Everything posted by ChrisLBren
L'Amarante by marsalv - 1:36 - POF
ChrisLBren replied to marsalv's topic in - Build logs for subjects built 1501 - 1750
It does - thank you V !!!! -
Looks really nice ! Question - it does not look like you simulate caulking on your models or if so its very subtle ? -
Thanks guys - I like the Hornbeam a lot so far. It cuts easily and glues well. Also it carves nicely - harder edge to it than Pear or Box. Many of the Eastern European modelers swear by it as a replacement for ebony. As far as bending with heat - I will let you know once I get to the wales. That's probably months away - so far I've broken down and rebuilt more assemblies than I care to admit ! That stem was probably version three. My mill went astray this AM while cutting the rabbet. So I took it apart with my friend Iso Alcohol and will reassemble it tomorrow with a new forefoot. I am very happy the upper part of the stem consisting of black hornbeam was not yet glued to the lower half.
I Have an Itch to Scratch
ChrisLBren replied to SaltyScot's topic in Modeling tools and Workshop Equipment
This is the scroll saw you want - and buy the optional stand. https://www.homedepot.com/pep/DEWALT-20-in-Variable-Speed-Scroll-Saw-DW788/203070202?mtc=SHOPPING-BF-CDP-BNG-D25P-025_009_PORTABLE_POWER-NA-NA-NA-PLALIA-NA-NA-NA-NA-NBR-NA-NA-NA-PortablePower_2023&cm_mmc=SHOPPING-BF-CDP-BNG-D25P-025_009_PORTABLE_POWER-NA-NA-NA-PLALIA-NA-NA-NA-NA-NBR-NA-NA-NA-PortablePower_2023-19672073971-145268702359-2274863535266&msclkid=3c2019a6f0a416cca20d718582c146c2&gclid=3c2019a6f0a416cca20d718582c146c2&gclsrc=3p.ds&gad_source=7 Having a good scroll saw for scratch building is vital. The other tools I use the most are Jim Byrnes Thickness Sander/Disc Sander, Oscillating Spindle Sander and TAIG Mill -
Thanks for your comments ! Tobias - I haven't received Vahur's delivery of Black Hornbeam - it should arrive any day. I won't be using it for another month or so as I want to finish all the frames before beginning the keels parts where it will be needed. Update - the first 29 frames of 58 total are assembled and roughly finished. I will be installing bolts once they are faired and ready for final install into the jig. I have seen either copper square wire or brass square wire as the material to simulate them, copper has the advantage of blackening it in situation without bleed into the surrounding wood. I am curious if using brass do most simply just install the brass square wire and let nature burnish it over time or blacken it. My understanding is you will need to seal the wood first before attempting to blacken brass in situation to avoid the bleed.
Thanks everyone for your comments. This week was negative progress... I was up to 20 frames and decided to test fit all of the notches with scrap wood - 4.5mm for the inner slot and 7mm for the outer. I should have done this during construction. Some of the first frames were off by almost .5mm which is a big gap in this sort of construction. So 10 frames ended up in the trash can and 10 remain. Moving forward not only am I using an optivisor while milling, I am doing my best to cut halfway into the lines. The good news is I have plenty of Pear wood and I am in no hurry to complete this one. I really want to take my time to get this right rather than use any flawed part and pay for it later in construction. Huge tip I figured out - always use a backing piece of plywood while milling parts. Im getting perfect cuts with no tear out.
Greetings Group, Back in 2017 shortly after finishing Confederacy, I attempted my first Ancre scratch build, La Renommee. I have always been in love with this Frigate and her unique lines. I, however did not possess the skills yet to do her justice, nor a mastery of my recently purchased tools (chisels, Byrnes Machines, Sanders, and my first mill). Raising small children and establishing a new business also provided problematic to achieving my goal of building this ship. I worked on a few other projects including Le Gros Ventre in 1/36 scale which did increase my skills with the scroll saw, sharpening and working with chisels and scrapers, the Proxxon MF70, reading plans, building a build site and milling wood. However after a 2 year break and revisiting my progress I noticed, being new to creating frames, they were too large and would require a heck of a lot of sanding to get to spec. Also the Proxxon MF70 while not a bad tool, is not nearly as accurate as my recently acquired TAIG mill. I really wanted to give all the keel parts another go with this tool. The question became do I re do Le Gros Ventre, or work on one of the other Mongraphs I own in both 1/36 and 1/48 scale (Egyptienne, Renommee Amarante, Requin to name a few) A friend has shared the frame drawings of La Renommee 1/48 fully laid out (in the Monograph Boudriot only drafts half frames) and easy to print on my home computer. These are a god send vs running to the local UPS store to make copies over and over again (my experience with Le Gros Ventres frames). After running some tests I found I do like the smaller scale of 1/48 (at least so far) as it gives me the option to rig later. So Ive sharpened all the tools, cleaned up the workshop and La Renommee was started again two weeks ago. So far I have completed 14 frames that are very accurate with only about .5mm of fat. As you can see the notches on the frames are a bit complicated. I can not image this build without having a good mill. I have some black hornbeam on the way from Hobbymill in Europe to use instead of ebony for the black parts and plenty of Pear I've collected over the years. I will need to learn metal work in the not too distant future and carving in the really distant future, however I am confident with some good coaching I'll get there.
Great tutorial - Im still stuck on these on my LGV build - which has spacers between the extensions as you know makes it more complex. Nice work !!!! -
Still struggling with this decision. I personally believe the Taig Mill is better than the Sherline - our late friend Jim B steered me that direction. Im not sure about the lathe though. The Taig Lathe is half of the price of the Sherline however the Sherline gets better reviews online and has DRO. Hard call - I did sell my Proxxon MF70, Preac Saw, and Unimat to help pay for this purchase. The other route I could go is buy a wood lathe and the Taig for metal work which could be less than the price of the Sherline.
