Hi Jason, I thought that the square top was a prerequisite only for the deck masts (fore, main, and aft)...
I think that I'll leave the top bowsprit mast round now. The black paint will cover that rookie's mistake...
Thanks for driving me to the right log!!
Edited by Stergios
Stergios
​Nice workmanship, the HMS Snake is coming along nicely.
Cheers
Geoff
Hi Geof and thanks for the comment.
Waiting to see your copper factory...(?)
The bowsprit fitted with walnut parts and cleats...
I still have the tendency to leave bowsprit and masts unpainted (red arrow) and only varnished (green arrow), just to give a sense of natural wood which, like the outer bulwarks i preffer so much...
In the other hand is the option to paint bowsprit and masts in yellow ochre...
A "decision making" is needed....
Edited by Stergios
I've left the most anterior grating unglued, as I have'nt any 2 mm anchor rope for the moment.
Do you still believe that the 2,5 mm supplied rope is so huge and out of scale..??
Edited by Stergios
I've ordered a couple of walnut dowel for the bowsprit and masts just to feel better the visual difference before I proceed to the the painted yellow ochre option...
Edited by Stergios
Cheers all
what;s the difference between 0,75 and .75 or 0,50 and .50 likes ...??  :rolleyes:
I'm thinking about the bowsprit gammoning and bowsprit's collars lines...
Edited by Stergios
I used .75mm for both (seems to be less than that anyway) as it looked more authentic comparing to the 0.5mm line.  If you plan to serve the it will also bulk it up a little.  Also, there are 2 sets of cleats to add near the base of the bowsprit for the stay collars which are easier to add before installing.
Cheers,
Jason
In the shipyard:
Hi Jason and thank you.
I think I'm ok with the pair of the cleats (see my previous pics).
Unfortunatelly I have not experience with any serving...
Edited by Stergios
Stergios, this is what I'm referring to, right behind the gammoning cleats.  There should also be another pair behind this one. I had run out of room so just had to make it work with the heart collars.
Cheers,
Jason
In the shipyard:
Jason, I cant' locate the second row of bowsprit cleats on the plans.
In the other hand I'm trying to undestand what's the reason of their existence....
Hi Stergios, here is picture from Plan 4, the two pairs of cleats are for the main and preventer stay collars.  I didn't have enough room to install both so could only install one set, but that was sufficient to separate the the collars. Hope that helps explain what I was referring to.
Cheers,
Jason
In the shipyard:
..... perfectly well Jason!
Cheers.
Well, now I believe I have fixed all the cleats in the right place.
To have enough vital room, I cut the rear pairs of cleats at a length of 3mm Vs the 5 mm of the other previously fixed.
I'm almost positive to paint the bowsprit and masts in yellow ochre but leave the outer bulwarks with that "vintage" wood appearance (like Norman ??)...
Edited by Stergios
I purchased a serving machine from Alexey here on MSW, but I have seen people build their own. (I seem to have little enough time to build the ship that I don't want to spend time building tools!)  This is my opinion only, serving the rigging components can give some very satisfying results, but it does introduce an additional time factor as everything takes longer to do.  Its also a bit addictive, knowing when to stop can be hard - and once you've started to do serving, you're really committing to continue to keep everything consistent.
Cheers,
Jason
In the shipyard:
I see...
I believe that I can live without it... Time is a major pressing component and want to remind myshelf that I bought and started this kit almost 3 yrs before...
I see...
I know how you feel :P
Cheers,
Jason
In the shipyard:
Very nice work  Stergios keep up the good work.
I am looking forward to seeing your next build, I wonder what it will be  :P
Vasileios
Vasileios
Thank you Vasileios. To see my next build (even I'm not sure what it will be, but you know my tendency..) I have to accelarate myshelf to finish my second beauty (Snake)
Next stop: started to learn how to cut the various masts sections (and especially how to make square a round section...  :o )....
