0.5mm (= 500,000nm) Battleship Yamato
Eq9dU_AUcAA2ssC.jpg.590ce6cdbff6261b55e3219bdb00c331.jpgEq9dU_BUYAAYUml.jpg.06e2c14bc0b2fcf9be13524a73a1f61a.jpg
Image source : https://twitter.com/hashtag/ナノ3Dプリンタ?src=hashtag_click
Method : Kind of SLA 3D printer
Material : UV-curing acrylic epoxy resin
Companies
https://www.optoscience.com/maker/upnano/
https://www.nanoscribe.com/jp/products/photonic-professional-gt2
https://www.optoscience.com/maker/upnano/pdf/NanoOne_DataSheet_jpA4_ver3_2008_L.pdf
Horizontal resolution : 170nm (=0.00017 mm)
Vertical resolution : 550nm (=0.00055 mm)
Bed size : 100 x 120 x 40mm
Weight : 124 Kg
I definitely want the 1,000 times higher resolution 3D printer, but the price tag is over $350,000. 😲
That’s fascinating. I imagine it costs a fortune. Depending on how strong the printed objects are, it does have relevance to modelling: for 1/100 scale I can print blocks down to about 2mm but anything smaller I.e. 6” blocks, are technically challenging. Nano 3D probably opens up a whole world of possibilities for models at, say, 1/700 etc.
Kevin
Current projects:
On 3/27/2022 at 5:47 PM, reklein said:
That is just nuts. I'm sure someone has found a use for such tiny objects too. Maybe in the electronic industries for printed circuitry eh?
Unlikely. As an electronics engineer, i can tell they are way ahead of this size. Chip technology uses photo etching and/or metal steaming-vaporising to build the circuits. They are really in nanometer scale. Nowadays a semiconductor in a chip is 5 nm wide, and now trying to reach 2 nm, but due technical difficulties (not the size, but the intereference between neighboring transistors: electrons can travel between them) those chips are not yet reliable.
I bet diagnostic and precision instruments industry who can use this level of accuracy in printing.
