HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
I’m getting close to finishing my first build:  the Model Shipways Banks Dory.
One of the last steps is the beckets.  The rope supplied with the kit is 2 mm beige jewelry nylon, which is roughly 2 scale inches (1:24) in diameter.
The pre-drilled holes are about 1 mm diameter.
2 inches seems like a very thick rope for lifting a small boat.
Question:  Should I drill the holes out or get thinner rope?  Or is there another option?
Edited by Mark m
Added photo
Yes, I thought the line was way to thick when I built the dory . I bought some 1 rigging line  because I  did not want to enlarge the holes  so much and then have the rope look out of scale.  I had to enlarge the holes some for the 1 mm line but, I think looks much better.  It is a small detail, but it is the details that add a lot to the model.  I think even a bit thinner line  ?0 .8 mm would have been fine.  I had a similar problem on the lobster smack. The line supplied was too thick to work well with the turnbuckles in the kit.
Current Build:  Sultana 1:64
Completed: Lowell Grand Banks Dory
                       Norwegian Sailing Pram 1:12
                      Muscongus Bay Lobster Smack
                      NRG 18th Century Merchantman Half Hull Project
That kit rope actually doesn't look too bad for once!
https://syrenshipmodelcompany.com/ Has some excellent rope.
My store https://ropesofscale.com/ has light beige and Tan Rope. 1mm or .8mm would work for that Dory. If you buy one bag from me the shipping is cheap as I can send it by a stamped envelope. That is until the post service catch on that I'm doing that 😁
Aha!  A rope expert.
What is the difference between cable-laid rope and polyester?
Im in the US, but will be in Canada near Toronto in about a month.  Do you have a physical store, or online only?
Cable-laid is for anchors on ships, you wont need it for your Dory. Polyester is the thread I use for making my synthetic ropes. I do have cotton rope but it looks a little rougher and fuzzy.
Online only.
2 minutes ago, BenD said:
Online only.
Ok.  I’ll contact you via your website and email to get details and order.
BTW - Syren store is currently down for maintenance, but thank you for offering that link as well.
Thank you!
  • 5 weeks later...
Finally got around to adding the rope from Ropes of Scale.
Looks much better than the kit rope would have.
What, if anything, should I have done about the fraying ends?  Real rope frays, but this looks excessive.DDEDB0F3-126D-43DA-815C-273BFC387AC2.thumb.jpeg.cfface78c3c41e1453adfeeac2edf8ba.jpeg
Polyester likes to go nuts. I do heat them so the rope doesn't unravel wildly when cut, but they do unravel and fuzz up when worked with. Id say use some CA glue or PVA and cut the fuzzy end off.
On real ropes you would add whipping to the ends of the ropes.
The frayed end in PIC 1 of post #8 doesn't look too bad.  Remember, this is a crappy @$$ed fishing boat, not a naval launch.  I'm not sure how much time they are going to spend whipping the ends of lines.  "Tie the knot and let's get back out on the water."
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
