Need 1/2” by 3/64 and 1/2 by 1/16 or 5/64 basswood strips
Go to solution Solved by David Lester,
Hi Laggard,
Did you consider using a harder wood such as castello, Alaskan cedar, or some other rather than soft wood like bass? If you have to stay with basswood  If you have access to a band saw or table saw you can always cut your own from blocks.  Consider no plank is over about 30 feet long so even at 1:48 the block of wood need only be about 8 inches long.
Allan
24 minutes ago, allanyed said:
Hi Laggard,
Allan
Instructions call for basswood.  I screwed up the two provided pieces.  No idea how important the wood type is.  I have no access to power tools.
  • Solution
1/16" x 1/2" basswood strips won't be too hard to find, they have them at MicroMark as well as at Model Expo for example.  3/64" stock can be harder to find, however I believe they have it (as well as 1/16" x 1/2") at minaturemarketplace.com which specializes in doll house supplies. Hopefully that's of some help.
David
Current Build - St. Roch, Billing Boats; HMS Agamemnon, Caldercraft (on hold)
Previous Builds - Armed Virginia Sloop, Model Shipways; Constitution, Model Shipways; Rattlesnake, Mamoli; Virginia Privateer, Marine Model Co, restoration; Prince de Neufchatel, Model Shipways; Charles W. Morgan, Model Shipways; Pride of Baltimore II, Model Shipways, Bluenose, Model Shipways (x2); Niagara, Model Shipways; Mayfower, Model Shipways; Shamrock V, Amati; HMS Pegasus, Victory/Amati
