I'm sorry, Mike, but you said (a little above, on 26 July):
Just make sure that you lay your planks naturally against the hull, and don't try to bend them laterally against their width.
and that's exactly what I've been trying to do!
Current build: HMS Pegasus
Previous build: HM Brig Supply
Mike is right in what he has mentioned to you, if tapering the plank does not close the gap leave the tapered plank lie naturally and use a stealer to fill the remaining space. It is all still going to work, not to worry there, we are not criticising only trying to help. Please do not take anything the wrong way
That's ok Buddy, two hours in dentist chair would have me going straight to liquor cabinet :P
No worries.  There is such a thing called a "plank nipper" or the like that makes narrow cut into the underside of the plank to help with bends.  Similar principle to what you are doing, but no chunks are taken out.
Don is right on the use of tapering and stealers to plank.  Use the first planking as a practice run for the second planking.  In some respects, the second planking is easier in that you have a solid foundation to plank on - for example, you don't need to pin the planks to the bulkheads, but use pins, etc. anywhere along the planking line (just don't put the pins in the plank itself!).
I've pinned a temporary batten to guide the top of the wale. Like others, I was a bit puzzled by how the wale should curve at the bow and stern, and I've just let the batten relax in what seems like a natural curve fore and aft.
On another topic, this thing (I find it hard to describe it as anything else) has just moored next to HMS Belfast here on London River. Cheek!
https://www.theguardian.com/world/2016/sep/06/russian-billionaires-superyacht-makes-waves-in-london
Thanks, Spyglass. I did take them from the plan, the problem I had was measuring the extreme forward and aft ends where there aren't any easy reference points. I have just remeasured and my marker batten is actually spot on, to less than 1mm.
From the TFFM series, the wale sorta flattens out at the stem and doesn't continue the upward sweep.  On my Pegasus, I found that this naturally happened given the curves at the stem so I didn't need any special bending or shaping.  If I remember correctly, this started happening halfway between the first gunport and the stem.  It's very slight though.
Here is why my log starts with the wale in case you're interested:
http://modelshipworld.com/index.php/topic/7267-hms-pegasus-by-landlubber-mike-amativictory-models-scale-164/?p=329358
Edited by Landlubber Mike
I think so, Mike, although it's very difficult to tell.  (I did read your log, and found it very useful. Especially the batten idea, as you see here.)
Edited by herbgold
You sorta have to guess a bit where the wales end up at the stem - look at the head-on picture in the plans which might help.
Using the temporary batten to mark the run of the wales works nicely.  I wouldn't use it as a template to run the actual planking against.  It didn't really work out all that well for me.  Instead, I would think about running tape, etc., then marking the line of the wale.
One thing I did was rather than do the full second planking and add a 1mm strip for the wale was to use a 2mm strip for the wale directly on top of the first planking.  It made for a cleaner look I think rather than seeing partial planks above and below it.  If you don't have 2mm strips, you could always laminate two 1mm strips together.
Thanks, SpyGlass. I measured down from the very top of the gunport strip to the bottom of my temporary batten, and get 29mm, which I think equates pretty closely to your 23.35mm measured from your extrapolated line.
Edited by herbgold
Just to add one more voice to this already insightful discussion, I'll reiterate that you can make precise measurements, but then as you eyeball the wales, you might just find that they sweep up too much.  That seems to be the tendency, and it's also why LL Mike's idea of using tape instead of a batten works well, since tape is easier to adjust.  In the end, I think everyone's wales ends up in a slightly different alignment.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Just to say that I haven't given up in spite of my long absence from these hallowed pages... I started two new history courses and my time has been taken with reading and attending lectures.
I'll be back - probably not before next March!
Edited by herbgold
