I always wanted to build this boat. I bought the hard copy To Build a Whaleboat by Eric Ronnberg 20 years ago.
I found the kit by accident on eBay for a reasonable price. Inspired by the already existing excellent blogs in this forum I will give it a try.
The box I received didn’t look so good and I was afraid that the wood was wrapped already, but to my surprise it was still good (so far as I know).
There is one thing I do not like from the beginning, the drawings are on both sides, obviously to save paper. That makes it kind of annoying to look for certain things. I believe the older kits had it on separate sheets, or the newer version?
I am surprised how bad the accuracy for the „laser cut“ pieces are.
Oh well, live and learn.
I did cut the molds according to the drawing, glued some strips on the molds where it was necessary.
After that a lot of sanding.
Thank you for the likes & comments
That will be a long build, time wise, because I can only work on the model on weekends.
Furthermore I had to build something for my cloth pin collection.
I managed to get the hull molds and the horses done. I encountered more issues withe the “laser cut” parts than I had imagine.
But nothing which couldn’t be fixed. It was just time consuming before you actually start building.
Edited by Hsae
On a side note, the waviness of the plan was / is kind of annoying.
you have to be very carefully if you measure something.
BTW, I reinforced the molds.
Edited by Hsae
Of cause I forgot to notch mold #1 & #5. I noticed it after I had glued them together. In this case  a mini Japanese saw is very helpful. The blades are ultra thin, only 0.1 mm or 0.00393701” ! One saw is for crosscut the other for rip cut.
Edited by Hsae
The big moment where I finally start building a boat, to attach the molds to the horses.
And an even bigger surprise, it didn’t fit.  In my infinite wisdom I glued the center horse already in place. With the result you see in the pictures.
Maybe next time I should dry fit everything first, before I glue it together. Oh well …
After adding some strips under the stern & bow horse, I was able to level the mold.
I have a question for you guys.
How in the world can the two keel layer (1/16 + 3/64) match the six posts with 1/32 each?
The difference is roughly 5/64”. I am struggling with the scarf joint.
Or am I overthinking this? Just sand it down?
Hello, nice job so far. One thing I did with my plans was to just iron them with my wife's iron. Then I cut foam board to size and attach the plans with clips. You could also use just thick poster board. Just an idea. I look forward to you progress
Geoff
NRG member #2666
Current build : USS Constitution
Finished builds: Armed Virginia Sloop (in gallery)
I was thinking that too. But I wasn’t sure if I don’t have the print reverse on the iron board. I’ll give it a try.
Thats a good idea with the foam board. 👍
Thanks Geoff!
Hermann
Meanwhile I did my first oar. I made it out of 3/8” square basswood.
Of cause the handle broke off. I will see if I can fix that, or if I have to cut into the oar a little bit further.
So, I am done with the oars & paddles, except painting and weathering.
According to the book from Willtis D. Amsel Paddels were reinforced with 2 pins with the handle.
I used 1 mm diameter plastic rods.
Edited by Hsae
Back to the model. I did my first big mistake. I already noticed that the dimensions are kind off (post #13), but I didn’t double check because I read that you have to take the measurement from the planking. Stupid me!
I made the lower keel too thin. 1/16” instead of 5/64” like stated in the parts list and elsewhere. So I have to redo the whole procedure. 😒
Well live and learn!
Edited by Hsae
I like these whaleboats, looks like you've made a good start, despite having little problems to overcome!
RE wavy plans: give them a once over with the Admirals iron, it works for me to flatten creases in folded plans/drawings.
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Thanks for the encouragement!
BTW, I did iron the drawings. It got much better.
Today I got something which was for a long time on my wishlist. A steam generator.
So far I did wood bending with hot water or with an iron, now I am looking forward to seeing this in action.
  • 1 year later...
I'm a bit late to the game but have enjoyed your log. I'm about ready to start my whale boat so your photos are going to be very helpful.  Is there a further update coming?
