foxy
Everything posted by foxy
  1. Well its on again today, with the crest made up and now mounted, it was the turn of finishing the latin lettering to the bow. Using Dafis help full hints made this a lot easier. Then it was the lettering, only lost two letters, but there are plenty more to make up for this, but care is needed. Next the nymphs were added, but also added some plastic to support the crest, once painted this is in non/visible. The Driver Booms were next, having made thes and the Gaff earlier, it was only the parrals to allow free movement. Boom in place but Gaff needs some more work before in stalling. Made the parrals from lead weights, split and ca to hold, came out well I thought. Then seeing the channels were set ok, I started adding the deadeye's, these using Dafis etched one's with the Heller centre's. Being no more time(tea time) I only did the one for-d set. Frank.
  2. Cheers Daniel. Well now its the draught marks next from Dafi's etched set. Good to have the hints and tips at this part of the build. Stern. will add more copper to tidy up. Same with Bow. Have now completed all the Hatch's and tided up the hull. Then fixed the channels in position and left to set proper. Have also fixed masts in position. Next is dead-eye's and crest to bow. Frank.
  3. At Nelsons last battle the marines suffered very badly, Nelson refused any one going to the tops as sharp shooters, which ment the marines had to withstand a blistering array of grenades and musket fire. The marine Captain had to call up all the Marines manning the guns to help stem the tide on deck. As there were only a few marines left on deck to return fire. Frank
  4. Cheers OC. Well its a picture of the Captains quarters, have added more items after this picture, doors to the Galley and some smaller items. Placed poop deck on at this stage and added some more fittings. Then it was to the rigging I turned. Made up heart blocks from Syren models and added to bowsprit for preventer stay's later. Next its the port side hatch's and a clean up, then on with the channels. Frank.
  5. Added the windows at this stage. Plus Captian Hatcher tested the Marine work. Then it was a test fit of the masts. All sitting comfortable. Next its fit out the Captains quarters and start on the port side hatch's. Fix the poop deck and then the Channels/deadeye's and chains. No pressure then. Frank.
  6. Thanks very much Bob. It was an old kit and took some work to get the crest looking right, Dafi made new lions for his and I nearly went down that road. But happy with it. Next it was the ships wheel in place, made sure the poop deck was not compromised. Added figures that may or may not be used. Next I fitted the Bowsprit at this time. Adding Dafi's Resin Knights head that I explained earlier how I went about this. Rapped ropes around, for this I used black 0.65mm rope, will use also for the lower preventer stay's. Then the marine work and support. Last picture is of the Kit stern lamps, these come in clear plastic and with a bit o paint do not look to bad. Still to remove plastic supports and add Dafi's brass one's. Frank.
  7. The poop deck kept my attention today, having planked it I started putting Dafi's eyelets/kevels in place. Also the beams across the skylight. Placed the etch skylight and you can see the beams, so thanks Daniel for the input on that. Also working on the furniture for the Captains quarters, will not bore you with it till I have completed this section of the ship. Frank
  8. Thanks OC shipmate. Ok had ago at the stand and have from Cornwall model boats some wood supports. They screw to the keel and are a lot stronger, just some varnish later, can be unscrewed so I can continue with my Keel holder. Next it was the Hatch's, these were painted and sealed then fixed to the deck. Am adding more that I made earlier so its beginning to take shape faster. For the main hatch I made up in two parts and painted. Then fixed to quarter deck. Also at this time added the smaller steps behind the Mizzen mast. More to follow. Frank
  9. Thank you Daniel. Yep was a challenge and thanks to your helpful hints it came out OK. Well before sorting the stand, I decided to do the Hatch's, the Heller one's I thought were to small in height. So am making mine from evergreen plastic. I made up rough using the Heller grates. After sawing/sanding they began to take shape. Note Marine Officer Captain Hatcher is Officer of the watch. Some paint next and then fix. Then its to the Captains quarters we go. Frank
  10. Cheers Guys. Thanks Bob shipmate. Moved on a bit with the planking. Used four apart for the main quarter deck and three apart for the Poop deck. But first the pike racks. These are Dafi's etched parts, and as he say's in his hints and tips, 'very fiddly'. Both the foremast and main carried these in racks, main full circle, fore half circle around masts. Fitted 5mm from the deck. As I am planking this deck, I used some wood to get the height and fixed the lower rack circle with the top one just slid on. Then measured the distance and fixed the top rings. Then loaded the pikes. Some touching up with paint. Next its some strapping to hold pikes in position. Then it was the turn of the deck. Worked from the centre out. 'Hey presto'. Now completed the planking on all decks. Next its to fit a better support for the stands fixed to the keel. Have some wood and brass one's. Will use the Brass I think. The stands that come with the kit are to flimsy and keep snapping. So before I go to much further, this has to be sorted. Frank.
  11. Thank you guy's for your input, most appreciated. Well from there it was a case of mounting the next (quarter deck). First Nelsons cot. The deck was put in in two parts, so as not to damage any thing below. Added chequed pattern to Captains quarters. Plus the support posts on the boat deck. Next its Dafis etched pike racks that adorn the Four and main masts. Frank.
  12. Cracking work Luke, that size is very difficult to work with. B.E. has the solution . Frank
  13. Well here I be again folks. Some more update on the build. First a picture of the boats which are now finished and ready when needed. Next is the 12 Pdrs in place and roped. Added the doors to the forecastle. And an overall picture of the progress. Next was the block and tackle, had these made up earlier, but it takes time to fit. Before. After. Next its the net rails around the Hatch's. These were made of brass. Sprayed with a Tamiya grey primer and then hand painted black. Then when dry a coat of Admiralty white paint. Not a hundred percent correct on the supports. Added netting and it looks much better. Frank
  14. Thanks guy's. Well had a break, but soon back on deck again. A call to the dark side has had my attention for a bit. Securing the 12 Pdrs to the upper deck and then its the dining room to sort out. Frank.
  15. Keep it up Daniel, can smell the broth from here. Marines only had short dress coats, the tails were for officers. Unless they are earlier than 1800, then fusiliers were stationed onboard. but lovely detail. frank
  16. Nice work Tim. Bob. You know grout attracts fungus. Frank
  17. Well we all seem to find a diff route, but, get there in the end. That's the way building goe's. Take your time Keith, just enjoy it when you can, that's the ticket. No pressure Frank
  18. Nice work Tim. I to think the entrance is the same width as the gun ports. AS for the removal and replacement, that is up to you Tim me lad. Frank
  19. Glad your still working on the Connie Evan. Nice to see any progress. Still building up a picture for mine, and your build is an inspiration I can tell you. Wonderfull work. Frank.
  20. Well started weathering the hammocks. This stuff is clay based and can be washed off as required, once dry it stay's. Next is the very usefull keel clamp I was on about, boy don't it make life easier. With the boats near finished, it was time for the oars. made these in four parts for two of the boats and three parts for the other three. Four parts Three parts. Frank.
  21. That's some fine coppering you have there Keith, great stuff. Frank
  22. The lighter guns were allways at the top. Heavy/medium and light for three Decked ships. Very nice work . Frank.
  23. Nice work Daniel. You think of everything . That's some fine way of going about the lower deck hatch's. Frank
  24. Hi Izzy Madd. I to had a bit of a headache on the hammocks, sore how Daniel did his made me think on the same lines as you. But sore on EBay a second hand Heller kit going cheapish , so managed to have a spare pair. This idea is not only easier but stronger, even if I have to chop them up to fit Daniels etch supports, that's a little way off at the moment but needs sorting. Also finding it very awkward to handle Victory while working on it, to that end I have purchased an Amati Keel clamp from Cornwall model boats, which is quite expensive, but as I have many more ships to build, this will be worth it, 'so I tell myself '. Cheers OC. Frank
