Everything posted by Landlubber Mike
I'd build what you're interested in. If it's a frigate, build a frigate. I built the Caldercraft Badger as my first kit, and while I have three wooden ship builds in process at the moment, I didn't think they were too far a step up in skill level. To me, the bigger ships typically just have more repetitive tasks that need to be done, they don't necessarily involve new construction techniques. Just take your time and look at other logs and you should be good to go. If you are worried about experience level, just buy one of the kits with good instructions and lots of build logs on here. For what it's worth, the Euromodel La Renommee that I'm working on is a frigate. The kit pretty much comes with no instructions, but has really good plans. @piratepete007 has put together a wonderful practicum for this and other Euromodel builds that is very helpful. Euromodel kits do require more scratch building than typical kits - they are a good middle ground if you ultimately want to scratch build some day. I love the subject, which is based on plans found in Chapman's Architectura, but I'm convinced it's not a French vessel but more likely a Swedish vessel (more on that in my build log). I had started building the Corel Unicorn - also a frigate - but there are a lot of errors and shortcuts in the kit. It does make for a nice model, but if you're into accuracy, then it's not a good kit to try. I ended up abandoning my build for that reason - the hull was way too tall and the plans were all over the place - drove me a little too crazy and I just thought it made more sense to spend my time working on something else.
Hi Steve, I think I'm going to go with the higher ("original") waterline from the kit plans. Apparently the waterline was at different levels during various periods, so it depends on the period you are thinking about modeling I suppose. For me, I like the look of the higher copper line, and it would save me from having to plank in ebony that much further down the hull. If it helps, page 4 of my build log showed models with the different waterlines: For the copper plating, I'm thinking of replacing the plates with those from Amati or Caldercraft (I forget which). I'm also going to try to oxidize the copper a bit to get that green verdigris look. I suppose you could paint it, but would the lower hull look like it's copper plated?
Another creative project, I'm in! Love the idea and use of native woods, this is going to be another Glen special!
- 174 replies
- Waa Kaulua
- bottle
I'm doing mine a bit different in that I am covering the hull with very thin ebony. My guess is that I'll probably need some drop planks in certain sections or specially cut planks. For the planks below the waterline, I'm going to copper plate the hull so I'm not as concerned with the first planking. I just ran the first planking as naturally as possible, and filled the gaps with stealers as necessary.
Great job Craig! Coming along nicely! I have increasingly gotten to like Mr. Putty. I also like the Tamiya two-part sculpting epoxy. It works well and doesn't shrink like other putties. For big gaps, I try to fill with plastic card as much as possible. I'll also use CA as a small spot filler - it works really well and sands nicely.
Wow, what an amazing model Jolle! Thank you for sharing it with us! Looking forward to your next project.
1/200 Trumpeter IJN YAMATO - issued by MRC/Gallery Models
Landlubber Mike replied to yvesvidal's topic in REVIEWS: Model kits
Me too! Pontos does very comprehensive detail sets - should look fantastic!- 104 replies
- MRC/Gallery
- Yamato
Jolle, the detail from the Pontos set, the figures, and your other improvements have elevated this model to incredible heights. Really nice job!!
