logs on various sites for their ideas.
The second planking went rather smoothly, but I did notice that if you are too aggressive using a hot plank bender, you can compress sections of the plank which would not spring back. However, since I planned to paint the hull, this was not an issue for this model, but lesson learned for future projects.
After completing the second planking, I placed the deck into the hull to see how the masts would fit. I immediately noted that the masts were perpendicular rather than raked as they should have been.
Comparison of the deck to the plans showed that in order for the mast holes to line up, it was necessary to trim about 4 - 5 mm from the stern. This allowed for approximately a 15 degree rake consistent with the plans, but also required that filler be put in the bow to provide for a base for the deck planking.
Lesson - the plans and the parts of a kit may not be exact, and care should be taken to get the desired results.
Yeah... I am building the same and I did not adjust the deck, I was wondering how I was going to get the rake, but assumed that it would become evident as I built it since it was clear in the plans and in Chapelle's book.  This will be interesting for me.
Current Build -
 Lynx 1812 by Mantua/Panart 1:62
Hi Peter.  When I placed the deck on top of the plans, I noticed that if I lined up the edges of the deck with the plan, the cutouts in the deck (mast and hatches) did not line up (should have taken a picture - sorry). When I lined up the cutouts to the plan, the edges of the deck did not line up (stern extended ~4 - 5 mm past the plan line. In order to get the rake, I trimmed the stern edge of the deck by ~4 mm so that the stern and cutouts lined up with the plan (had to fill in the bow with scrap/filler so that the deck planks have support). Hope this helps and keep it up - this is a good model to learn with.
Thanks, I’m past that point and didn’t think to check it against the plans. One of those learning things I suppose. What I did was drop the masts into the holes and make sure both sets lined up, I poured over the plans but somehow it just didn’t occur to me until later as those two sets just lined up so nicely.
Current Build -
Moving on, the next step was to bend the subdeck to conform to the hull. After reading various sites warning against delaminating the plywood, I used a more conservative approach. I dampened each side of the plywood, then placed it in the hull and placed weights (a brass block and removable weights left over from physical rehab) on top. Each night I repeated the process and after a week, the plywood conformed nicely to the hull without delamination.
Things then proceeded nicely according to the plans (minor sanding here and there), until it was time to add the chain wales. The parts supplied had extensions which would either have to be cut off or extend the wales away from the hull which did not appear to be correct. My solution was to carve square holes that aligned with the extensions thinking that this would also strengthen the joints. I cut the holes and installed the chain wales prior to planking the bulkheads so that the holes would be hidden by the planking.
After painting the hull (and adding pin rails etc.), the results were as shown - I installed the planking on the chain wales after attaching them to the hull to cover any gaps where the extension went into the hull.
At this point, thing progressed pretty much as the plans indicated, although it seemed as if there were not enough parts to complete the deck gratings. I lucked out since I saved trimmed ends and was able to splice parts together.
Next up, masts and rigging.
Masts and Yards:
The first issue I encountered was that the lower masts were made of 8 mm dowls, but the top blocks were drilled out for 7 mm. Rather than make the top blocks too thin, I sanded the masts down to 7mm, but only down to where the cheeks/crosstrees began, leaving the lower portion at 8 mm. This gave a better fit through the deck.
The second issue was with the chainplates. After playing around with the brass strips, wire, and deadeyes, I decided to purchase the chainplates (27 mm) online. I found some that I think actually look better than what was proposed in the kit.
Another issue was that the outrigger clamps shown in the plans had nothing to do with what was supplied or described. The plans showed metal clamps to be squeezed on the yardarms, but an addendum showed plywood clamps and indicated that the clamps should be made with brass strips. Not only that, but there were also insufficient plywood parts for all the yards and booms.
I decided to use the plywood parts (sanded and painted black) for the larger yardarms and use the brass strip (painted black) for the smaller booms. The yardarms ended up looking like this.
At this point, I tested how the masts would fit,
I'm so happy to be able to see your progress as I slough along behind you.  It looks fantastic, and I have to keep stopping myself from comparing.  I remind myself it's a first time for me and I will (hopefully) improve. It's great to have yours as a refence though.
I love your paint, and am considering following something like your example.  I have started, and was planning on following the plan's scheme of black, green waterline and white up to the fender rail.  I have looked at many pictures of Baltimore Clippers and the vast majority look like yours does, with white paint between the gunnels and the fender rail.  Also, a little paint and wood filler would cover a number of my sins. :)
I don't know how I messed up the portholes still.  I measured carefully, but the standoff for the chain-wales didn't fit on mine and I ended up having to trim them down.  It looks OK, but yours look much better.  I like what you did with the holes for the tabs, but that wasn't an option for me.
Anyway, thanks again for posting all this, it looks fantastic!
Current Build -
At this point I took a recommendation from Frank Mastini's "Ship Modeling Simplified" and attached rigging (backstays etc.) to the masts before stepping them permanently with the following results.
67.thumb.jpg.c45cc832a035a88dc3a8b7b53ab21253.jpg66.thumb.jpg.074589091079fd1a1492679693787b86.jpg
While this seems doable for a schooner, I question how practical it is for a full rigged ship like a clipper (next project).
After finishing the standing rigging, I worked on the ratlines. I ordered some thinner line as recommended by Mastini (and ordered extra line for the rest of the rigging since I was using more than the kit supplied). I tied each ratline to the stay using clove hitches since I found after experimenting that it was easier to adjust the tension/spacing between the stays. As I moved along, I put a drop of 50:50 wood glue on the knots to hold them in place.
When it came time to install the yardarms, I was uncertain the best way to hold them in place while rigging them. Some blogs recommended using a pin or nail to hold them, others recommended gluing them. I ended up using butcher's/kitchen twine as a temporary measure. The advantage was that the twine is fairly soft and wouldn't scar up the mast or yards, but "bit" itself to hold things steady.
Once I finished the running rigging and was satisfied with the position/angle of the yardarm, I put a drop of CA glue to hold it in place and removed the twine.
At this point things went pretty much according to plan with the following observations.
It is extremely useful to use any extra line to hold yards and booms in place until you can secure them with the running rigging. Once everything looks good, add a drop of 50:50 glue to all the knots etc. I also experimented with seizing lines as well as using the method described by Mastini (overhand knot, several turns and a drop of glue). I think seizing gives a better result, but it is not always practical. If you do use seizing, Do Not trim any excess ends until the everything is secure, and you have added the final drop of glue. Several times I pulled the block free while tightening the lines (usually at the end of a yard or somewhere else equally inconvenient) and had to reattach using Mastini's method. Finally, dampening the flag and using the wife's curling iron works really well to get a nice droop in the flag (so long as she isn't around).
Building the model also reinforced a lesson I learned in the past. If kit instructions say to attach Part A to Part B using Part : 1. The person who made Part A never met or talked to the person who made Part B, 2. Part C will be missing, 3. The person who wrote the instructions never assembled the kit or talked to anyone involved in making any parts, and 4. Once you have jury rigged or bought a replacement for Part C, that part will be found in the corner of the box or on the floor under the table.
Hopefully my next log will be better. Here is the finished result.LynxX.thumb.jpg.0e451a23b9458fb9964567e89b42e875.jpgLynxT.thumb.jpg.cd0c1c238b7745c77b61dca93596c5e8.jpgLynxY.thumb.jpg.e5067f7cd43c49cf3e8145cbcf00f6f0.jpgLynxE.thumb.jpg.becfda02ed4af38144045e89c9ca80a3.jpg
Until next time.
Gorgeous!  I hope mine turns out 1/4 as good as this one.  Thanks so much for posting this.  This seems to be a not uncommon kit, but other than the one on the front of the box, this is the first completed one I've seen.  I searched for pictures so that I could have a reference in the past and haven't been able to find much. Lots of folks seem to start this model but few complete it.
Current Build -
