Has anyone else had trouble with the MDF frame and bulkheads in Vanguard Models? I have found they are very brittle and easily broken. I wish they were ply like many of the others I have built.
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
I did already email you with my answer, so here is a portion of that emial I have already sent you you:
I have used MDF for the past 18 years, starting at Amati - I am very surprised you did not know this!
As I have explained countless time now, for some of the more complex designs, ply was no good, why? Because the tolorances on the thicknesses are comical, they can be anything between 2.7-3.4mm for a 3mm thick sheet. This is OK with very simple kits (just a simple keel and a few bulkheads), but not when so many parts need to slot and interlock well - using ply would be a disaster, as batches can vary a lot in thickness.
Also to add, when sanding the bulkheads, it is much easier as the material is all the same.
Vanguard Models on Facebook
Hi Chris. Yes, I got your message. However, I was interested to know if other modellers were having the same problems or if it was just me being a klutz.
Hornet
Never had a problem. It’s much easier to work with than the old fashion easily splintered ply material. So I’m thinking you’re a klutz:-)
There are many posts on this topicin years past, mostly it seemed to me people resisting change had a bigger problem than anything related to the material. Some cheaper models may use a lower grade quality of MDF, that’s certainly not the case with any Vanguard model. More significantly the is no way Chris could create his modern interlocking designs with ply, there would be shattering and splinters everywhere.
Regards,
Glenn
Current Build: HM Flirt
