Do you feel that the kit manufacturers give you enough bulkheads to affix the planks to. Most kits look like they have a very long reach between stations. Or would more bulkheads be an extra burden to have to set to the keel?
I would definitely prefer more bulkheads. But more bulkheads come at a cost too - they need to be carefully positioned otherwise it would be difficult to cut out some gunports!
Edited by KeithW
Regards, Keith
  If you look at the stem and stern area, it is advisable to use balsa blocks to aid in glueing the planks on. I always found these areas more trouble than the long runs.
 Some builders I know, say they get a starved horse look between bulkheads and use blocks as well there.
 If you glue blocks in, shaping the bulkheads does become easier. But personally I think its more work than I want to do.
 Dave.
I added extra ribs/bulkheads on some places ...
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Also, Chuch is designing a POB kit for Winchelsea, and he make much more bulkheads then usual, specifically to make the hull lines smoother and planking easier. Here is the build log: http://modelshipworld.com/index.php?/topic/99-hms-winchelsea-by-chuck-1764-english-32-gun-frigate-pob-164/
In a word YES.I am now full convert to full timber infill of the lower hull.Even if you plank the model and don't have dips or flatspots,they can appear years later if the model is subject to a humidity change.Lots of bulkheads would cure this,but on a kit,it is easier to 'fill and fair' than add more bulkheads.Many Eastern European,Ukranian and Russian masters infill their hulls or use a design that creates a semi solid hull,so it is certainly more than just me that believes there is mileage in this technique.
Kind Regards
Nigel
Currently working on Royal Caroline
Manufacturers put just enough to get a shape.  This helps to keep the cost down.  However over the years I have found that filling in between the bulkeads makes for a better gluing surface.  You can also now easily visualize how the finished hull will look and make symmetrical.
David B
