Still having difficulty in figuring out how to cut the garboard strake curve at the bow. If I can get this down I'll be home free. I THINK the best way is to lay the straight plank on the plans and trace the curve of the garboard strake onto the straight plank and cut it out. Am I correct?
Edited by acaron41120
Allen
Current Builds: Mayflower - 1:60; Golden Hind - 1:50
Past Builds: Marie Jeanne, Bluenose, Bluenose II, Oseberg, Roar Ege,
Waiting to Build: Swift; Skipjack
    I had that problem as well.  I read alot about it and followed many build logs.  The light finally came on when I took what I had learned and started experimenting.  By taking a test plank and sanding the bow end as I go, I test fit the plank.  At one point, the plank fit snug with little or no problem  This was normally right at the curve of the keel up to the stem.  Working it out just from plans never worked.  Test plank or cardboard template in conjunction with the model ended up working for me.
Edited by Chuck Seiler
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
But you really need to plan out all the planking runs first, or you will run planks at the bow down to points! The problem arises by running the garboard up the stem, as in the illustration above. It leaves insufficient space for all the other strakes, like crowded teeth. The only solution is to drop some strakes, which in most hulls is unnecessary. Do read the planking tutorials. It will save you a lot of grief.
Please read either:
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://thenrg.org/resources/Documents/articles/APrimerOnPlanking.pdf
or:
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://thenrg.org/resources/Documents/articles/LiningOffYourHullPlankingTutorialAndFan.pdf
Thern is so  much information at your fingertips on this wonderful site!
Actually, the trick is to cut the garboard strake so the next plank runs pretty straight to the stem (bow).
The lower edge of the garboard strake follows the rabbet at the keel. curving up at the bow. The upper edge of the garboard strake should follow the unmodified  edge of the next plank as it curves around the bow.
Each additional plank follows the same rule. The lower edge follows the curve of the plank below it, and the upper edge is trimmed to follow the curve of the plank above it. So one edge of each plank is the natural curve around the shape of the hull, and the upper edge is trimmed to fit the plank above it.
While this sounds simple, it may be necessary to "hook" planks above and below a plank, cutting it short and hooking the planks above and/or below to fill in the space.
Look at the tutorials.
Phil
Current build: USS Cape MSI-2
  • Solution
On 3/22/2025 at 5:34 PM, palmerit said:
'm still a novice. I thought the garboard strake should not make a "smiley face" (curving up) but be flat with the keel. Not true?
You are correct.  That was a poor representation of what I was trying to get at.  The updated drawing is probably better.  The key is dry fitting a plank or cardboard template so that it snugs into the curve of the stem.  As you say, the upper edge should be straight.  It will be a natural fit.
Chuck Seiler
