Mike Dowling
Everything posted by Mike Dowling
  1. I think the deliberate mistake was the left hand end panel as you look at it. Do I get my plane ride ?
  2. I think I have gone as far as I dare now going from the top down. Clinkering is becoming a real problem so I think I have to go from the bottom up to meet it. I nearly got to the waterline at the front which was my hope.
  3. Those pictures Thunder are really useful - thank you. The only pictures of the full boat are one on the plans. Otherwise the picture on the box is all I have to go on until now.You are more than welcome along for the ride. I just hope I can be helpful to you as well. Don't be put off by the planking. If I can make a reasonable job of it then anyone can. Planking is not my best point ! Having said that my objective on the first layer was to experiment a bit and at worst simply cover the hull. It actually came out better than I expected and now with a smooth 'whole'surface the second layer is proving quite successful I think. I did buy a whole batch of new walnut for the second layer because the stuff with the kit was so old it was very brittle. I think it was a good idea although the quality of that which I bought is nothing special. I have managed to get two whole strakes on and the second wale. It did need soaking and CA to hold it on but it didn't fit too badly. I now have two more strakes underneath that. I want to get at least two more on before working from the bottom up because I want to try and get to the waterline first. Then, if it is a bit patchy below it won't show especially if I paint it. I did read somewhere that the bottoms of these were copper plated. I wonder if that is right and if so should I paint it copper rather than white ? There is no way I am actually going to try to plate it.
  4. Thanks guys, unfortunately I don't have thinner wood I don't think so I guess - press on and hope !!!
  5. A situation report ! I have done the shaping around the bulwarks and I have done the second planking from the first wale upwards. The second wale goes 8mm (2 strake width) below the first and it is wider (5mm x 1.5). I have curved the bow by soaking and bending as before but it really doesn't like the inevitable lateral bend that has to happen to keep it parallel to the first wale. I think I may have to put it on wet and let it dry in position. I am not sure whether to force two strakes on below to top wale in order to get the width for the second right or to taper them. Below the second wale the tapering has to be quite severe - I just hope I don't get much clinkering. It is tricky because it is only a wee little boat but very bendy and the strakes are 3x1mm. Any more advice would be welcomed before I start going down !!
  6. When you say 'create a line and stick with it' what do you mean ? I don't understand. I don't think the bow looks too bad but I am seriously concerned about how it will come out with the thinner second layer.
  7. No solid blocks at all on this beasty Thunder ! and it would seem from Brian's photos that these vessels were indeed planked strangely. With such a bulbous front I don't think there would be much choice. Guys, I took on board all the advice - thank you. I gave the hull a rough sanding and then sealed it with sanding sealer to stop it being too absorbent. I then applied filler in my normal way which is to spread fine surface, very wet filler with a pallet knife. That way the filler goes on pretty smoothly and without leaving too much excess. Leave to dry and then sand the whole thing again with a less aggressive paper. This is how she looked after that. A somewhat prettier site !! My next job is to remove the excess planking that I deliberately put on down the level of the bulwarks and make her look more boat like.
  8. Well folks, the hull is finally covered ! It is not a pretty sight but it is covered !! For discussion - should I sand first and then fill or fill first and then sand ? Usually I apply some sanding sealer before filling to avoid the wood swelling with water based filler. Also any tips or points to watch on the second planking with walnut? It is not a wood I have used before for planking and I know it can be rather brittle.
  9. Did you choose the colour scheme yourself or is it based on the real boat ?
  10. Oops! If you cut some of that frame off won't you be able to rduce some of that angle. I reckon you might be able to do that with a fine saw without taking anything off ? Just a suggestion.
  11. I think that's a lovely job Gregory especially for this 'round' boat. I hope mine turns out half as well.
  12. Hey Eric, great to have you along for the ride. As you know I need all the help I can get with planking especially on this small bendy beast. I have started from the garboard up and am indeed tapering the planks. The supplied wood is complete rubbish but I am trying to use it. I received some lovely lime strip today which I can use now before my language gets too bad !! The second planking is walnut strip which I have never tried before. I have always had sapele before. Any tips in advance before I get to it ? (I did get some new walnut in case!!)
  13. Very observant of you !!!! Especially as it was only on one side.
  14. Just what I thought Brian !! Can't say I did Popeye and , to be quite honest I still can't see it !
  15. Thanks Popeye and Hubert, the pictures are really helpful, thank you.
  16. Just another question - should I taper the garboard at the bow and continue the taper with subsequent strakes until they meet?
  17. Thanks for that Popeye. I thought that's what might be best. I understand the 'stealer' and such but my idea was that if I got the first planking right it would make the second so much easier. I think most of my difficulty, apart from being a rubbish planker, is that it is a very small boat for such a bendy bow ! Re the PM's. I don't understand - I have received nothing from you ??
  18. Please can someone tell me where I went wrong. I have had trouble before because I didn't taper strakes enough so I tried to make sire I did enough early enough. I am however left with a very unpleasant hole to fill in and some clinkering at the bow. The remaining spaces with my current tapering seen to be about right but I am going to have a big hole from about bulkheads 1 - 4. So, not only what did I do wrong but what should I do next ? I don't think I can strip anything off because, as I usually do I glued stuff on too well.
  19. The first planking is taking forever and I think the bottom part is going to be a bit 'patchwork'! It may well be that I over tapered some of the bow strakes to early. Anyway, I will get it covered and adjust my technique for the second go. Whilst waiting for soaking wood to dry I have been making the top rails. This involves laminating 4 pieces of 2mm x 1mm walnut together whilst bending them in jig. Not an easy task! On the outside a further 2 pieces, one of walnut and one boxwood 1x1mm have to go on the outside. There is less than 1 inch of excess wood !!! I have surmised that Mamoli kits are not for the fainthearted and definitely not for the beginner.
  20. Pencil along the edge has always worked well for me for caulking. Use a nice soft pencil and I always hold a bunch of pre-cut lengths together and do the sides like that.
  21. Whoever said that Mamoli were mean with their wood were quite right ! Not only mean but some timber missing altogether. Thank goodness I have a lot of leftovers having been very careful in the past.
  22. This is the best google translate could manage so thank you Hubert. Very helpful. The only comment I would make is that I NEVER use contact adhesive. It is horrible and totally unforgiving. I always use white wood glue or occasionally a very small amount of CA. Hi Mike, here an article from me in German for my forum on planking. It is an absolute MUST that the straightening of the ribs with a strake-line (as it seems to me, for some a disagreeable, but by no means exceedingly important work) is carried out with painstaking precision. Also, a Auffütern on the ribs can sometimes be necessary to ensure the lines. What is ground too closely here, must later be compensated with spatula and regrind and multiple labor input. , For the Unterbeplankung I cut myself with a large circular saw with guide rail of 5mm pine board bars with ~ 2.5mm thickness. There are then quite a few tenths mm tolerance in it. The bending of the strips at the bow is done by slight buckling in 5 to 10mm intervals, depending on the desired curve of the strips. This allows me to bend the bar practically as I want it and need it. With the bending pliers in about the same kinking effect is generated. To the rear of the bar must then be partially twisted in order to sit well and over the entire surface of the frame. This works perfectly with the spruce strips. It is glued with express wood glue and the strips are fixed with model needles to dry. Glued is not only on the bulkhead, but also (important !!) the whole length of the strips with each other. This results in a very compact, solid hull at the end. Due to the thickness of the strips, I have enough "meat" when grinding to produce a nearly perfect outer skin. Due to the tolerance when sawing the strips, it may happen that in places minimal fillings with wooden spatula are necessary. The shape of the plucking is absolutely nothing nachzuspachteln! A perfect Unterbeplankung I need it because the 2nd planking is done only with veneer (0.6 to 0.9mm). With this thickness, I could hide absolutely no more mistakes. The veneer is applied with contact adhesive. For the hull with liquid veneer with gel. Gel is cleaner to work, you do not smear everything completely and it does not pull strings. First apply the bar exactly with little pressure then a slight gap can still be pushed. Only with perfect fit press the bar. With a small metal ruler, the bar is then finally pressed. In doing so, I drive with the front of the ruler over the entire length with great pressure. The quality of the strength of the contact adhesive is achieved by the force of Andruck`s, even if it takes only a short time. The high pressure can in turn be exercised only if the Erstbeplankung has the appropriate strength. The first plank has to be laid as planned! As far as mine, for me very good working method, Greeting Hubert
  23. Thank you very much for your long reply. I will try to get it translated so that I can understand it.
  24. I just use a paintbrush for PVA, various sizes for various places. By the way, I always water mine down a bit a put it in an old cream container.
