Like all dories, it is built upside down. FIrst step is to wax the formers so the glue (hopefully) doesn't stick. Then they are glued to the building board.
Edited by MrBlueJacket
A little sanding to bevel the stem, transom, and bottom so the sides can lay on a flat surface.
Trim the first side, and add the other side, remove from building jig and sand to final shape.
Now for the thole pins. I'm making them from .020 brass rod. First, I cut them long and install them through the caprail.
Next step is to trim them to length. I'm using a 1/16" x 1/8" scrap of wood as the guide.
And here's the trimmed thole pins.
Did I say they are delicate? While sanding them, two handles broke off. This leads me to several choices:
1- get more lasered oars (advantage of working here)
2- only show 2 oars on the boat
3-get creative and find a way to hide the error
I'm deciding on #3. I think it will work.
That got a chuckle out of me. Advantage indeed!
Actually, there is a 4th option - re-cut the handles. But being so delicate, I didn't want to risk it. So my option #3 is to put the end of the oars somewhere where it is not easy to see that the handles are missing, like under a thwart.
