Could somebody help a newbie ASAP, I am trying to find the location of a printable A4 sheet with the (dont know the name for it yet) the lined pyramid that you use to work out the hull widths tapering. Have seen this used on a few videos.
Thank you all
Edited by JDillon
Joe
If it moves Grease it if it doesn't Paint it.....
Current Builds: Occre, Polaris                                                          Shopping List: Vanguard, HMS Sphinx
                            Occre, HMS Terror        Vanguard, HMS Flirt
        Occre, Endurance
Completed Builds: 0
Hi JDillon,
I believe you are looking for a "planking fan". You will find it in the Articles Database (located on the topbar). Scroll down to the "Framing and Planking" section, it is in the article "Lining Off Your Hull Planking, Tutorial and Fan" by Chuck Passaro, one of the administrators here on MSW. I would recommend reading all of the articles and other tutorials before commencing hull planking as it is one of the trickier parts of a build.
Hope that helps,
starlight
Edited by starlight
@starlight the article link links back to this thread.  You may want to edit the link to point to the planking article.
The planking article can be found as you described via the Articles Database link you provided.
Edited by robert952
Robert Chenoweth
In the research department:
Nothing at this time.
Oops, how embarrassing! Fixed.
You can easily draw such a "pyramid" by yourself. Take a sheet of paper and along one edge draw a vertical line and mark on it a series of equal points, say, every half inch or so. In the middle of an opposite edge of this paper make a point half way on the sheet.
Connect this point with all points marked on the vertical line, and voila! You have this pyramid...
Edited by Dziadeczek
Here, make it easy on yourself... just save the PDF and print.
plankingfan.pdf
Thank you all. all sorted now
Joe
        Occre, Endurance
Completed Builds: 0
