Mike Dowling
Everything posted by Mike Dowling
  1. I have just measured the remaining space on the widest bulkeads left to plank. 3 of them are practically 10cm. The space left on the bow is 5.5cm if I can remove 3 strakes or 4cm if I leave them. The longest remaining distance or length is 26cm. The strakes are 5mm wide. The lowest one on these pictures is not yet glued but I might be able to remove the three above it. I am not sure but I think you will know - if I started at the keel working up I think I could get in even more of a mess?
  2. Hey all, thank you very much for your posts and suggestions. What I think I will do is take a picture of the bow so you may be able to tell me better where I went wrong. It started off OK. I think, if it is the way forward that I can remove the last 3 strakes from about the middle of the hull (longitudinally) to the bow. It might take a bit of soaking but I think they would come off. I will also do some measuring and see what that suggests. Not quite sure I understand your trapezoid idea Al but might PM you on that if you don't mind. Thanks Dom I see what you mean but I am not sure which side of the strake you taper. Is it the side nearest the hull or the top deck? I may not do much today as it is my Birthday but will get back to you all as soon as I can. Again, thanks so much.
  3. Hi Hamilton, thanks for the post. It might look great but I have a nasty feeling I have some undoing to do! I don't think I have put the bowsprit (?) on yet but as she is she measures 62cm stem to stern.
  4. Thanks CF. No you are quite right I haven't tapered any planks yet. I really am trying to understand your help. Do I need to go back and try and remove some planks or can or taper from where I have got to now. Which side of the plank do I taper from? I believe I have to leave one side untouched in order that the next one has a flush surface, is that right? Since I haven't yet worked up from the keel how do I work out how many planks I need at each place? I am sorry to be so thick but I really am trying to get this right. I can't understand why the stern is OK but the bow is going wrong. I will check out drop planks tomorrow but if you can think of any other way you can help my simple brain please let me know.
  5. Oh thanks! That really doesn't help me now. I don't understand early tapering, late tapering, intermediate or how to do it despite me begging for help from the beginning. I will have to do my second effort differently but hopefully one way or another I will have a smooth surface to play with!! This is fun, I am enjoying it. This is fun and I am enjoying it. This is fun and really, I am enjoying it!.
  6. I have done the wretched pots but am not happy with my foliage yet and I wouldn't put them in until I have finished this wonderful and truly liberating experience of planking!! Do you notice a small sense of irony creeping in here? Anyway, I though we had agreed that our models were going to be post mutiny without breadfruit! Thanks for the nice comment about my transom!!! I am having serious problems with my bow and am beginning to understand why I should have perhaps stopped and worked up from the keel. I am beginning to have serious clinkering problems. I don't know whether to put in some wedge shaped 'stealers' now or see how it goes and be prepared to use quite a lot of filler afterwards. Can anyone help?
  7. If I can interfere with someone elses build I would suggest Al that you mark out where the holes will be as you plank over them. You can then cut down on the planks covering the holes with a really sharp xacto afterwards and just file or sandpaper the edges .
  8. CF! You can partially ignore the PM I sent you because I found your log!! The garboard is what you said which is why I stopped and carried on downwards. Thank you for saying she is beautiful because as you well know I am not planking to the rules. I guess your question re the deck edges refers to those that will be seen on the exposed hull? The instructions say paint them brown but I have seriously been thinking of putting an edge strip on them - I think it would look a lot better.
  9. Some more progress ? pictures. The lowest strake here isn't glued yet - just moulding!! The extra bit of wood is moulding again.
  10. Hi, I found you!! Your model looks pretty good to me. Do you have to add your bulwarks and some deck features before the dreaded planking? Glad you and Al are keeping an eye on each other as well.
  11. Morning all, thanks Capt Fisher for your post - I must try and find your build log. I'm not sure if I have decided or not but for the time being I am continuing to work downwards. I guess the difference for us is that one side is mostly unplanked, yours more than mine in fact. I am rather afraid of ending up with a really narrow plank if the bottom meets the top is you know what I mean. If that happens I would rather it was near the keel as I don't think it would show too much. As Dom rightly says you can always plank it twice if you want to or conversely I guess and if the first layer is really good leave it alone! I don't envy you the walnut at all, it is so hard and brittle. Someone suggested to me that Beech is really good. Anyway I will try and get a couple more pictures on today.
  12. I do hope so, otherwise I might just have to paint my nails!!!! If you know what I mean?
  13. No new pictures to show yet but, the planking continues. Now, call me stupid but, owing to a fairly serious battle I had trying to do what you experts out there call a 'garboard strake' I decided in my beginners innocence to continue planking in a downward direction. So far (!!!!!!!!!) it seems to be going quite well. Do you think I am going to hate myself when I near the keel? I think it was CF who said don't leave the garboard until last.
  14. Hi there, nice to see how you are getting along. Your first planking doesn't look too bad to me. She is an awkward little boat, the first one I tried and I didn't have a clue about planking. Still don't to be honest. She is a bulbous beasty as is the Bounty I am trying to do now but will make up into a smashing little model. I have to confess I didn't try to do the sails but did do all the rigging. Anyway enough of my blether. Good luck to you and having had peritonitis a couple of years ago you have my sympathies so I hope you get back to good health quickly.
  15. Oh my, you are getting more than your fair share of problems. I only had a little bit of 'jiggling' to do to get mine to fit between beams etc. Mind you your cabins are far more detailed than mine, I just hope that all your hard work and efforts will show in the end. I am still fighting strakes, something I am getting used to as their is still so much to do. Dom doesn't like my straight planking but it is the first layer and I am only following my equally pathetic instructions! I agree with one of our colleagues out there - sometimes I wonder if we are scratch building!! Might as well for all the use the plans are. However my friend, neither you nor I as complete novices are going to be beaten are we!!! We will win some kind of victory in the end and, before you say it I know we are building the Bounty, not the Victory!!!
  16. Well thanks guys, I am blushing but I know you can't see!! Windows 8 is the worst thing since Windows 95 - that worked just fine! So, do you think it's time I started at the keel and work up? So far, apart from the stern a little bit I haven't got involved in much lateral stress to the strakes. Is this good or bad? I know I have to wait until I have finished the first go but, inevitably there is some unevenness evident. Should I just sand everything smooth, fill it first or a bit of both? PS. Sorry about your cold Dom, just keep knitting!
  17. I have done another row of strakes today and am now just below the level of the second deck. I am thinking maybe now I should be working from the keel up. Any thoughts?
  18. Thanks very much Al. I haven't really got to cover much of the filler yet but yes, I do think it was a good idea. One of the hardest things I am finding is that with this very springy wood it is difficult to hold down whilst gluing so, the greater surface area with the filler has to help. So far I have only used CA once and have managed with white glue but I can see that changing when I get to filling in gaps. I'm not sure if you have too much visible on your hull but if you can I would certainly fill the stern area. You have loads more formers than I in the bow so you probably won't have to fill there.
  19. I am experiencing an interesting problem with my lime wood planking. The wood is 2mm x 5mm. When dry it snaps pretty easily and when wet it splits equally easily. If I soak it for between I guess 1 hour to 4 hours it does become quite flexible and fairly easy to bend but tries very successfully to straighten whilst or after drying. If I soak the wood overnight it actually becomes harder again and very difficult to bend. I just wondered out of curiosity if anyone else has found this. It was suggested to me somewhere along the line that Beech wood is more user friendly and maybe I should have ordered some to replace what came with my kit.
  20. Hello everybody, thought you might like to see how my feeble attempts at planking this monster are going! And here's one I made earlier!!!
  21. Al I'm really sorry as I did't reply to this very well if at all. Now I have got a bit further on I would go for the 80 to 90 percent open!! I envy you your 1mm strakes although I think I would be far too tempted to do a bit of lateral bending with those1 Still, did anyone actually say that the Bounty wasn't clinker built? I am using at Dominics brilliant suggestions for holding the wood in place. I am bending where necessary as much as I can when wet by hand or with a plank bender. Then using the hull as a jig effectively while they dry and managing mostly to hold them in the right place with pins at the sides. The strakes do split very easily if I try to pin through them so that goodness I am not using the instructions using the supplied brass pins. Anyway, once the strakes are practically dry I glue them in place, use the pins again and if I am really lucky use the same holes. Lots of PVA glue and a prayer with every piece!! I will try and get a couple of pics on later.
  22. Hi Al, I can only agree with the last two posts, you are doing an amazing job. I think you said you were obsessive and I think you were right! I use what I think are called side cutters for cutting the eyebolts. I can't say they cut absolutely flush but pretty darn close. I had the same problems with the rings OcCre supplied, they were all too big and I had to make my own, you see I too can be obsessive! Keep up the good work.
  23. Thanks for the posts Alistair. I am not finding the big bends too challenging, the lime wood is quite obliging for those. It is the little more acute bends that are the problem. I have resorted to soaking them for hours and then found either thumb nails or gentle work the bender works ok. Interestingly with the lime wood really wet the plank bender won't cut through even if I try! The lengthy soaking does mean progress is very slow, about two planks per day but, I am in no rush. I hope to get to about 1/3rd of the way today.
  24. The more I look at the AL kit the more differences I see. Unfortunately (because I am building the OcCRe version) the AL kit is far more detailed, below decks anyway. I know the single planking is a hazard for some (particularly me) because you have to get it right first time. If I had realised there was a choice I would have gone for the AL. Too late now I have to do the best I can with what I have.
