Mike Dowling
Everything posted by Mike Dowling
  1. Happy New Year to all. A big thank you to Cap'n'Bob and GuntherMT for your generous comments. All I had to do next was put the bits together, add the awning a some deck furniture and Louise is now finished. She turned out quite well I think. I did go to the extra expense of buying some brass rod because it gives a much better result. Why do these kit manufacturers include brass wire wound up ? It is impossible to straighten properly and gives a very poor finish although I have to say I used their stuff for the boiler fittings. Anyway, I hope you like her.
  2. Sorry, I have rushed ahead somewhat without many updates but here we are. I managed to bend those cockpit surrounds and the trim to go with them and the splits I got have fortunately come out better than I expected so they are now on and varnished. The boiler I worked on whilst waiting for the surrounds to dry. A lot of wire bending as you can see - not my favourite part as I have always preferred woodwork to metalwork but I am quite pleased with the final result. Then the cabin had to be made from individual strips of wood, no laser cut ply backing for this ! A good lesson in marquetry I guess, not something I had tried before but I can include pictures of the making and the finished item.
  3. I thought you might like to see my progress. Louise has had her frames removed and now has her keel, her transom piece, her wales and the floor and deck have been planked. Next stage is to put some frames back in - weird eh ? I have also been bending the wood for the cockpit frames. Those are quite some bends to expect from 1.5 x 7mm sapele and the eagle eyed amongst you will notice that both bends split at the tightest part. I can't say I am surprised but I hope my repair will have worked when I remove them.
  4. Here we are again !! Louise now has a layer of planking on her hull. The wood used was 2 x 5mm sapele which in my humble opinion was too thick for a boat of this size. It was difficult to bend and much prefers to return to being straight. What I thought would be a problem was in as much as I couldn't glue the planks to most of the frames because they have to be removed and even trying to glue the plank edges meant missing out the areas of the frames. Anyway she has been sanded and sealed but, if I leave her as she is she will still be sanded again and have at least two coats of clear gloss varnish eventually. I am hopeful that that would make the lines between some of the planks less noticeable. My question is does she need planking again with veneer or is she OK as is ?
  5. I guess you could turn this into an RC model but it might be a bit small.
  6. So, I have made a start. The hull frames are cut in half which means that each side has to be attached to the false keel separately. A rather strange and unnecessary complication to my mind and very difficult to line up squarely. Three of the frames had to be planked and varnished prior to attachment as they will show from the top of the boat and there is no access once the deck is on. The added complication of this build is that five of the frames have to removed after planking so they are only there as guides and cannot be glued to. This has proved to bit a bit of a nightmare. Once the frames were attached a 'ribband' had to be run along the length of the hull but only attached to the non-removable frames making it hard to glue bendy pieces of wood. Anyway, once on the deck had to be cut out and glued onto the ribbands and fixed frames. The sheet containing the deck was poorly cut with the laser which had failed to cut right through the sheer so some delicate knife work was required to remove the parts. Finally achieved the deck has now been fixed on and I have faired the hull ready for planking with 2 x 5mm sapele planks. One rather good thing about the kit is that a set of veneer is included for those who want to double plank the hull. I think in view of the construction this may well be required but it is nice to know it's there in case.
  7. Hi everyone. Thought you might like to see my next build. This one is to tide me over until I start another big build. Louise is a small Victorian steam launch, the kit from Constructo who I have never had anything to do with before. The kit arrived in a nicely packed box with various bits and pieces in numbered bags that are referred to in the parts list. The build instructions are in a booklet in about a zillion languages including English accompanied by a booklet of photographs at various stages of the build. There is also a 1/1 plan sheet showing side elevations and various parts of the build including the boiler construction and that of the cabin. The only laser cut parts are for the deck and the hull frames. The rest of the kit is various sizes of five different types of wood which seem to be of good quality.
  8. Really valuable point there Keith, easily missed I think but very difficult without the extra plank. Of course 'anorak' is a compliment after all, they keep you prepared for all weathers !!!
  9. What happened to 'if I can do it then so can you' !!!
  10. Why don't you use cellulose sanding sealer (aka dope for model aircraft enthusiasts). You can make it as thick or thin as you like, it dries really fast and if you want you can make a really good satin finish with just two coats. Or you can easily sand it down and put any paint or varnish on top. I grant you that it does darken some wood a bit.
  11. Hi folks, May I say a huge thank you to everyone who has taken the trouble to send a post on both my log and my gallery. I am really flattered and grateful that you consider the work of a novice builder to be worthy of such praise. I am not thinking of making a case for her as it would cost almost as much as the original build. I realise that she will gather dust but eventually that should 'age' her nicely and provide a home for the odd spider or two. Sadly in a way not that many people will ever see her so her preservation is not so important. For me the joy is in the making and a satisfactory end result which I imagine applies to many of the MSW members. I am going to have a brief sabbatical and make a horse drawn taxi next to keep me occupied but fear not, I shall return with a new build when I have decided which paddle steamer I am going to do. I have done one, the Spirit of the Mississippi (another OcCre kit) but I want her to have a companion so I have big hopes for Christmas. Thank you all again for your very kind comments.
  12. Greetings, After 8 months my OcCre Bounty is finally finished. It has been a huge learning experience and mostly a great deal of fun. I didn't expect the hull planking to be so hard and likewise the rigging. In the end I am glad I gave her sails, as someone said a sailing ship should have them and I guess they were right. Before I let you see the pictures, in true Hollywood style I would like to say a few thanks. Firstly to those on MSW who gave me such a warm welcome in the first place and some who continued to follow my log. To Capt.Al who has shared his build with mine, been a huge help with research and companionship. To Dan Vadas who, despite being an experienced ship builder has always found time to help a novice. To Cannon Fodder who tried so hard to teach me hull planking. To Shihawk who kept watching and boosted my flagging ego. To Fifthace who gave friendly criticism and a lot of advice and to Bindy for her amazing enthusiasm, her sense of humour, her bravery and her friendship. And now Ladies and Gentlemen I give you the Bounty, may God bless her and all who sail in her.
  13. Greetings!! I hadn't realised it was over a month since I reported in but here I am. Firstly I must include my sincere thanks to Dan Vadas and Capt.Al without whom reaching the stage I am at would have been quite impossible and so I really want to express my gratitude to them both. Well folks, after much thought and heavy persuasion from members of the family who told me my boat would not be complete without them, I decided to go for broke and put sails on the beast !!! I failed to follow advice from those on MSW and put the yards on first because I decided to follow the order of my woefully inadequate parts list. There was after all a great deal of rigging to do once they were on and before sails were added. Someone had said attach the sails to the yards first but in all honesty I was glad I didn't as I could never have attached the yards properly with sails attached. However I must be equally honest and say that attaching sails afterwards has been very fiddly but then this whole rigging lark is. It is quite amusing in a way - the instruction booklet I have has some photos in it but there are at least two if not three different rigging setups. The parts list is different again, it is completely different from the AL version and the McKay book! Suffice to say that thus far I have had to use average opinion and an amount of what I like to call 'maritime licence' !!! I know there are one or two bits that are totally wrong and the same that could be right. Apparently when Capt. Bligh took on the ship he re rigged it anyway to suit himself so I am quite sure there must be several acceptable ways. Anyway, I now have all the 'forward' facing sails on and rigged. I still have what I call the 'sideways' sails to do, the lifeboat to fix on, the open side to 'accessorise' and some general tidying up to do before I can call it finished. I'll let you see it when it's done.
  14. A nice bit of work but I have to say it doesn't look anything like my OcCre Bounty stern. That doesn't mean it isn't right mind you mine could be completely wrong.
  15. OK fans, this is where I am! I have done all the standing rigging I can until I have to fit the yards. I am told that, if I am going to fit sails onto the boat I should attach the sails to the yards before attaching the yards to the masts. I am at that stage and would value the considered opinions of anyone out there who cares - do I try to put sails on the boat or not? It is completely new territory for me as I have never done it before. I eagerly await your responses!
  16. Thank you all for your kind comments. Captain Al has very kindly sent me some pictures of rigging which are proving to be very useful but Capt.Fisher if you can send more I am grateful for any/all contributions. The rigging is proving harder than I thought and I am only able to follow the order in the parts list to give me any clue. I can't believe Al that you tried to count the knots - you really should get out more! But, in answer to your question about wood, I know I am very careful not to waste anything but I have more than enough wood for this kit. I have always found OcCreto be not exactly generous but ample with their supplies. Maybe I should have a word with the forum moderators and see if I can create a new list of 'words' for the use of frustrated modellers! I must also add a big thank you to Dan Vadas who was a tremendous help with regard to the placing of shrouds and without him I would not be where I have got to.
  17. I really couldn't say I'm afraid. Every Bounty model I have seen so far has been different. This one has been and still is pretty hard but I am only a beginner and really should have got a simpler model to start with. But thanks very much for the comment.
  18. Hi there viewers! An update for you. After a great deal of eye strain, some new terms of abuse invented and at times a serious loss of sense of humour I have completed the shrouds on the sides of the boat and the ratlines !! I now fully understand why people build plastic model ships with pre- formed ratlines etc. I thought for fun I might count the number of hand tied knots but gave up after about 800 ! I did have to redo all the deadeyes on the fore and main masts as I made a complete mess of them first time. I learned a lot from it and my second attempt whilst not perfect I am certainly more pleased with. Now of course I have to deal with the rest of the standing rigging. Does anyone have some decent diagrams/plans of the rest of the rigging that you could send me from a similar build. My plans are dreadful and I really don't want to put rigging in the wrong places and spoil what I have done so far.
  19. You are very welcome. It's nice to anticipate a problem before it happens and having had my fair share with the same boat which was my first go I know how easy it can be to get disheartened. You are doing just fine!
  20. Just a thought, keep it coming with the pictures. Sometimes it is easier to spot a mistake before it happens and we only want to help.
  21. Oh no, the deck isn't painted. Varnished yes. Real shame about the splintering because you have done a good job so far. Don't worry though, by the time you have put the rest of the deck structure and bits and pieces on it really won't show much.
  22. That's a good job done well. I guess you will be fighting with the rubbing strakes next ?
  23. Make sure you sand along the grain of the planks. If you try to do it across the edge you will splinter them.
  24. Can any clever person out there tell me how tight I should have the shrouds?
