Proxxon DB250 3 Jaw Chuck
Go to solution Solved by Dziadeczek,
Thanks for the replies… definitely do not speak Russian but do proudly speak some Ukrainian. The chuck in the video is completely different that the 3 jaw chuck of the DB250 but thanks for posting.
Certainly I meant to say that the towel over the chuck would need to be created in a tent in order to catch the oil on the first spin after applying penetrating oil.
Julian
Current: Mamoli - Friesland
Finished: Billing Boats - Bluenose
Mamoli - Santa Maria, Billing Boats - Dutch Sperwer
On Hold: Caldercraft - Bomb Vessel Granado
Waaay back when I was much younger and in college one of our lecturers had a run in with a chuck breaking on a lathe - happened before I was there.
It hit him in the forehead but he was lucky, he was left with no brain injury and  piece of skull removed that left a large visible dent.
Fast rotating objects and flapping clothes or other things really don't mix!
Bob
Current build Cutty Sark, Mini Mamoli
Finished  King of the Mississippi
No trees were harmed by this message, but an awful lot of electrons were put out.
I have a basic workshop safety-rule: I keep my face/head out of the line-of-flight of spinning objects as much as possible. When working with the lathe, I am always with my body slightly to the right from a spinning chuck.
They also sell round polycarbonate shields for lathes, but they are not very convenient for precision work on small parts.
I find it much easier to wear a face shield than trying to work around the mounted polycarbonate shield.
Previous build: NRG Half Hull
Previous build: MS Bluenose
I use neither, only safety goggles (with or without built-in magnification), but then I rarely use the chucks for model work, only for my tool-making. For really fine work, where you have to look at the work from different angles, face shields are impractical.
Never had that problem.
