On 12/6/2024 at 5:56 PM, Baker said:
The strakes normally follow the lines of the planks and seal the seams between two planks
Well today I learned - and that's annoying, because the Caldercraft instructions have them as I've placed them on the hull. I should have looked this up first!
Here indeed there was no clinker planking, but removable shields.
I woke up this morning and decided it would always annoy me if I didn't change this. I've already ripped some of these off and I've started on the planking of a similar area on the forecastle - I'll update soon with my new version.
Thanks for the reply!
Doug
In the shipyard:
Caldercraft's Mary Rose 1:80
Finished Builds:
Mamoli's Gretel 1:54
OcCre Palamos 1:45
I can send you more info and drawings via pm about these shields.
But then you have to wait a bit, Baker is on vacation
I'd be interested in your research - though I've already added in my interpretation of the drawings I have for my model 😉 I hope your vacation is going well!
Here's today's update. After taking off the clinker over the gunport holes, I turned my attention fully to the forecastle this week.
Well, sort of fully - here's my 3D-printed bronze cannon, now painted bronze. 20241209_155656.thumb.jpg.32117f69927b3ceb9fcf5ae24dd8fb9e.jpg
I'm very happy with how these have turned out. For the paint I used Army Painter Weapon Bronze, followed by a wash of Citadel Nuln Oil and a drybrush of both Weapon Bronze and Citadel Leadbelcher. I was tempted to add a little verdigris with some weathering powders I have, but I think that might be taking  it a little too far!
Here's two of them in place:
So. Forecastle.
In a previous post I mentioned that I was unsure about how to deal with the delta-shaped top of the lowest deck of the castle where it meets the second deck. In the end, I simply planked over it. This looks similar to some of the reference images I'm using, and I'm pleased with how these planks have fit together.
You can see here the offset hole I've cut for the bowsprit and the slight divot I've taken from the front supporting post to accomodate it as well.
And here's my solution for the pavisade gunports - I'll be replicating this on the sterncastle as well, though slightly differently as the ports are spaced slightly closer together there.
In McElvogue's book he has a lovely illustration of how these would have fit together, and I loosely copied that. The ports need a bit of cleanup in this photo, but they're far better representations of the various media than what I'd done before. Also in this photo note the white band across the middle where I'll be painting the yellow and red stripes depicted in the Anthony Roll. I used white painter's gesso for this as it's designed for use on wood and provides a very solid base coat - another layer still required.
For the top layer of ports I've created a similar pattern, but as these are smaller in the various sources I have I resorted to a bit of improvisation. Later on I filed out a little groove in the top of each port to create the same 'dimpled' shape as the lower ones.
Here's a couple photos of it in situ:
You can also see a sneak peek at my sterncastle progress - I stuck in the four cannon and have begun the pavisade gunports there too, but I'll update that properly in the next post. I'm happy with how the forecastle looks here, and though I am a little concerned about the height I think it does match the historical sources quite well.
Now onto the main issue that's caused me consternation over the last few days. First, let's look at the Anthony Roll's depiction of the forecastle:
And then here is McElvogue's drawing of it:
And Marsden's:
So my questions were mostly around the top 'cabin' and the two 'prows' that extend over the top deck and the cabin's roof. In McElvogue's work they're extremely pronounced, whilst in Marsden's they're nonexistent. I can't believe that Anthony Anthony would have added the slight curve forward in his illustration if it wasn't there, but it certainly doesn't feel like a sharp point is what we're working with here.
Additionally, both of the archaeologists have omitted any kind of railing on their top deck here, implying that there was no access to this point on the ship, and yet to manage the masts there must have been a need to climb up here. Certainly health and safety wasn't what it is today, but I'd be surprised if there was nothing at all, especially when looking at the Embarkation painting, which definitely has a pavisade-style railing, much like in the waist of the Mary Rose:
Here's my creation with the bowsprit in place against one of Marsden's drawings:
As you can see, the bowsprit on mine is at a much steeper angle - I could change this still, but it does appear to have been steeper based on the various historical sources, and McElvogue's book has it at around a 40 degree pitch.
For the prow, I initially experimented with creating something similar to McElvogue's work, bending a plank to meet a very pointed 'stempost' at the tip of the castle:
I think that if I'd got this to work, it would have looked quite nice, but after a lot of struggling I just couldn't make the planks sit right, and it didn't feel like the Anthony Roll's depiction at all.
I moved on to a slightly less prominent 'prow' (forgive me, I have no idea what this point should be called).
And this is what I've decided to go with - it still expands the top 10mm or so of the castle without creating a major headache of plank bending, and looks a lot more like the Embarkation painting.
Here's a view of the inside:
The two planks here raise the height around 10mm above the deck - that's just over 1 metre to scale. My plan is to have this as the railing of the top deck, and build up the cabin at the back of this structure.
So that's what I did:
Here's the cabin, with three supports to estimate a good height. This is 20mm above the railing planks, which I intend to lower slightly. You can see that I've planked over these with a very thin sapelli veneer; this will be the base for another strip of white gesso before I paint on the stripes.
And some walls on the cabin:
I again used some of the precut boards from the Caldercraft kit for this - I believe that these would have been part of the original forecastle, so it's nearly accurate 😉 I'll put in some more interesting planking around these once I'm happy with the basic structure.
And here it is on the ship:
And from the front:
I'm sure that this is deviating wildly from known historical evidence at this point, but ultimately it is a model, my first semi-scratch build - and I'm pretty damn pleased with how this has come out.
Do let me know your thoughts.
Thanks for reading!
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
Excllent work,  I still  remember the  day when she was lifted in the Solent -  what  an event  on the tv.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Keep in mind that these reconstruction drawings are modern interpretations, and I for one can't see any evidence to justify these 'prows'. I like your way of doing it far better.
I think the angle of the bowsprit looks far closer to the Anthony Roll depiction than those of the two modern reconstructions. So go with it.
The height of the bulwark above the deck - one metre - is what is specified here in Oz for any structure such as a railing on a raised floor/balcony etc. So I think you're on the money there.
The triangular 'cabin' surprised me a bit. I would have thought the Anthony Roll shows the walls parallel to the sides of the forecastle. But this is very open to interpretation, and I'm by no means going to say you're wrong in doing it this way.
Overall, I'm gobsmacked. You're doing a beautiful job!
Steven
Yes, I'm not entirely sure about it, but I think I'm happy with how it looks. If it doesn't work out it's only the top deck to rip off later 😉
That said, if you look at the Anthony Roll there are three obvious flags on the very top of the forecastle, and so I was going with the assumption they were on each point of the triangle. There's one more flag on the forward tip of the forecastle itself. We'll see!
Thank you very much, that means a lot!
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
Interesting thought. To me it looks as if the two at far left and far right are level with each other, both at the front corner of the 'cabin', and the rear one is at the back corner (starboard), but that leaves the question 'where's the one for the port back corner?' Or it could just be that he bunged flags wherever he could fit them. I dunno. Up to you, mate, whatever you feel is right. It's your model, after all.
Best wishes,
Steven
On 12/15/2024 at 7:32 AM, Baker said:
Indeed, a very intriguing view of the upper part of the fore castle 🤔
I ended up agreeing with both of you on this. Back to the drawing board; see below!
First of all, I carried on with my initial construction of the forecastle. Where we left off was pretty close to done, but I finished off with the roof of the cabin and the beams that run vertically up the aft side:
In the Anthony Roll these are extremely curved - I toned that down somewhat, but I did add a little curvature in. It's possible these would have been completely straight.
On with the masking tape! This was a time-consuming process, but worth it in the end. Here you see the first layer of gesso on:
And here's the stripes!
Pretty happy with this - a few messy bits that I'll clean up later, once the sterncastle is painted.
Another view from the front:
And now time to rip off that top cabin. I wasn't happy with it, and especially after the feedback from my last post I knew it would never be right to me.
Luckily I'd not actually attached it very strongly, and some careful prodding with a hobby saw later...
My original front post for the triangular cabin was around 5mm thick, and after some even more careful application of the saw, I had these:
Which had mostly survived unscathed!
The original Caldercraft kit had a little archway for the front of the forecastle. I figured I might as well use it here, and created this:
And a side view:
I'm much happier with this shape, and I think it works well with the rest of the structure. This means the forecastle is mostly completed, other than the entire aft wall. I still need to decide whether to include the Tudor rose 'figurehead' that was apparently affixed to the tip of the upper deck.
Now I've not just been working on the forecastle - if you recall from a previous post I wasn't happy with the clinker planking I'd done over the portholes, so I took those off. Here's what I replaced that with:
I believe that this is much more in line with the 'original', as far as we know. It's also in a similar style to what I've done on the forecastle, so I'm much more satisfied with it.
You can also see I've started building up the walls above - these are just thin sheets of plywood as a basis for the coming construction.
Here's the poop deck dry fit to check the height:
And a full side view:
And since then, I've actually made huge progress, adding in the middle deck:
Note I'm not planking the two internal decks; they'll be practically invisible through the tiny portholes, and I'm running a little low on the tanganyika planks I've used for the rest of the decking, so it seems sensible to not waste the wood here. Each of these decks will have two cannon fore and aft, but as you can see in this photo there's little visibility around the barrels anyway. I'll probably not spend too much effort making the carriages perfect either for this reason.
There are thirteen portholes on the next level up, separated by distinct uprights. I managed to get exactly thirteen with a pattern using the various scrap pieces the build has generated thus far, which I'm quite pleased with. I'll be rounding out the top of each porthole later down the line. The strips of sapelli veneer will be painted over with gesso and then stripes.
And here's the top deck in place, with masts all test fit just because I could:
A view from the other side:
My plan is to put a small railing around the top of the sterncastle as well, which will give me space for the top line of stripes. In between this and the previous line is a strange pattern of cross hatching - I'm not entirely sure what to do here, so any input would be very appreciated.
A couple final details before I sign off - the top of the forecastle planked:
And a full view of the sterncastle's port side:
You can also see I've started planking the poop deck here. Once the railing is in place my next task will be working out how on earth to get 1:80 scale boarding netting to look good. Any suggestions?!
That's all for now - I've packed up for Christmas as we've got lots of family round and the dining table was required. Thanks for reading, and happy holidays to all!
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
That's all looking very good, Doug.
I like the paintwork, very neat. And you have the narrow white stripe between the red and the yellow. Very nice.
That works nicely. Arches seem to have been a bit of thing at this time, so I think you've got a pretty good justification for it.
Oh, do it if you possibly can. You do know they've actually found the original, don't you? https://maryrose.org/artefacts/emblem-figurehead/ If you're worried about carving it, don't be. That's just a matter of practice. And using the correct wood (fruit woods are nice and fine grained - pear, apple , cherry. Or better still English box - buxus sempervirens - that's amazingly good). Have  ago! Carving can be very rewarding and fulfilling (and addictive if you're not careful!)
No, there's no need. I made the mistake of not even including the decks at all in my Great Harry (hey, I was seventeen - I didn't think ahead far enough) and had terrible trouble supporting the cannons inside. I had to do all kinds of dodgy work to make it happen. Never again. But there's certainly no need to have planking on a deck that nobody will every see.
Very nice.
Yes, that's a bit of a mystery. I don't think it's an open railing, which was the first thing that came to mind, as it doesn't continue around the stern. But the transom is not the same as the sides - it has to be solid to support the spar that takes the lateen sheet, so maybe that is an open railing after all. But yes, there is a narrow line of stripes above it. Perhaps a broad, painted top rail?
I know McElvogue has shown a wooden support structure in his book, but I'm pretty sure that's speculative - I don't think anything was actually recovered. But I'm pretty sure the remnants of netting he shows are the real thing. I'd say, however, that his idea is practical and is quite probably what was done. Have a look at the "boarding frames" - that is, sort of pergola things that served the same purpose on earlier carracks. McElvogue's design is similar, but with the 'rafters' further apart, which would be sensible as the netting takes the place of the intervening rafters to act as a barrier to boarding. The main issue I had was - how do you deal with the problem of belaying all your rigging lines if a boarding netting is in the way? They normally belay either to the side of the ship or close to the relevant mast, and it's probably possible to work it all out. But you'd have to think it through well in advance so as not to paint yourself into a corner.  To be honest, I had been planning on a boarding netting on my Great Harry, but I chickened out - it all seemed too difficult. Though that was at 1:200 - yours at 1:80 shouldn't be as hard.
Steven
  Don't forget the painting of Henry setting out for Calais - it shows shields all around the top decks - presumably supported by open railings - so archers could shoot through the gaps between shields and still have a lot of protection via the shields.  Also, boarding netting would only be put up when the ship was readied for action with an enemy.  Henry was on a diplomatic mission, so there are no nets in place.
Thanks for the kind words everybody!
Here's my next update, but first:
Oh, I'll definitely be giving it a go! I've got some boxwood lying around so at some point it's definitely on the agenda - as is a trip to the museum to go see the real thing 😁
Yes, these are the issues I've been dealing with as well - and it's something I'm going to have to consider very soon as I think the nets will have to go in around the same time as the masts. I think I'll probably go with something similar to Mcelvogue's interpretation, though Marsden also has some input which I need to review. My other concern is actually sourcing a net that's that fine; I think judging by the scale I need around a 1.5mm hole size and probably about 0.8mm cordage - not really something I want to make myself, but I suspect that might be the only option. I did buy some sample fabric on etsy, but it was far too heavy for my purposes. I was also thinking of perhaps using some hessian fabric (burlap or jute for the non-UK speakers here) I have lying around, but even that seems too coarse. I'll keep looking.
Yeah, the Anthony Roll also has the shields in the waist, and the Embarkment painting has them on the forecastle as well - but how they'd have been mounted is completely unknown!
Agreed the boarding nets wouldn't have been permanent, but for sure at least some of the support structure for them must have been. Looks to me like there was a sort of A-frame 'tent' structure on the sterncastle, and then the waist has a central walkway from which the nets were supported on spars - much like @Louie da fly detailed above.
On with my (small) update for today!
I carried on with the decking on the sterncastle's poop deck:
A bit of a weird shape resulting in a jigsaw puzzle, this, but it looks pretty good now it's done.
And then I tackled the railings. I wasn't keen on doing an open railing - I love what @Baker has done on his version, but I certainly don't have his artisanal skills and I doubted my own ability to make it look as good.
First I built up the sides and added a series of 9mm uprights:
These are spaced around 30mm apart, but I did play a little fast and loose with this, as at this point in the build nothing is quite square any more. Sue me.
I promptly forgot to take a single photo between this and completing the railing on this side. So here it is:
As you can see, I have interpreted the cross-hatching on the Anthony Roll image as a series of uprights which support the railing. As mentioned in the previous post, all of the strips of slightly reddish sapelli veneer will eventually be painted with the red and yellow stripes, just like the forecastle.
Here's the other side:
This side was a pain in the *** to get right - the whole thing is, it turns out, about 1.5mm off level. All things considered, less than it could have been, and not really noticable, but a huge nightmare when you've only got the right wood in 4mm widths. Ah well!
Shortly after this was taken, I added in the clinker planking on the exposed pine midway up at the front of the sterncastle wall.
And then I moved to the back!
20250102_161544.thumb.jpg.f2ae71c92e4c7b2ea000e02784b0e75a.jpg20250102_161738.thumb.jpg.3e688541b2fbe6e8f1a3043d962331a0.jpg
Here you can see me building up the transom and testing out where the cannon will go. As you can see, I'm not building up the carriages properly, ommitting the wheels and the rear structure of each - only I, and everyone who sees this, will ever know!
I tried to follow the structure shown in the Anthony Roll as much as possible in this build, and for the most part it was just a puzzle of working out how to fill up the gaps and create something that'd be strong enough to support itself and the planking over the top. It's a little bit of a bodge in places, but I think it's come out looking great.
Here's the planking over the middle set of cannons:
Again, the strip of sapelli will be painted with stripes. In the Anthony Roll this stripe is actually above the ports, but this lines up with the stripes on the side of the sterncastle, so I thought it would look a bit better.
Next the top deck:
20250104_130531.thumb.jpg.e85a7668308d6a15d19a60c0b0d13816.jpg20250104_135753.thumb.jpg.d3465e6752a5073c23f585ccb9fb90f6.jpg
This posed a little bit of a challenge as I needed to include the middle window, and so I had to move where I'd initially planned to put the cannon ports. Not a major issue, but one that some better pre-planning would have avoided. I'm ver pleased with my uprights here; they all required a very slight curve that was a pleasure once I got it right.
N.b there aren't any obvious uprights in the Anthony Roll's depiction of this section, but I'd rather have these on the outside as it breaks up what would otherwise be rather bland clinker planking.
Speaking of which:
Here she is!
This is really beginning to look, to excuse the pun, ship-shape. I'm super pleased with how this bit has come out.
Next I'll be working on the aft side of the forecastle and the fore side of the sterncastle, at which point I'm very nearly done with the bulk of the initial build.
Thanks again for all the lovely comments and the engagement with this build.
See you next time!
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
Very nice work, Doug. Looking very good.
As I mentioned earlier, I chickened out on adding netting on my own Great Harry, but I found gauze at a fabric store that would have done the job nicely. You know, the stuff that goes on bridal gowns etc. Might be worth checking out. Probably synthetic, but what the hey. I chose black, firstly because the original stuff was probably tarred, secondly so it didn't grab the attention too much away from the rest of the ship.
Probably on what is known as a pavesade - basically just a railing that holds shields. They were probably tied to the rail by a rope passing through their enarmes (the straps at the back that you hold the shield by). That's certainly what I did with the shields on my dromon build, and it worked fine (though you have to make sure you get the alignment right).
Steven
And another update! I knuckled down this week and got a lot of the tedious bits left to do on the hull out of the way. Here we go:
I put the rudder brackets on and attached the metalwork on the rudder itself.
This is actually still removable - I feel like I'm going to knock it and don't want to bend the relatively soft brass out of shape, so I'll just keep it off whilst still working on the build.
Then I started on the aft side of the forecastle:
Most of the following building work is done using the same principle of 0.8mm plywood as a foundation followed by planking over it with walnut. I won't go over the major details, so here's a few photos:
I made sure to keep the cannon pointing out at a suitable angle - the Anthony Roll has these pointing upward at quite an angle as well, but mine are relatively horizontal.
The way I'd put my decks in meant I couldn't follow the lines of cannon and windows exactly like the Anthony Roll depicts, but I've tried to be relatively faithful to that design, with the two windows at the top.
Here it is finished:
I'm really pleased with how this has come out. I used the same sort of design for my various portholes and cannon ports as I did along the sides of the ship, so it fits very well with the rest of the build.
On to the sterncastle:
I had a bit of scrap ply that was almost exactly the right width for the entire sterncastle's forward face, so I marked out where I wanted the various apetures and cut them out. The small arched openings are a little messy, but it doesn't show up too badly on the final product.
Here it is test fit with some of the details added:
And here with the rest of the detail:
Here it is with everything in place, and again I'm very pleased with this. I ended up adding one more strip of 2x3mm walnut at the top to fill in the gap between the face and the poop deck.
She's absolutely bristling with cannon now!
I also finally got around to finishing up the waist:
Caldercraft had some very strange designs in mind for the 8 ventilation hatches here, with an open square at the bottom and then a top plate that's only just large enough to sit on top of the opening. I'm not entirely sure what the idea was for this - there's supposed to be another larger square on top of each of them, but they were so flat and uninteresting that I've left them off. There's no evidence these holes even had hatch covers, but I wanted at least something on them as I'd not planked the deck below. The provided ladders were also way too long - an extremely frustrating part of the build. I ended up covering up the two ladderways on either side of the mast - they didn't exist in the real Mary Rose, as there was a bilge pump where one of them is.
Then I build up the trestle-tree and the top for the main mast:
I tested the mast length again and found that Caldercraft's measurements are just slightly shorter than I'd expect. According to R.C. Anderson's The Rigging of Ships in the Days of the Spritsail Topmast, the mast should be 2.4x the length of the beam. That puts my mast at 336mm, which is 88 feet in real scale, though that's measuring from the deck and not from the keel - but Anderson notes that masts were getting shorter throughout the 16th and 17th centuries, so it stands to reason that the Mary Rose's could have been slightly longer. Most sources seem to think that the mast was around 80 feet.
As you can see, I have some wiggle room here, as my shrouds still won't interact with the sides of the sterncastle - especially once they go over the trestle-trees. I think I might be conservative and bring the trees down to the 300mm mark, or 78ft from the deck.
I also planked up the waist gangway. This will eventually support the struts for the boarding netting on each side of the waist, but I needed it planked now as I'll be putting in the masts soon and the mainmast goes through it.
And with this update, I'm pretty sure the main bulk of the build is done! I still need to paint the sterncastle stripes, but otherwise the majority of the wood is in place. Caldercraft's kit is extremely generous in this regard - despite the huge amount of extra stuff I've built, there's still an enormous amount of spare timber. The only thing I've ordered extra of is 3x2mm walnut strips. I did order extra 1.5x1.5mm wood as well, but it was left out of my order and I didn't end up needing extra.
Thanks for following along as always!
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
16 hours ago, Louie da fly said:
That's very nice work. You've made a lot of forward progress since your previous post and its all looking very good.
Thanks very much Steven!!
I made a little bit more progress today, and wanted to share it as I've reached a point I'm slightly unsure on.
Here's the masthead for the mainmast:
I built this mostly to Caldercraft's specifications, but I squared off the head instead of rounding it, as according to Anderson's book this is probably more period accurate. Also it's easier.
Here's me testing out the topmast:
Here's the mainmast, main topmast and main topgallant tapered, in place with mastheads assembled and dry-fit:
And so my concern, for those with more knowledge and experience than me - does this look too tall?
To scale, the total height here is just around 180 feet from the keel, or 150 feet from the deck. McElvogue quotes a source suggesting 150 feet for the main mast, but it isn't clear whether this is just the main or the whole structure - if it's the whole structure then that's actually way longer than my construction here, but if not then mine is likely a little too tall. Nothing is glued in here, so I can easily shorten each of the three sections, but I'm a little tight for clearance with the shrouds off the first top - I suspect I can only lower it by around 1-2cm before I have real issues.
Any input would be very appreciated!
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
  I've noticed that on the Anthony Roll, the first section of masting (as well as the bowsprit) seem 'impossibly' tall - topped by modest mast sections.  This depiction is also seen in other contemporary art.  Talk about instability in all but the lightest breezes.  The old Sergal 1:65 Great Henry used proportions like that in the kit design, and examples of more recent art also take after 'Anthony Roll proportions'.
 Yet there are examples of what seem to be more likely (sea worthy) mast length proportions both in art and models as shown below:
image.png.ade79c783f25d94d44e31a0ce870e0f2.pngimage.png.7e744ad8a386e1a0ef282987005f4bdf.png
I can't claim to know anything about what should be the correct height for the mainmast. McElvogue isn't my favourite author; I'd be looking at Anderson for preference, but even he is working with vessels that are from a period starting out 55 years after the Mary Rose sank, let alone when she was rebuilt (64 years). A lot can happen in that time. So at 1:80 you have 1-2 cm maximum to play with - that equates to 80-160 cm in the real world - 2'7" - 5'4' - in something like 150 feet above deck level - which is only 1.75% to 3.5% of that height. I can't see that making that amount of change would affect things very much.
However it's possible that at this time the top and topgallant masts were rather lighter than they became later. Certainly in the late 15th-early 16th century, the topmasts and topsails seem to be nothing much more than an afterthought. But of course we also have to allow for the evolution of sails and masts over the period between then and when Mary Rose was rebuilt in 1536. So really I can't help a lot in answering your question, but I hope I've raised some ideas for consideration.
Best wishes,
Steven
On this drawing the keel is 15cm.
From keel to first mast top 13,5cm
From keel to second mast top 18cm
total length of main mast, from keel to top 20cm.
Thanks Steven. Yes, it seems silly to make any amendments for such a small percentage change. I've ended up leaving my mainmast as it is, but I have slightly shortened the main topmast and very slightly shortened the main topgallant mast - overall it's about 145ft from the deck now, which is still pretty tall, but now looks much more in proportion - I'll update soon with proper photos. I'm using Anderson's guidelines for the other masts, so now I'm happy with the main mast the rest should go smoothly. Famous last words.
Thanks Patrick! Looks like I'm on the right track if slightly too tall with my mast - in proportion it seems like it's around the right size. Useful image!
I'd like to say it's probably artistic license. In Anderson's book he does mention that masts were getting shorter throughout the two centuries after the Mary Rose sank, so I suppose they could have been much taller (despite the instability). I've had similar qualms about the length of my bowsprit as the angle is quite extreme as well.
Thanks for the kind words and comments on the last post everybody! I'll be updating very soon with some major mast progress I hope 😁
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
So - even more progress!
First, I put the wooldings on the mainmast:
Caldercraft only speciified 8 wooldings here, but Anderson thinks that there were normally more in the 15th century, so I went with 10 wrappings. Hard to prove that one either way!
Then I finally got round to what I've been putting off for ages:
Masking tape.
Then a layer of painting gesso, followed by...
More masking tape.
Honestly, placing the tape was the most tedious task, because once I got the paint out it didn't take too long:
And then the yellow:
And finally, the grand reveal:
I even painted some stripes on the transom:
So that was fun. Glad that's over - what a slow process!
As I was on a bit of a roll, I moved on to adding the other masts - now I've stuck with my mainmast being slightly longer than it perhaps really was, I can work out the heights of the other masts from it. My bonaventure mizzen wasn't sitting at a good angle, so I had to take the longest 6mm drill bit I could find to move the hole in one of the internal decks - no damage that's visible!
Here she is in full view, all masts in place. The bowsprit isn't cut to length yet - I was reluctant to cut it too short.
And here are the topmasts:
The main topmast is slightly wonky as this is all dry-fit - I am fully aware of the kink in it!
Here you can also see two marks on the bowsprit dowel. The shorter one is McElvogue's measurements, though I'm very dubious of his scale here. The longer mark is around what Anderson recommends, though he also notes that it's very difficult to prescribe as it's nearly impossible to tell where bowsprits start and end within the bow of the ship. I ended up taking the measurement from the stempost, and the longer mark is what I used.
Here the masts and bowsprit are, tapered, stained and in place (dry-fit still, I'm not insane).
I'm really happy with how the stripes look on the sterncastle. Some of the angles of my masts are a little off - I especially need to adjust the mizzen.
And then, not to jump ahead too much, I cut all the yards to length:
These are mostly based on Anderson's measurements, though Peter Marsden's book also has listings for most of them. He omits the mizzen topyard and the spritsail yard, so for those I've used Anderson's suggestions. I will say that the main yard feels ridiculously long - 85 feet! But it does seem to be backed up by the sources, so it's what I've gone for, though I can still cut these shorter if needed.
Now I've got these cut to length I'll need to taper and prepare them for mounting, which also means tackling the fiddly-looking parrels, so it might be a short while before my next update. However, I'll leave you with an interesting conundrum; deadeyes. See below for McElvogue's drawings of the deadeyes, and some of the actual examples pulled up from the wreck:
20250117_141324.thumb.jpg.e1a2177266cbceebd06d16f09aefd4ec.jpgimage.jpeg.6a1b81bed1a4c5b9a62adf189794b932.jpeg
And now see the deadeyes provided by Caldercraft:
Not quite enough holes, methinks.
Any suggestions for how to go about making myself some 7-hole deadeyes would be very appreciated, though at this scale I do wonder if it's worth the effort - I'm sure @Louie da fly would appreciate it though!
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
Nice paint job
Red,yellow,white... familiar 😉.
The lower deadeyes of the main mast had  7 holes. The rest probably less.
The holes in these deadeyes are not drilled symmetrically. You can always drill a few extra.
    Your decorated castles are absolutely fabulous ...  The fighting tops being on a 'curved trajectory are attractive, but when I get around to ever finishing a GH, I may favor a lower position for the fighting tops (topmasts look fine) as marked below.  But the fore top could be just about on the level as the main top ... hard to decide - but when the time comes I could start with higher first mast  segments and them trim from the bottom as desired.
  Given the crammed troop loading and extra armaments in the castles and tops, its no wonder that the Mary Rose capsized like the Vasa ... much to our present knowledge.
On 1/17/2025 at 5:34 PM, Baker said:
Nice paint job
On 1/17/2025 at 5:36 PM, Baker said:
Thanks Patrick! I really like the colours, they stand out especially nicely against the walnut I've used in the sterncastle.
Thanks for the heads up about the 7 holes only being for the mainmast - that'll save me a hell of a lot of work.
I had a go at drilling a few extra holes into one of the deadeyes:
I think this should work, though I suspect six might be easier to manage than seven for most of them. At this scale it's going to be a bit of a mess of threads, so I'll have a play with this. Not sure I've got the craftmanship skills to create deadeyes like you have on the Golden Hind!
Thank you very much!
I've put them at the heights suggested by Anderson in The Rigging of Ships, which has the fore top slightly lower than the main top, and from this the mizzen top is slightly lower etc. etc. - whether that's how the Mary Rose was, we'll never know, but I do agree it's an attractive way of doing it, so I think that's how they'll stay!
Absolutely, there must have been a huge amount of weight in each top with all the various darts and hand-cannon they had up there as well, I can easily see how the capsizing happened.
On 1/18/2025 at 12:54 AM, SiriusVoyager said:
Great work on the painting.  This has been a fun build to watch.
Thank you very much Eric!
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
And here's a slightly build-adjacent post: I went to the Mary Rose Museum in Portsmouth Historic Dockyards this weekend!
I've been meaning to go ever since I started this build, and it was nice to be back in the city (even if it was a rather gloomy day).
I took a whole bunch of photos, but for the sake of brevity I'll just post some of the more interesting ones relating to my build. I'd really recommend the museum if you ever get the chance to go - it is quite expensive, but to see the ship in real life is really something else, and the rest of  the dockyard attractions are also fascinating.
First of all, the Caldercraft model according to the instructions:
Curiously, this is clearly made with a very different wood to the version I have. I imagine it's been updated somewhat, but still interesting to note. The museum gift shop sells the kit for £400 - significantly more than I paid for it! A few of the various infographics within the museum use diagrams that this was clearly based on, with short castles and the weird boxy forecastle. Obviously this was an early vision of the ship, but I'm surprised that they've not updated it.
On to the actual museum. Here's the ship's bell:
And some anti-boarding netting:
This hasn't helped my quest to add the netting to my own build, but it was very cool to see some of it. I think at my scale each hole will be about 1mm - I'm concerned this will block vision into the waist a little.
Here's the first glimpse you get of the ship herself:
You'll have to excuse some of the following photos - my phone was really struggling as the main room of the museum is kept quite dark, I assume to preserve the wood.
This wasn't my first trip to the museum, I've been twice before, but it always blows me away how well-preserved the ship really is. It's possible to pick out individual cabin walls, and one of the museum staff used a laser pointer to show us where the carpenter and ship's doctor were located - fascinating.
Here's one of the slings:
The same museum staff member - who was, incidentally, dressed in full Tudor costume - gave me an interesting factoid on this. All of the two-wheeled cannon carriages were apparently military cannon, brought aboard for use by soldiers who were untrained with the larger, four-wheeled naval cannon. This explains some of the mix of cannon aboard, with breech-loaded slings mostly in the waist and castles, whilst the naval cannon were operated by the ship's permanent maritime soldiers in the main gun deck below. This was apparently the very beginning of what we now call the Royal Marines, that is, soldiers who were deployed upon ships.
Here's some more views of the ship herself. We were standing at around the height of the main gun deck and waist here.
20250118_133902.thumb.jpg.eafc2cb61826aa21c06a439b65df090e.jpg20250118_133859.thumb.jpg.021f1c94c90875ad58c73396166218ca.jpg
I tried taking a panoramic photo here but unfortunately the light levels were simply not good enough. Even so, I hope you can get an idea of the scale of the Mary Rose from these, as well as how remarkably well-preserved she is.
On the same level we found the figurehead, and some digital reconstructions of it:
20250118_134035.thumb.jpg.6f4bb3f6f685a019323098cc81728a3c.jpg20250118_134102.thumb.jpg.6e1aee3fe931151a549c6dfd0e142ffa.jpg
I'll definitely be trying my hand at recreating this - fantastic stuff!
Further on, some more really interesting stuff about the cannon; I'd guess these were some of the better preserved bits, and I'm sure they're very popular with the public as well.
20250118_134555.thumb.jpg.aa78dc86deb1bd61aab8ab061769404f.jpg20250118_134616.thumb.jpg.63acaff14169fe725156aa0ca6efbd91.jpg
Really interesting to see these in person, and has happily reinforced my 3D-printed creations. Awesome stuff.
Here's one of the two enormous ship's cauldrons, arranged as it was found:
One of the bricks here had a dog's pawprint on it, a lost remnant of an animal now nearly 500 years gone. Crazy.
The Mary Rose from the bow end:
Here are some of the blocks, tackle and other rigging paraphernalia:
20250118_135455.thumb.jpg.f11c29b648debb21b0159800745ce6cf.jpg20250118_135508.thumb.jpg.d9f1fb35bce48d8da9ca928c70b50151.jpg
You can see a few parrel beads on the left there, though there was a fully assembled parrel later in the museum.
A note - where the museum wanted to demonstrate missing parts, they've replaced them with perspex, as with the blades on the knives in the right photo. This is to help distinguish what is real and what is reproduction, especially in the gloomy museum.
Here's the parrel:
The ones in the Caldercraft kit are seed beads with brass etching for the ribs - that's the next project for me, so wish me luck!
And here are everyone's favourite deadeyes:
20250118_140426.thumb.jpg.2e7a1e906d543f09cdd33505f44e0007.jpg20250118_140432.thumb.jpg.19b8b9dec93a80332352e1c39d7cec9d.jpg20250118_140631.thumb.jpg.3c7749e475b5c68d99ab6bff4a42e816.jpg
On the bottom photo you can see one of the pulleys in the process of being carved out - this was found in the carpenter's cabin. How amazing is that?!
Another cannon, this one a brass culverin that points forward out of the sterncastle's forward wall. This is placed in a position that directly mirrors the wreck of the hull, helping give visitors an idea of where everything would have really sat:
And here's an interesting one:
That's one of the 'fowlers', or Pierrier à boîte which were discussed earlier in the build log for my forecastle. On my model, these are 12mm long. You can see the 'beer tankard' breech loading mechanism, which would have been filled with gunpowder.
Again, I took a fair few other photos, but mostly more of the same, a few references of cannon etc. - a lot of what I'm doing now is rigging and masts, which are pretty absent in the museum - for obvious reasons!
On the way out I did find this, which I thought was quite funny:
I've had a look at this online, and it would appear that the castles in this plastic kit are actually more accurate than the Caldercraft model. Hilarious.
There was one other slightly more accurate model in the entrance foyer to the dockyard itself, but unfortunately I didn't get a photo of it - I'll definitely be going back, so will try and remember next time.
A few last photos to finish off the post, not the Mary Rose but in the dockyard. First, the hull and keel of the Victory:
Last time I was here, you couldn't walk underneath, but at the moment the ship herself is coated in scaffolding - we did go onboard, but photo opportunities were limited. She's undergoing major restoration, and will be under wraps until 2035!
And here's a modern juxtaposition, the HMS Queen Elizabeth and HMS Prince of Wales (not sure which is which!)
A photo doesn't do justice to how enormous these things are - from a distance they looked like buildings on the skyline. A fun tidbit from the trip - the Queen Elizabeth has a Tudor Rose as her 'figurehead', much like the Mary Rose did.
That's all folks. Again, if you get the chance to go to the museum, please take it - it's a real labour of love.
Thanks for reading!
Edited by djford
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
