  • 2 months later...
hi, so am planing to start this projekt before the winter (3-4mnd) i need to finished the pequot ship first....
but am starting to get wat i need for the first 3-4 chapter at start ,
my question ? is there a wood list ? to ripp the planks myself or do i have to by the wood finished ripped?
svein.erik
You can rip as you go or buy the completed wood package . I just cut my wood as I needed it. Chuck outlines pretty clearly what thickness you will need, If you’re cutting your own.
http://www.modelerssawmill.com/wood-packages.php
hi ,again☺ know my joureny begins .... after waiting for this build to start ,
i have order the 1/4 laser cut bulkhead set from Chuck , but i do have to wat for it.....😲
so ... am desided to plank the hull with boxwood and am also using the ayc for the dekk planking and many other parts
because there are many parts thats  is painted , so fore this am using the ayc kits from Chuck.
As i can see, Modeler's sawmill do not ship to Norway/Euro. so i have to get it from Hobbymill.EU
thats means the sheets is in metric so i have to cut it twice to make it to inch...
example: 1/4 (6.35 mm) for this i need 7mm sheet  then cut it down .. thats Europe...😉
there wil be some photos later lol...
svein-erik
svein-erik
Will hobbymill mill the wood to your desired thickness? I would inquire to see if they also offer a lumber package for the Winchelsea. I believe the owner of hobbymill.eu is also a MSW member.
yes  thee is a lumber package all milled ready to go, but the price is 314 euro for ayc and about 385 euro for boxwood +shipment and tax
if i get the sheets and mill my self the cost is about 90-100 euro ☺☺
9I received some boxwood from Hobbymill EU 20220411_182812.thumb.jpg.e000a894fbbd096e950f940256c69bd7.jpg
I've found it to be excellent 20220411_182744.thumb.jpg.877a8616fbb0c132de699b53968a1a16.jpg
along with Vahur customer services.
Hope this helps with your choice!
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
