After being a bit sidetracked by the Corel Unicorn hull I found at a local flea market, I was still looking for a new project.
I spend Tuesdays mornings at my model club, HSME ( Hereford Society of Model Engineers )
After searching in the clubs library (the clubhouse loft)  I discover we have a large collection of Model Shipwright magazines and the quarterly books dating back to 1972. After much rummaging,  I find some plans and articles by Bill Shoulders for the cutter "Speedy 1828".
I was very impressed by Thunders build log on the old kit he found that happens to be based on these articles.
So HMS Speedy 1828, looks like it will be my new project, small, simple and should make a nice model.
So its over to RMG to get the original draughts that Bill used to develop his plans. Lets hope there is a high resolution version on Wiki as well
Then I need to scan and scale the drawings, I think I will stick to 1:48 for this build, my Bounty's launch was very fiddly to learn on.
Tim
Current Builds :
Cutter "Speedy" 1828 from Plans by Bill Shoulders at 148
Bounty Launch - Scratch build - FINISHED
85 ft. Harbour Tug. scratch built  from plans by Francis Smith. ( FINISHED but no build log for this )
HMS Lightning. kit bashed from Deans Marine HMS Kelly kit ( FINISHED ) yes at last....
Sorry Tim, Speedy (1928) is based on Lapwing (1916) and believe me, there are no hires plans.  Edit: I forgot about the Danish drawings found by Bruce_d (post #11 below)
Revisit my Lapwing thread for clues: https://modelshipworld.com/topic/23486-lapwing-1816-revenue-cutter/
Edited by iMustBeCrazy
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
48 minutes ago, iMustBeCrazy said:
Hi Craig
This really is a small world, I had completely forgotten about your Lapwing, heading over there right now....
Tim
Current Builds :
I now have a complete set of drawings scaled and corrected.
As Thunder commented in his Speedy build the bulkheads needed quite a bit of adjusting to get correct.
So tomorrow I will print out the keel and bulkheads, paste them to some plywood and make some sawdust.
Tim
Current Builds :
Are you sure? I've been asleep but looking this morning there are some discrepancies between drawings. And it doesn't help that there are 10 stations and 9 moulds.
The 1st drawing below has a scale to which I have corrected but the aspect ratio is wrong (only just noticed that) station 6 should be 10'11" ( half of 21'10" ).
I traced the sternpost, keel and stem and copied it to the other drawing which has been scaled to Mould 'E' which should be 21'10" (twice station 6) and the length doesn't match. So there is possibly something wrong with the scaling of individual sections. Maybe?
Or maybe I'm still asleep having a nightmare?
See post #7.
Craig.
Hi Tim, this is the last from the Danish Archive attributed to Lapwing:
data.ashx?bid=31917848
HTH,
Bruce
STAY SAFE
current builds:
Definitely a nightmare. 2 sets of plans, 2 draftsmen. Sheet 1 and 2 are a pair but the one showing the moulds is different.
The book of building the model gives the answer, despite the name on the box and book It's not Speedy!
Page 31 of the book gives references and says "The original Admiralty draught of the naval cutter that the 'Speedy' model was based on" and shows a drawing.
Except it's not! The drawing shown is ZAZ6373 which is the drawing 'Skylark' was to be built from along with 'Swift', 'Bramble' and 'Diligence'.
I believe these were cancelled and the names 'Skylark', 'Swift', 'Bramble' and 'Diligence' and 'Speedy' were later given to vessels built on the lines of the 'Lapwing', hence the confusion.
So the model is of the proposed 'Skylark' perhaps with some alterations taken from 'Lapwing/Speedy' drawings. Lots of room for confusion.
So I confess I was wrong, it's ZAZ6425 which is Lapwing and therefore Speedy.. Tooooo many drawings.
Because I'm wrong :)
Craig.
It may be wise to drop back 10 and punt again.
Consider:
ZAZ6345  ---  the full size print is L 31 and available
the NMM  JPEGs for the details  are large enough to get what is needed:
ZAZ6344     ZAZ6348     ZAZ6349
A Vigilant lookup will get a print of a painting with rigging details.
Scratch is difficult enough without starting with ambiguous plans.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
True, but the plans Tim has will build him a cutter, just not Speedy. For me, my great grandfather sailed out here on Lapwing so I'm more inclined to build her and get her right, unfortunately.
Craig.
Thank you Craig, Jaager and Bruce.
While I was asleep dreaming peacefully about the sweet little cutter I was going to start building today, you lot have been living a nightmare.....
I am deeply impressed with all of your research skills, I will need all of that kind of information when I get back to my other cutter "Rattlesnake"
the plans for which are still being developed.
Craig is right, I the plans that I have 'corrected and scaled' are adequate to build a cutter, it will really be a generic cutter of the period.
For this build I would really like to develop my planking skills and end up with a nice looking hull in wood, it will not be rigged.
A note on what I meant by scaled and corrected.
I imported the RMG drawing and made sure it was at 1:48 scale.
Then I imported the other plans into that master drawing and scaled then to 'match' the RMG draught.
The bulkheads are really badly distorted and needed a lot of work to get right.
The 'lower deck' part that locks the bulkheads together was also not symmetrical.
So today I will cut out some parts and see how they fit together.
It should only take a couple of hours, so let's meet back here for tea. ( or grog )
Tim
Current Builds :
Hi Jaager
Thanks for all of that information, it will be / is really helpful.
As I said before, I am really impressed with your  research skills.
Although the actual ship may be ambiguous, I think this could make a nice little cutter model.
 I have to warn you that this is going to be a simple PoB build so don't fall back to sleep 🙂
Tim
Current Builds :
Just heading off to the workshop.
Here are a couple of the drawings I have been working with, lets see what we get
This shows the original bulkheads directly off the booklet plans
Here are my corrected bulkheads overlaid on Bill Shoulders original 1972 drawing. I also cleaned up the scan of Bills drawing.
Now ( after I have cut the lawn ) to make some sawdust.
Tim
Current Builds :
Hello again Tim, I was about to offer sympathy and suggest an aspirin sandwich but it looks like you are on top of it.
However, I still have one comment. If, and I will not try to guess, if the bulkheads you have ended up with reconcile with the original plans of Lapwing, then you have the ability to add more bulkheads easily. The Danish plans are hi-res and G5757 has around 17 or 18 stations.
Ignore if I am telling Granny about eggs.
Bruce
Edited by bruce d
STAY SAFE
current builds:
16 minutes ago, iMustBeCrazy said:
Here's one I made earlier ;)
Oh Craig, I should have guessed as usual you are one step ahead of me..........
I will crack on and see if I can keep pace.
Question. Are those bulkheads directly from the booklet plans?
Tim
Current Builds :
Hi Bruce
Thanks for thinking of me.
Where can I get hold of the Danish hi res version of the plans?
Anything that will help my build is good.
Tim
Current Builds :
Here you go, use the 'SAVE' icon in the top right group above the image and it opens in a new tab. All plans are accessible from the column to the left.
Arkivalieronline (sa.dk)
HTH,
Bruce
EDIT: I should have said also that there are only four plans there for Lapwing. G5757 - 5760.
Edited by bruce d
STAY SAFE
current builds:
Hi Bruce
Thanks for the link, the drawings will be useful for the detail.
What an amazing resource, how on earth do you find specific ships?
Tim
Current Builds :
STAY SAFE
current builds:
Umm. Earlier was 2018, before I found this forum. First ever 'build' and I wasn't happy with what I was doing and with the family connection I wanted to show more of the interior. The moulds/bulkheads were corrected.
Which lead to something more like Bruce is suggesting:
But I still wasn't happy, so I bought a Bounty Launch kit and found this forum and started learning.
But I still wasn't happy, so I designed and built my small Cutter and learned a lot.
I was quite happy with that so I designed and am building my Bounty Launch (and 'Kitty').
Which brings us up to date.
Craig.
3 hours ago, bruce d said:
Have fun!
Months and months of fun at a guess!
But for some of us your hard work (actually 'Diligence' seems more appropriate ;) ) paid off. Thank you again.
Lapwing (1816)
Kite
Fancy (1817)
Racer
Sprightly
Nightingale (1825)
Speedy (1828)
Snipe (1828)
Vigilant (1821)
Swift (1821)
Basilisk (1822)
Bramble (1822)
Skylark
Diligence
Craig.
12 hours ago, bruce d said:
Fun ! I think I may need that Aspirin now..........
Just spent a good ten mins looking for a way to search for a specific name?
Any clues?
I was looking for more detail on the cutter Rattlesnake ( I already have the profile and lines that Craig sent me the link too )
Tim
Current Builds :
And your Bounty Launch is fantastic, I have just been over there to have another look.
So patience and hard work pays off.
For me, I definitely see this small cutter build a step in the right direction.
I am already having new ideas on how the Rattlesnake might be constructed for a PoB model.
Taking ideas from Bill Shoulders original model and mixing it up with modern ideas.
Tim
Current Builds :
... a way to search for a specific name?
Using the link in post #19 above, this database is the alphabetical list of subjects so look at the vertical menu on the left; RATTLESNAKE will be in the set ‘No.77 – Sea’.
STAY SAFE
current builds:
And you should find the 'card' for Rattle Snake at No 116. On it in the lower left you will see the reference 'F 18'. As there is only one reference there is only one drawing.
To access the drawing open the link Bruce provided in post #17 and search in the left column for F 18. You should find a F14-F31, click on the plus symbol, nothing but numbers, number 1 is F14, 2 is the back of F14 etc etc (most of the time) 9 is F 18.
It's a real pity that they made this wonderful resource so hard to navigate.
Anyway, have fun.
Craig.
Yesterday in the workshop I managed to get quite a lot done.
Pasted the paper templates onto the plywood.
then made some sawdust
here are the bulkheads and the 'deck' which holds the whole thing together.
I then glued the rabbet strip on the keel using some 1mm limewood.
I will leave that to dry overnight , then cover the plywood edge grain as well.
A good days work
Tim
Current Builds :
Just a couple of small jobs to keep the build moving along.
Glued on a strip of limewood to cover the raw plywood edge.
then added a layer of limewood to the stern. In my next build I really want to make a solid wood stem, keel and stern post.
but for this simple cutter model that I am using to get some practice at planking, this will do.
Tomorrow I will cut a rabbet.
Tim
Current Builds :
Found some time time to cut the rabbet
and then trying the keel in place.
stem
and stern post
its beginning to take shape
Tim
Current Builds :
I cut the parts for the transom, but the parts on the plans do match those in the booklet or on Thunders log.
They will need to be sanded down to match more closely.
the top part is too wide !
here is the version from Thunder's kit build
see
Tim
Edited by oakheart
Current Builds :
