Put through and make knot
Put through and serve over. To fix last bight- make overlapping like knot.
Thank you Alexey
the above mentioned photos illustrate two different ways to secure the serving line to the main rope, right??
Thanks again Alexey, I'll show you asap.
A lot of questions before my first attempts to serving, folks:
1) For the main ropes, do you serve the sames ropes (in quality, width etc) included/indicated in/by the kit plans or other simple threads from the local sewing stores?
2) What’s the best way to keep the serving line as tight as I can around the main rope?
Thanks in advance.
Edited by Stergios
................  I'd also recommend you buy some GS-Hypo glue, it works really well with rigging.  Dries clear and slightly flexible, works well on false splices.
Hey jason
Have you figured out the bonding strength of hypo gs glue?
It is somewhere between pva and cyano or stronger?
Thanks.
1) For the main ropes, do you serve the sames ropes (in quality, width etc) included [indicated] in [by] the kit plans or other simple threads from the local sewing stores?
Thanks in advance.
I've never done serving (yet), but everything I've read indicates that it is done with a much smaller rope or thread around the larger rope.
Watch the video from the Alexey on Youtube - http://youtu.be/o5gZQRN6yoU?t=7m22s
You can see in the video how he uses what appears to me to be thread, or possibly very fine rope.
Hi Brian and thank you for stopping by
I have well understood the basic options for the serving line.
My concern for the moment is the main (served, larger) rope and whether should I use the original from the kit or regular sewing rope from the stores...
Cheers.
Stergios
You mean the rope that you are doing the serving on?  That rope should be the standard rigging - so if you are serving the top of your shrouds for example, you would use the regular rigging supplied (or something like Chuck's rope if you are replacing the kit rope) and then 'serve' that line with thread or very small rope, much like you would seize the normal rigging with thread.
Since the served rigging is typically not served for the entire length (with some exceptions), it wouldn't work to use a thin thread as you would then need to somehow attach the thicker rope for the non-served part.  The served part should appear thicker anyway, since it's been wrapped with another smaller rope.
Back to shrouds as an example, most shrouds were served where they go over the masthead (I think that's what it's called.  At the top of the shroud in any case) for a short distance, but were not served from there down to the dead eye.  The exception is the trailing shroud where it might be exposed to sails which is often fully served, but even in that case, you would use the full sized shroud line and serve it.
Hi Stergios,
I used all of the ropes included within the kit. I kept the rope as tight as I could just by keeping it hand tight as I served the ropes. you will see it is easy.
Hope this helps,
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Hi Stergios
I used the rope diameters as stated in the plans. To do the actual serving my current method is as follows:
Attached the line to be served to the serving machine having confirmed the length to be served.
Pass a sewing needle through the line at the start point and leave it in the line. Thread the serving line into needle and pull through. Keeping needle threaded, pass it through the same point gain at 90 degrees to first pass.
Knot the lines with a basic knot and dab a little watered PVA on the knot. This will hold fast and you can start serving immediately before PVA dries.
I use my right hand to turn the serving machine and my left hand to hold the serving thread. I use my index finger and thumb to hold the line keeping it slightly taut and slightly ahead of the serve, whilst allowing line to pass through as the serving takes place.
Once at the finishing point you have to be careful. Pass a needle through (still holding serving line in left hand!) at the ending point. Thread the end of serving line through keeping taut. Pull needle though twice as before. Line will now be held. Knot and glue with watered PVA.
I will post some pictures later if that helps.
Jim
Current builds:
HMS Snake
HMS Hood
Mechanical Solar System
Completed builds:
HMS Ballahoo
Brian, Mort and Jim
thank you so much mates for the continuous support and your time to typing!
Edited by Stergios
Hi Stergios
Jim thank you again
Now, I think I've understood clearly.
In case of need I'll recall!
I've concluded to buy new ropes (to make the serving on) from local sewing stores. I can find better material than those of the kit or those from the cornwall model boats. All I need is to have the same diameter, as the plan indicates.
Hi Stergios
Jim, do you use any pva glue or something to make the serving more secure around the main rope?
Thank you.
Thank you again Jim!
I'm "practising" myshelf all the time this Saturday.
I'm about to show you my progress following Jim's recommendation to serving.
Photos to follow later.
gia sou ksana Stergie
pantos prohoras arketa grigora. to log sou fenete oti parakolouthite apo arketous pou sou dinoun ke arketes simvoules.#
kali sinehia ke kali doulia :piratebo5:
Costa se efxaristo
to grigora einai poli sxetiko....
Ena apo ta pleonektimata ton mi Ellinon einai oti efkola kai aploxera sou metadisoun ti gnosi kai tis simvoules tous.
Kali sinexeia!
Well it's time to present you my progress according to Jim's steps and recommendations.
First of all the serving lines I've tested are 1) regular sewing cotton line No 10, 2) a 100% polyester line and 3) regular sewing cotton, from local stores.
I've used a simple white [for contrast] main rope to serve
The first passing of the serving line
and the following second passing of the needle at 90 degrees compared to the 1st one
Here is the serving line after the 2nd passing and
a simple knot is ready to follow
The knot is then tightened
and the free adge of the serving line trimmed with a spot of undiluted pva
...which is slightly pressed against the knot, before the starting of the serving
... to be continued.....
Here is my 1st attempt using the cotton line No 10
A photo shot showing the three different serving lines (cotton 10 on the right, polyester in the middle and cotton 40 on the left) from a distance
A close up view of the cotton 10
A close up view of the 100% polyester line
and the close up view of the cotton 40...
For the mo I really don't know which one is the best to use as my serving line....
That's for today
Thanks again.
Cheers
I mean about that kind of seizing.
It seelms to me very risky, especially using served rope to do that zip seizing, don't you think?
Today, I've found time for practise on seizing the served ropes. I generally like the style of the zip seizing, so my basic concern was to see whether was possible the served rope pass through the zip seizing ("hangman knot") without any damage of the serving line...
I made my 1st zip seizing turning 5 times the #10 cotton line around a 1,5 mm wire. This is the preliminary result
This is another try turning 7 times the #10 cotton line...
Alternatively I have tried this seizing with 2-3 simple knots around the served rope,
but I'm not happy with the result
Edited by Stergios
That;s a picture showing the final result of a zip seizing of 7 turns of the #10 cotton line, after the trimming of the free edge of the rope.
This seizing seems to me a little oversized and the main rope not so centralized to the seizing....
Any comments and advices, as always are appreciated mates.
Thanks.
It looks good as far as technique goes, but I think your seizing should be much smaller diameter rope - like thread sized probably, or very small rope - and it would look better.  When you look at photographs of real seizings (for example Google search images for the Constitution rigging) the seizing rope is very small in diameter compared to the line being seized.
Here's a nice photo (linking to a Flickr page) - https://www.flickr.com/photos/ghrs47/14580207322/in/pool-old_ironsides
Make sure to click on the image to expand it to full size and you can then scroll around the image by moving your mouse.
If you look at that full size, it's still difficult to make out the seizings on the shrouds, but they are visible.  You can also see numerous other seizings on the other rigging lines, and they can all be seen to be very small rope relative to the main line being seized.
Edited by GuntherMT
