JSGerson
Everything posted by JSGerson
  1. Hey, I'm a life long 77 year old bachelor with no one to answer to except myself and the cat, so I've got time to gather stuff and organize it for easy retrieval. I try to share the wealth. Jon
  2. I have approximately 25,500 images of the ship from the very earliest in 1857 to the present showing all kinds of detail from multiple angles and multiple sources (public & private) that I have collected since about 2014. Should you or anyone else need a image showing particular detail, there is a good chance I may have it. Just ask. Jon
  3. For those who did not take` the time to read this vintage text, I copied the section in modern font for your convenance: Composition for Blacking Guns lbs. lbs. Black lead 20 Red lead 10 Lampblack 14 Linseed oil 18 gals. DIRECTIONS: First the above mentioned articles must be ground very fine with boiled oil. PROCESS Boil the oil sufficiently until every appearance of froth subsides – the best way is to have two iron pots, dividing the oil in each pot, put the black lead in the boiled oil, and boil it half an hour. The 10lbs. of red lead must be put in the other pot, after the oil is put on the fire and boiled half an hour; after which, put the lampblack to the red lead and boil them together half an hour. – The two pots must be put by until nearly cold, when by the means of an iron ladle the ingredients must be shifted from one pot to the other, until they are naturally well mixed. CAUTION. Great care must be taken during the time the liquor is preparing to prevent its boiling over, and in particular to keep stirring the ingredients during the time of boiling. Marshall’s Practical Marine Gunnery CONTAINING A VIEW OF THE Magnitude, Weight, Description & Use, OF EVERY ARTICLE USED IN THE SEJ GUNNER'S DEPARTMENT, IN THE NAVY OF THE UNITED STATES., 1822, p94-95
  4. Gregg, well I don't have ALL the resources, but I do have a bunch😛 As for printing them out full size, I haven't done that as it is costly and inconvenient. I did have the kit's plans copied full size so I could mark them up, fold them in torturous ways, and if they get damaged, no worries. I print out what I need on a regular inkjet printer on standard paper using PowerPoint. When I need to print to model scale, it's by trial and error because PowerPoint can't print to a given scale on command. Additionally, I may need to tape together multiple sheets to get the desired printed image, which I admit is a crude method. Most of the time I just zoom in and out on the computer screen. The US Navy plans have the actual full scale dimensions so it's just a matter of scaling down the numbers for a lot of things. Jon
  5. Dputxler, you can get the US Navy plans here: https://ussconstitutionmuseum.org/discover-learn/modeler-resources/ Jon
  6. Very sharp eyes! Yes, I spotted that too. luckily the pumps were only dry fitted when the photo was taken. That misplacement was corrected almost as soon as I made my posting. I didn't think any one would notice. I appreciate your attention to the details. Thanks! Jon
  7. At this point I installed the last of the gun deck furniture previously made four years ago: double pump quad pump sea chest scuttlebutt & table grog cask & table harness cask Still to come, the remaining spar beams and associate accoutrements to support the main hatch.
  8. Getting back to the ladder hand ropes, I left the messenger rope loose on the deck as if it had just been released from the cable or chain and the ladders were put back in place. Technically, either the messenger is in place, or the hatch covers and ladders are in use, not both at the same time. In either case, it’s all going to be difficult to see and the layman certainly won’t know anything looks out of place. Next, more spar deck supports and their associated diagonal knees at their bulwarks were installed aft of the capstan. Additionally, some “temporary” (as marked on the US Navy plans) supports (painted white) were added as well. It’s getting really crowded on the gun deck.
  9. The messenger rope was installed first since it was wrapped around the capstan. A spliced loop end was created for each end of the messenger rope first. Then the rope was wrapped around the capstan three complete times. The rope went along the gun deck to the bow around a support and back again towards the capstan. There would have been a roller mechanism for this at the apex of the turn in the actual ship, but that will not be seen in this model. The two end loops of the messenger rope were then lashed together. The lashing had to be done using needle and thread in the confined space of the model and was a bit delicate to do. The anchor cable and anchor chain were inserted through their respective hawser holes in the bow, down the length of the deck using anchor chain guides previously installed, and into the pipe in the gun deck. Neither ends of the cable nor chain were permanently installed pending attachment of their anchors at a later date. Oh, I also installed the framework for the main mast so it has a rake of 3.5 degrees.
  10. When I last worked on the gun deck capstan, I left it in such a manner that I could fine tune its height to the proper length when I knew how long it had to be. With the spar beam dry fitted above it, the capstan was cut and sanded to its final height and installed (shown without the spar beams).
  11. Determination of the Anchor Cable and Messenger Cable Size The question arose: what size is the messenger cable? First, I had to determine the size of the anchor cable. Step one as indicated below, I found on another builder’s log who was quoting one of the historical ship building books of old. Sorry, didn’t record that either. 1. “The Circumference of the anchor cable = 0.62 the Diameter of the mainmast” 2. Main Mast Diameter (US Navy plans) = 32” (full scale) 3. Anchor cable Circumference = 0.62 x 32” = 19.84” (0.258” scale) 4. Anchor cable Diameter = C/π = 0.258”/3.14159 = 0.082” 5. Guestimate that the messenger cable is ½ the Diameter of the Anchor Cable = 0.041” (3” full size) I could not find the rule for messenger cable size, so it was assumed the messenger cable diameter had to be small enough to wrap around the capstan and still be strong enough to pull either the cable or chain. In my stock, I have Syren Ship Model miniature tan rope sizes 0.080” and 0.035” for the anchor cable and messenger cable respectfully which should work for the model.
  12. I ran into a couple of surprises that although I had thought about them before, I overlooked in the end. When the capstan is engaged, anything that would interfere with the capstan operation and anchor cable/chain are in the clear, like hatch covers are in place and ladders are stowed away. In my case, I fabricated the hand ropes and stanchions for the ladders going down to the berth deck next to the gun deck capstan. As built, they would interfere with the messenger cable wrapping around the capstan. Also, I forgot to create the ladders going up to the spar deck for the open capstan hatchway, which I took care of. One of the infamous Murphy’s Laws states: that no matter what you must do, you must do something else first. In this case I must install more supporting spar beams and their associated diagonal knees at the bulwarks as well as their support columns. But the more beams I install, the more difficult it becomes to install other items on the gun deck. Therefore, I’m constantly checking the sequence of fabrication and installation. While I’m doing this, I decided it was time to lay down an anchor cable and an anchor chain. There are three anchors that came with the MS kit. One will be attached to the anchor chain, the second one to the anchor cable, and the third will be stowed on the deck. The anchor chain that came with the kit has single links, but according to the photographs of the ship when she last used her anchor in the 1930s, she had a cross-linked chain. Today those chains are being used for mooring. I bought such a chain off the internet a year or so ago and unfortunately neglected to record where I purchased it from. The chain metal appears to be copper which required that it be blackened. The picture below shows the chain after it was blackened and drying.
  13. Rich, that is the difference between a model (what you are making) and a reconstruction which matches every little detail to the real thing. Mine is a model, based on the recent 2015-17 restoration, with elements of 1812 and 1927 configurations. We are the ship builders and captains and the resulting product is as much a part of ourselves as it is of the original builders and subsequent restorers of the actual ship. Enjoying yours and Avi's logs Jon
  14. Post your offer here on this website. It's where you can sell, buy, donate, and request all kinds of stuff. I found it by using the search feature on the home page with "for sale" in the search item. Jon
  15. Yours was the higher resolution, thanks. My Rattlesnake was kit-bashed and made from natural woods following Mr. Hunt's practicum. Various woods were used for different "colors." (Black paint was used in lieu of Ebony wood (its sawdust is toxic)). To think I tried this on my first POB square rigged ship model is scary to me now, but I didn't know better then. I'm still happy how it turn out. Jon
  16. I found one more: Mantua 1:98. The kit is designed as natural wood. If I were to build this kit as natural wood, I might substitute woods of different colors to mimic the blacks and whites portions of the real ship. Jon
  17. For me, my choice is simple. My model is based (with some exceptions) on the present version because I have access to thousands of photos of the actual ship as she floats today. Building an historic model, I would have to rely on paintings, old books, and old drawings which can be very complicated or assumes the reader has more nautical understanding than I have to understand. So, modern rigging it is for my model. kmart, when you started your build, I believe you were shooting for the 1812 configuration. Bluejacket's model is by design, to be 1812 era. model. I would use that as my primary rigging guide, and fill in in any gaps from other sources as required. You can buy their rigging plans if you don't have them. As you may know, rigging styles vary from era to era, ship to ship, and captains to captains. A ship may leave port with one rigging style and return with another depending on the environment the voyage encountered. So there is no one correct rigging plan. You're the captain of your ship; what you choose for your ship, is by definition, the correct one. Jon
  18. Peter, I use my disc sander like a belt sander. Granted, they are not the same tool, but I make it work. Jon
  19. I have/use 4 basic power tools: Dremel rotary tool Byrnes table saw - Invaluable!!! Small disc sander 50 yr old Dremel scroll saw I also have, but rarely use these power tools: Byrnes dimensional sander Small wood lathe I have learned not to anticipate a tool I may need in the future because I most likely won't need it. Buy it when you are positive you need it. This goes for both hand and power tools. Always research the tool before you buy. Hope this helps Jon
  20. If you have been following my log, you would know that ladders have been my nemesis. I tried building ladders without trend grooves in the side rails like, you early in my build, and luckily they were installed from the gun deck to the berth deck so you couldn't see much of them. They weren't that good. The ones I made for the passage from the gun deck to the spar deck inspired by Mustafa's method, came out much better though still not as nice looking as yours. That was a lot of meticulous work you invested and you were rewarded with beautiful ladders. Well done! Jon
  21. I found I enjoyed making that boat so much, it was like eating potato chips, you can't stop at one. Soon after I finished the Rattlesnake, I started working on the Model Shipways USS Constitution. So, the first thing I started working on when I started the model was to fabricate the ship's four whale boats. You might want to check on those. That was seven years ago and I figure I've got another bunch of years to go. Have fun, if nothing else Jon
