Hello Everyone ;
Beside ship modelling, I love to make something useful for myself from wood. So, I needed an angle sander for Taka's windows. I have a disc sander but, really I don't like it. Guess, I like to make it harder way.. :)
So, here is the progress ..
First of all, I really don't know why, made a sides of box. Used 4mm plywood.
When dried, determinated rail way.. And glued.
Carving sanding car for rails.
Left and right side of the sanding car.
Looking like :)
Glued second platform of the rails.
Edited by Bugra
There is nothing that a little sanding can't solve.. Bugra.
Current Builds :
H.M.S. Triton Cross Section by Bugra - 1/48
Turkish Traditional Ship - Surmene Takasi by Bugra - 1:35
Marked first floor of rails.
This is better. Have much more easier pushing.
Marked angle lines.
Again.. Marked lines for ruler and cut
Started to making angle pointer. Marked and drilled.
Shaping pointer.
Just simple for now..
Edited by Bugra
Current Builds :
And from now, it's just about to good looking.
First, making Angle Markers. Will use 2cm brass for 90, 45 degrees. And 1 cm for 15, 30 and 60 degrees.
Marked base for brass.
Glued..
Erasing curves from brass wire.
After drying, sanding with files.
Well, I think not bad for now..
Will continue tomorrow..
Edited by Bugra
Current Builds :
I will take your ideas for me, to, if you don't mind?
Wait for the rest. Al the best from me
Cristi
Current build : Sovereign of the Seas - Mantua 1:78 scale
Finished:        San John the Baptist - Cross section
                    Santisima Trinidad - Cross section                  Galery Santisima
                    San John the Baptist ( San Juan Bautista)    Galery  San John
                    HMS Victory 1805 - Cross section - Corel 1:98 scale
                    Panart (Mantua) 740 Battle Station          Battle Station Panart 740 Galerry
On Hold:        HMS Bounty 1:64   Mamoli MV39
Looks very intersting. Perhaps you can post some pictures how it works.
Regards Christian
Sure, will post how it works soon Christian..
Actually orginal photos of the idea are these..
So, here are the progress. After this, all steps are for good looking and fantasy :)
I saw this technique in Remco's HMS Kingfisher's log. Just wanted to give it a try. And the result is awesome. Especially, on irregular surfaces.
Will add some mahogany as a frame..
Scratched sides for frame.
Last view..
And this was fun.. Added some brass to the pointer. Just fantasy :)
Edited by Bugra
Current Builds :
Well, not much to the finish..
From now things are getting complicated.. Used varnish for table..
And use PVA for assembling sides and table..
Started to make holder for the rail car. Plywood has nice pattern, so made sandwich from 4mm Plywood.
I always say that I like sanding.. But this one forced even me.
Ps. Image sizes are better this way I guess.. Isn't it ?
Edited by Bugra
Current Builds :
Today worked lot. A couple hours of sanding here's our holder.
Started to looking good for me :)
By the way, I'm cleaning my sand papers and sand sticks with an hard eraser. It's very handy. I have using this stick for a long long time. Is theere any other way ? If so, please let me know :)
Yes, that's what I wanted to see for now.. Not bad and comfortable :)
Again?! I didn't like when becoming together.. Have to do something for rail car too. Tomorrow.
Current Builds :
I really do enjoy seeing very creative solutions to our modelmaking tasks.
Michael
So, I've finished Sander. The results are satisfying. Guess, car needs to ger a bir deeper. Will improve in future.
Results. Not bad, hm ?
Any ideas and comments are always welcome.
Cheers, Bugra.
Edited by Bugra
Current Builds :
Burga, the results speak for themselves.
Michael
