Ahoy modelWQrights
                                     A Build I Been working On Off An On Like Many Others.  When I Was in the Navy I Purchased This kit Through The Ships Store Now It Is Time to Finish This the Project Will Be A RC Build As Of the Construction Thus Far I am completing The Super Structure Decks And Fitting Out with the fittings.  Should Have Everything topside finished By The end Of This week Then I Will Resume on the Hull thanks for you views and comments I am Honored  Frankie Day
Turn To Continue Ships Work
  • 5 months later...
nice work Deckape,
do you also posess the red lightmast and the yellow front signal mast ? Guess they should be  included in the Billings Fitting set
Nils
Current builds
-Lightship Elbe 1
Completed
