Everything posted by Siggi52
Hello, the carpenters say many thanks for your likes. I should tell you that 😉 Today we finished the carlings and the carpenters started to cut the slots for the ledges. That will take some time, even when we install only there ledges where you could see them later.
Hello and many thanks for your likes. I'll tell the carpenters. Today they where also very busy to lay out the next rows. I hope that we get the rest tomorrow ready.
Hello Mark, your problem is a self made problem. If you had a look at the decks plan of the gun deck, you would see it. Here I show the decks plan to the sheer plan. In blue are the beams you have drawn, but you did't draw the short bowed beams, in red. Sorry my english. If you set the standard at that short beam, you did it! The same with he next beam. Why did you omit that standard in your drawing?
Hello, and thank you all for your comments and likes. At the shipyard the carpenters set the last pillars at the gun deck. Next are then the carlings and the last smaller things at the deck.
Thank you Mark and Druxey, that is then something I have to remember when I build them at the upper gun deck. I think for the gun deck I leave it as it is.
Hello, and many thanks for all the likes and comments today only a short update, the carpenters installed the pillars aft. The man from the admiralty spend rum for a grog, so it's not so much work today. Is it over there also so wet and cold? I do not like this weather, but until May I think it would't be better.
Hello, and many thanks for your likes today is a great day, the chain pumps are ready. Even the man from the admiralty came to watch it. Ok, there is no water in the ship, so we could't test it working.
Hello Gary, that is really interesting. I had only a short look at the gun deck plans, before I posted my comment. But realised later, that the upper gun deck of the Dorsetshire plan, was disordered on which side of the beams are the hanging knees. When it is right what Druxsey said, that these plans where made „as build“ plans, then I would say, that the shipwrights had the choice where to locate the knees. At the plan for the 1745 establishment they followed mostly the for and aft theory. Because that was't a real ship they had drawn there. At the plans for the real ships, who where later build, are no knees drawn. Very interesting is here, that they did't plan hanging knees in the captains cabin at the upper gun deck!
Hello Gary, I do not understand your question fully, but in front of the main mast the hanging knees are in front of the beam, behind the main mast they are behind the beam. That is what I could tell you, depending of the plan from the 1745 establishment and the Dorsetshire plan.
Hello, today only a short update. I turned the pillars for the gun deck. They are all turned manually.
Hello, today only a small update. Because some of the beams where to high, I had to level them all to the right high. The shipwright is now testing the elm-tree pump and also with the cannons seams to be all ok. The next thing to build are the carlings for all those beams. 😟
Hello, and many thanks for your comments and likes. Today was a great day, because we laid all beams of the upper gun deck. The shipwright was very pleased, and spend a brandy! 😊 From the ropewalk came the anchor cable. For this I used dark brown yarn, but made also an experiment and tarring a cable. That looks very interesting. That tar diluted with benzine is now dry, that one diluted with turpentine is still sticky. But they are both black now, as at the contemporary models.
Hello, now the Rudder is ready. Because there was no protest or other solutions, I build it the way I think it is right. At least it's not an unknown praxis. Ruder2.mov
Hello and many thanks for your comments and likes the last week I was not very busy at the shipyard but I got the tiller and most of it's components finished. The sweep, flush with the beams, as the 1719 establishment asked for. And here all parts are together, and it works! 😅 I don't think to build also the ledges here, most of this you would't see when the ship is ready. So far, so good but how to get the ropes up? The wheels are behind the mizzen mast, so I should have the sheaves direkt behind the beam. In the middle of the beam is a carling and I could build between this and the next carlings to the outside diagonal carlings with the sheaves in the middle (blue line), or build like the French there a block with the sheaves and support it with the carling. At least is this the same as at the side of the ship. I don't know, but prefer the last method.
Hello, this time only a short update. The crew finished the cabins at the stern and the knees for the transom. The tiller is also in the raw ready. so the next time the crew has to build the rest of the beams.
Hello, today the carpenters build the step for the bowsprit and the manger. The painter painted it afterwards. I think, he has to wait until the paint dries to get out there 😁 The next thing would be to build the cabins for the gunner and his neighbour in the back of the ship.
Hello, and many thanks for your likes. Today the carpenters where extremely busy. They build all the beams who are made from one peace of wood. This ship is smaller and has lower decks. Here you can see the beams are only 5f 11,5in above the deck.
Hello, it is done, the standards for the gun deck are in place and also the scuppers are bored and painted. As next I would build the beams for the upper gun deck. I would't install them permanent, but I would have as much done at the gun deck as I can, before starting and finishing the outside of the hull.
Hello, it seams so, that this is not a theme of much interest or knowledge. Yesterday and today I searched more about the list's of establishments. The 1719 list is the most complete list with two modifications who deal only with the length and breath of the ships. Also the list of 1745 and her modifications, deal only with the dimensions of the ships, not with the interior. When I looked at the information about the Dorsetshire (1757) I learned, that she was build to the 1745 list of establishment, as a 70 gunner but carried only 64 guns. Interesting is, that the master shipwright was Peirson Lock of Portsmouth. The Tiger was build at the shipyard of Thomas Stanton & Wells, Rotherhithe. But the plan was made by a John Lock, Woolwich, later master shipwright at Chatham. That all brought me to the result to use the plan of the Dorsetshire as a reference for the Tiger. She was build 28 years after 1719, but only 10 years before the Dorsetshire. May be it was right in 1719 to have only 2 pairs of standards at the gun deck. But that did't tell us, that the shipwrights saw it the same way. They had a lot of freedom in those days. All plans of the sister ships of the Tiger looked a little different. So, there is a lot of work in front of me. But because we have the next month a partial look down, it would be ok. All is better then building gun ports 😉
Many thanks Gary, for my Dragon I build them also like you have build yours. But now there should be only 2 pairs of standards at the gun deck. Ok, I think that would't be a problem, I do not build them. At least you would't see them. The question is , how would the iron version look like? But for the upper gun deck I think I should build them. As always is here the plan for the Dorsetshire (1757) a great source. Where I made the brown arrows I think that that are the standards. But what are these things behind them, (blue arrow) cleats? Like this at the Medway? Or did they bore holes through the standards and set them in? Just some round peaces of wood. So with only 3 pairs of standards I have the choice to set them evenly in the middle of the waist. If someone has more information about that, you are welcome. At the moment I have to make decisions only for the gun deck. This is the gun deck of the Dorsetshire. Here are some standards thinner then the other. Are that the iron one?
Hello Gary, the standards are at every side of the ship and there normally in the middle where the ship is strait. At the picture from Falconer they are behind the cannons. „ F“ for the lower cannon. And then between the cannons at every second beam.
Hello, I'm sorry that I did't mention that the elm-tree pumps at the moment are not to be permanent installed. This morning I gave them a coat of lacquer and after that they went to a save place. But I have a question about the standards used in a ship. In the 1719 establishment list is there something unclear, or I did't understand it. All I could find about this, I found in Goodwin's Constructions and fitting...., and what he writes there (at page 108-109) is even more confusing: By the end of the third quarter of the eighteenth century the number of standards had been reduced, and they where found only on lower decks. Falconer describe them short, and at his plate VII you could see one. Lavery in his Ship of the Lines II, only mention them. In his Bellona book he has a picture with lots of standards at both gun decks, Page 46, B27. I think it's the Berwick plan from 1775. Because in the 1745 establishment list they did't deal with such things, I have to look in the 1719 list. There I found this about the beams and for the Gun Deck this and here for the Upper Gun Deck Far to the right you found what is for the 60 gunners. They listed for the gun deck 2 pairs of standards, one of them from iron! For the upper gun deck 3 pairs, none of iron. So at least I did't know what to do. In 1775 a 70 (?) gunner has 9 pairs of standards at the gun deck and a 70 gunner up to 1760 only 3 pairs? And Goodwin wrote that they reduced them.
