Hi all, I have just completed my first build ever (Polaris) by OCCRE and now I am about to begin my second (HMS Endurance) by OCCRE. In looking over the instructions I found the attached symbol in building mast. Can anyone tell me what it means?
Thank you in advance for your help.
Chuck
I don’t think so. For example not shown in picture is the same mast without the B, showing just an A. Then the A appears again with the symbol similar what the B has. Hope I haven’t confused you too much.  Thanks Chuck
I think Broach Boating is on the right track.  Your image is plan A and the line labeled B will correspond to a line on plan B that shows the point that the plans overlap.
I am sure that DonSangria is exactly right - 'A' indicates a view from the front and 'B' indicates a view from above.
Finished: Billings Nordkap / Billings Boulogne Etaples / Billings Evelyn / Billings Elbjorn
In progress: Amati HMS Vanguard / Caldercraft HMS Victory / Caldercraft HMS Diana / Occre Montanes / Artesania Latina Santissima Trinidad
In the dim distant past: Model Slipway Wyeforce / Mountfleet Models Boston Typhoon (abandoned build) / Bluejacket Charles P. Notman (abandoned)
50 minutes ago, ChuckP said:
Here is the full picture vs just the section I attached earlier.
A is looking at the part from the front as shown in the A elevation on the right. B is looking down on the part, showing the platform in B elevation on the left.
Edited by BrochBoating
Simon.
Current builds
  • HMS Speedy v2023 - Vanguard Models
  • Nisha - Vanguard Models
  • HM Gun Brig Adder - Vanguard Models
Previous
This is partially correct.  "B"  is the cross section (looking down) at the point where the arrow indicates, it is not from the top of the mast which would have included the cap.   Another common convention would be as below
Allan
Allan
Allan is completely right.
Correct.
    Done:          Venetian Polacre http://modelshipworld.com/index.php?/topic/7290-venetian-polacre-by-cristiano-sec-xviii-from-original-drawings/
                              Halifax  http://modelshipworld.com/index.php?/gallery/album/844-halifax/
                              Ranger  https://modelshipworld.com/gallery/album/2175-ranger-revenue-cutter-by-corel/
                              HM Bark Endeavour (Corel kit heavily kitbashed) : http://modelshipworld.com/index.php?/gallery/album/125-hmbark-endeavour-corel-kit-bashed/
                             Venetian Galleon (from scratch) - Pirate Junk - Sicilian Speronara (from scratch)
On the shelf (still packed):     Artesania Le Hussard....
